Topic: Help with Parallax 2x16 Serial LCD? (Read 4599 times) previous topic - next topic
_Marcus
Apr 30, 2012, 12:17 am Last Edit: Apr 30, 2012, 12:36 am by _Marcus Reason: 1
I am trying to get this LCD working, but it seems nothing I do works.
I started searching around, and I found a link, but it's dead. Link: www.cyberblob.net/parallaxlcd.zip
My code isn't working either. Here is my code:
Code: [Select]
 lcd_turnOn();
 lcd_backlightOn();
void lcd_clear() {
 Serial.write(12);
 delay(5);
void lcd_newLine() {
 Serial.write(13);
void lcd_turnOn() {
 Serial.write(22);
void lcd_backlightOn() {
 Serial.write(17);
void lcd_backlightOff() {
 Serial.write(18);
And on the back of the LCD device, I have switch 1 set to off, and switch 2 set to on, which is what they ask me to do in the documentation.
I've also tried changing all "Serial.write" to "Serial.print" and "Serial.println" and nothing happened still.
So does anyone know what I can do to get this thing working? The examples shown on the documents provided by Parallax are not for Arduino, and are in BASIC. Docs: http://www.parallax.com/dl/docs/prod/audiovis/SICSerialLcd.pdf
Any help would be highly appreciated!
runaway_pancake
#1
Apr 30, 2012, 12:40 am Last Edit: Apr 30, 2012, 12:51 am by Runaway Pancake Reason: 1
I think that you have to send it some text to display.
And make sure the DIPswitches are right for 9600.
(If you don't have the backlight version then that won't work.)
Code: [Select]
 Serial.write(22);
 Serial.write(12);
 delay(5);
 Serial.print("Hi Guy");
 lcd_turnOff();
 lcd_turnOn();
void lcd_turnOn()
 Serial.write(22);
void lcd_turnOff()
 Serial.write(21);
* * * *  There's a "Kickstart" with Arduino example --
https://sites.google.com/site/parallaxinretailstores/home/2x16-serial-lcd-backlit
It uses 'software serial' though.
When using Arduino TX (D1/pin1) you should probably disconnect the USB first?  Not sure.
Disconnect the LCD from TX when programming.  Disconnect USB.  Connect LCD.  Power up.  ?
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
floresta
#2
Apr 30, 2012, 02:14 am Last Edit: Apr 30, 2012, 02:25 am by floresta Reason: 1
The LCD does not need to be 'refreshed'.  Any information that you send to it will remain there until it is overwritten.
You generally only send information to the display in loop() if that information is changing, such as periodically updating a clock.
If you want to see if you can successfully display anything on the display you will have to do this in setup().   You should go back and try sending some information to the display in setup() and get that part working before you try to do anything with loop().
Don
[Edit]:  Did you look at the Arduino 'kickstart' example that was referred to in Reply #1?  Did you notice that loop() has nothing in it?
ernieb
I wrote this code this morning and it worked first time before I started playing with it but it may help.
const int TxPin = 7;
const int Baud = 9600;
#include <SoftwareSerial.h>
SoftwareSerial mySerial = SoftwareSerial(255, TxPin);
int loopCount = 0;
  pinMode(TxPin, OUTPUT);
  digitalWrite(TxPin, HIGH);
  mySerial.begin(Baud);
  delay(100);
  mySerial.write(12);                 // Clear
  mySerial.write(17);                 // Turn backlight on
  delay(5);                           // Required delay
  mySerial.print("Hello, world...");  // First line
  mySerial.write(13);                 // Form feed
  mySerial.print("from Ernie!");   // Second line
  mySerial.write(212);                // Quarter note
  mySerial.write(220);                // A tone
  delay (1000);
  mySerial.write(21);
  delay (1000);
  mySerial.write(22);
  delay (1000);
  mySerial.write(18);
  delay (1000);
  mySerial.write(17);
  delay (1000);
  mySerial.write(12);
  delay(5);
  mySerial.print("   Loop Count ");
  mySerial.write (155);
  mySerial.print(loopCount++);
floresta
Quote
If you want to make your post a lot more useful then you could add some comments that explain the magic numbers in your loop expressions.
If you want to make your post a lot more legible you could highlight the code portion of the post and use the 'code' button (the #) to make it look like the code in reply #1
Don
ernieb
Don, point well taken.
Here is a program which uses the serial display and a simple pot fro gnd to +5 and it works as a voltmeter.
Hope it is helpful to others.
Ernie
Code: [Select]
  LiquidCrystal Serial
Demonstrates the use a Paralax 2X16 Serial LCD display.
This sketch prints "Hello, world..." to the first line LCD
and "From Ernie" in the second line. It then loops with a
counter running and  plays with the backlight and display.
The circuit:
* LCD Serial Pin to digital pin 7
By Ernie Bose
Created 2 May 2012
by Ernie Bose
  This example code is in the public domain.
  display information can be found here:
    http://www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/27976-7-9-ParallaxSerialLCD-v3.0.pdf
    The command set describes what each command does to the display.
//  Constants used so all the setup stuff is in one place
const int TxPin = 7;               // serial output to display
const int VinPin = A0;              // analog input for measurement
// The int2voltstr subroutine converts an integer value in the range 0 to 1024
// and converts it to a string of the format 00.00. The value is scaled by the
// map function so that the range is scaled to represent 0 to 500 for 5 volts.
// The string is returned.
String int2voltstr (int v)
  int vv = v;
  char voltageString[6];
  // Do these two first since they don't change:
  voltageString[5] = 0;    // Null termination for the string
  voltageString[2] = '.';  // Decimal separator can be changed to comma
  // Make the value be in between 0 and 500
  int mappedValue = map( vv, 0, 1023, 0, 500 );
  // Working backwards, take the bottom digit and shift
  voltageString[4] = '0' + mappedValue % 10; // Take the bottom digit
  mappedValue /= 10;    // Shift by one digit
  voltageString[3] = '0' + mappedValue % 10; // Take the bottom digit
  // Decimal was already written above, skip voltageString[2]
  voltageString[1] = '0' + mappedValue % 10; // Take the bottom digit
  voltageString[0] = '0' + mappedValue % 10; // Take the bottom digit
  return voltageString;
  pinMode(VinPin, INPUT);
  mySerial.begin(Baud);               // Set serial Baud rate
  delay(100);                         // wait for the display
  // The next lines are for debug purposes and not needed in the final
  //mySerial.print("Hello, world...");  // First line
  //mySerial.write(13);                 // Form feed
  //mySerial.print("from Ernie!");      // Second line
  //mySerial.write(212);                // Quarter note
  //mySerial.write(220);                // A tone
  String strVolts;                    // String to store the results
  int volts = analogRead(VinPin);    // Get the value from the input pin
  mySerial.write(12);                // write form feed to the display to clear
  mySerial.write(148);               // put the cursor at the beginning of line 2
  mySerial.print(volts);             // print the raw analog pin data
  strVolts = int2voltstr (volts);    // convert the raw data into a scaled string
  mySerial.write(128);                // put the cursor on the top line
  mySerial.print(" Volts = ");
  mySerial.print(strVolts);           // print Volts = xx.xx
  delay(200);                         // let the display catch up and do it again
