You're misunderstanding the situation again iyahdub. You're making suggestions to problems that don't exist and making false claims that I'm not doing things I should be doing or vice-verse.
The soldered LEDS...Have u checked the continuity of it all
Of course that isn't a problem because they all light up. Come on man; really?
But unless you are prepared to follow his instructions
I have been.. Obviously. There's an example of you making a false claim again.
Cause look at the amount of pages we been through over such a simple task !!
That's because there is a strange problem somewhere and the correct way to wire it doesn't work. Could be a breadboard issue.. Who knows. That's the reason it's taking a while to figure out. I've already got it working correctly but it is using bizarre wiring. We're trying to figure out
WHY. Come on man. Quit misunderstanding what's going on.
That amount of leds is a bit ridiculous to be honest unless you follow another tested circuit prepared to power all those leds.
Here again is another example of you missing a critical detail that has already been posted. I mentioned already that I only have ~15 of them on at the most at any given time. Do you understand? That means amperage is not an issue. 13.6mA x 15 = 204mA. That is what is being drawn
at most. Come on man, quit making false claims.
Cause this path wont get you anywhere.
What path? You're obviously not paying very close attention to what's going on. We're trying to figure out why the correct wiring won't work and why the "working configuration" that I've been using does work.
Oh is it ?!? OK then, explain me how it worked for NICK and didnt for you ?!? Cause you have a mistake somewhere.
Projects with much less LEDS use Transistors for the sake of proper functioning, and you wanna light a whole neighbourhood with a AA battery...
And still you keep saying that the way you been explained is the wrong way ( but only for you of course cause everyone else sees it is correct).
And NO,m we already figured that it isnt enough powering... NICk done the numbers assuming it will always draw 14 mA, which it wont, as average is 20mA and that would be a expected value( which we know fluctuates). NIck done the number for us, but he also said to you that that was just for the leds, and not the chips, or have you only read what suited you !? So unless you are prepared to rethink your strategy, this aint going anywhere.
Anyway, im not here to argue, or enter into kids type of debates( oh u said i said, you wrong im not).
As i said, i wish you good luck.
Im offski !!
But my advice would be RETHINK YOUR STRATEGY !!
It is your inability to SEE the obvious that doesnt allow us to get anywhere here.
