Author Topic: Using Xbee S1 to communicate between two arduinos.  (Read 616 times)
I am trying to use two XBee modules to send commands to the other arduino to do something.
The code I have (see code bellow) works and I wanted to use it so I can use the same keypad attached to my first arduino to control the other arduino to do exactly the same thing as the code shows.
I configured the two XBees (set the Pan ID same for both, Channel 11 for bought, Baud rate = 115200 for bought) and don't know what to do to the code. So I just uploaded it to both Arduinos but didn't work.
I matched the baud rate to my computer. the code has the serial print command.
 I guess I am not understanding something. Any suggestion is helpful.
Here is the code
  #include <Keypad.h>
const byte IOXpin = 2;
const byte ROWS = 4; // rows of the keypad
const byte COLS = 4; //columns of the kepad
char keys[ROWS][COLS] =
    { '1','2','3','A'},
    { '4','5','6','B' },
    { '7','8','9','C' },
    { '*','0','#', 'D' }
byte rowPins [ROWS] = { 3, 4, 5, 6};
byte colPins [COLS] = { 7, 8, 9,10 };
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  pinMode(IOXpin, OUTPUT);
  digitalWrite(IOXpin, HIGH);
  Serial.begin (115200);
void processNumber (const unsigned long amount)
  Serial.print ("Dispensing ");
  Serial.print (amount);
  Serial.println (" uL.");
  if (amount < 19 || amount > 300)
    Serial.println ("Invalid Amount!!");
    return;
  unsigned long startTime = millis ();
  unsigned long runTime = amount * 100;   // assume 0.1 secs per uL
  digitalWrite (IOXpin, LOW);
  while (millis () - startTime < runTime)
    if (kpd.getKey() == '*')  // cancel button
       Serial.println ("Cancelled.");
       break;
  digitalWrite (IOXpin, HIGH);
  Serial.println ("Done.");
void handleKeypress (const char key)
  Serial.print ("Entered: ");
  Serial.println (key);
  static unsigned long receivedNumber = 0;
  switch (key)
    case '#':
      processNumber (receivedNumber);
      receivedNumber = 0;
      break;
    case '0' ... '9':
      receivedNumber *= 10;
      receivedNumber += key - '0';
      break;
    default:
      Serial.println ("Unexpected input!");
      break;
    } // end of switch
  }  // end of handleKeypress
  byte key = kpd.getKey();
  if (key)
    handleKeypress (key);
Seattle, WA USA
Seattle, WA USA
Series 1 XBees need to have MY and DL set. MY on one must match DL on the other, and neither should be 0. Did you set these?
What's the MY stand for?
Western New York, USA
In this scenario the XBees are substituting a radio link for the wires that would otherwise interconnect your two Arduinos.
Get your program working properly using wires first, then deal with the XBees.
Ask 'Digi' or look in their datasheet.
Don
Very good idea flores. Thank you
Sorry for dispelling your name. Very good idea Floresta. I guess by the two wires you meant RX and TX right?
Well here what I did:
I tried to see if it'll first work with a simple program like the one made by Jeremy blum. where he used two arduinos (first one to read a pot input and the second to get the input of the pot from the first and turn servo motor on the second arduino) His code is correct, and verified, but when I apply it to mine the motor just goes crazy when I turn the pot and it doesn't stop. It just vibrates like a phone. No turning as you turn the pot.
Here is the code of Jeremy just that you see what I am talking about:
/*The pot in the first Arduino
int potPin = 0;
  int val = map(analogRead(potPin), 0, 1023, 0, 9);
  Serial.println(val);
  delay(50);
//The servo in the second arduino
#include <Servo.h>
int servoPin = 9;
Servo mysServo;
  mysServo.attach(servoPin);
  while( Serial.available() == 0);
  int data = Serial.read() -'0';
  int pos = map(data, 0, 9, 0, 180);
  pos = constrain(pos, 0, 180);
  //turn
  Serial.println(pos);
  mysServo.write(pos);
  Serial.flush();
please provide some feedback.
Thanks
Have you tried   Serial.print(val); ?
Don
Seattle, WA USA
Seattle, WA USA
  Serial.flush();
Throw away random amounts of unread data (0023 and earlier) or wait until all pending data has been sent (1.0+). Why do you need to do either one?
but why the same code worked for Jeremy and not for me. I did the same thing. This means I have some problems with the Xbees not the code of the arduino
UK
No, it probably means that you have some problems with the Xbees as well as the problems PaulS pointed out with the code of the Arduino.
