Topic: expected initializer before void function (Read 2190 times) previous topic - next topic
kikivick
hi, im new to arduino, and when i compile my code the next error appears it says that  expected initializer before void function, i've already read in the web and says that maybe i need a semicolon but i cant find where
my code is the next, i would appreciate if you could tell my where my error is.
  //constantes para pines
const int xpin = A0; //pin x
const int ypin = A1; //pin y
const int zpin = A2; //pin z
const unsigned int baud_rate = 9600;
int x; //variable valor x
int y; //variable valor y
int z; //variable valor z
int contador = 0;   //contador de valores
  //valores obtenidos de getval
int valx1;
int valy1;
int valz1;
int constante=415;  //constante para saber el numero que salio
  //diferencias entre constante y valores obtenidos
int dif1;
int dif2;
int dif3;
int numero
  //inicio del serial
void setup() //
  Serial.begin(baud_rate); //
  for(contador=0;contador<2;contador++)
     x = GetValX();
     y = GetValY();
     z = GetValZ();
dxw00d
#1
Apr 30, 2012, 10:13 pm Last Edit: Apr 30, 2012, 10:15 pm by dxw00d Reason: 1
Code: [Select]
int numero
Here?
Please use [code]...[/code] tags when posting code. Use the # button above the text entry box.
CrossRoads
Yes,
int numero
needs a ; at the end.
int numero ;
Didn't the IDE also highlight the line for you, or indicate the line number? (looks like line 19)
kikivick
CrossRoads
Easy to miss.
You'll see those sooner after coding for 6 months 8)
