Loading...
Pages: [1]   Go Down
Author Topic: Call a method during a delay using an if statement  (Read 580 times)
Offline Offline
Newbie
View Profile
Hi Guys,
I want to create a IF statement to run an event if the action is true, for example I have a motor and it spins for a second then has a delay of 60 secs, during that time I want a servo to move but not wait till the 60 secs are over as with a delay, I know you need to use an IF statement, please see attached code for more details.
Cheers
Code:
#include <Servo.h>
int motorPin = 9;  // define the pin the motor is connected to
                    // (if you use pin 9,10,11 or 3you can also control speed)
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int onTime = 1000;  //the number of milliseconds for the motor to turn on for
int offTime = 30000;
int pos = 0;
  * setup() - this function runs once when you turn your Arduino on
  * We set the motors pin to be an output (turning the pin high (+5v) or low (ground) (-))
  * rather than an input (checking whether a pin is high or low)
  pinMode(motorPin, OUTPUT);
  myservo.attach(6);  // attaches the servo on pin 9 to the servo object
  myservo.write(0);
  * loop() - this function will start after setup finishes and then repeat
  * we call a function called motorOnThenOff()
void loop()                     // run over and over again
  motorOnThenOff();
  //motorOnThenOffWithSpeed();
  //motorAcceleration();
  * motorOnThenOff() - turns motor on then off
  * (notice this code is identical to the code we used for
  * the blinking LED)
 void motorOnThenOff(){
   //int offTime2 = 50000; //the number of milliseconds for the motor to turn off for
   digitalWrite(motorPin, HIGH); // turns the motor On
   delay(onTime); // waits for onTime milliseconds
   digitalWrite(motorPin, LOW);  // turns the motor Off
   if (motorPin == 30000)
   {runServo();
    delay(offTime-30000);
else{delay(offTime);}
   //delay(offTime2);    // waits for offTime milliseconds
void runServo()
  for(pos = 0; pos < 90; pos += 90)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(1);                       // waits 15ms for the servo to reach the position
  for(pos = 90; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
  delay(30000);
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
As always, have a look at the blink without delay example for clues of how to avoid using "delay"
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Sr. Member
View Profile
As the delay tutorial explain, u cant really do anything else while the delay is active !
Logged
10 LET Loop=Infinite
20 GO TO 10
South Texas
Offline Offline
God Member
View Profile
You are going to have to create a variable (or 2) and use millis() to assign a value and then write your logic that that starts and stops the motor using those values to determine when it is the proper time.  Look at Blink without delay for how to do it.
Logged
Offline Offline
Newbie
View Profile
Hi Guys,
Looking at the blink without delay, its not making sense can some explain to me please  smiley-mr-green
Logged
Offline Offline
Sr. Member
View Profile
there are already loads of posts explaining it
Logged
20 GO TO 10
Global Moderator
UK
Online Online
Brattain Member
View Profile
The blink without delay example effectively consists of about four lines.
Tell us what you don't understand
Logged
Offline Offline
Newbie
View Profile
An update,
Solved this problem by adding the servo method to the loop and reducing the time it takes on the delay, seems to be working fine now, thanks for the input.
Logged
Pages: [1]   Go Up
Print
Jump to:
