Topic: Reading multiple sensor using visual basic 2008 (Read 5700 times) previous topic - next topic
ram1301
I am trying to read data using 2 sensors from Arduino to Visual Basic 2010. So far i am able to read for 1 sensor using timer in visual basic 2010. If i add reading sensor 2 at timer 2 reading only show at timer 1 and nothing happen at timer 2. What is the problem....? Below are may codes vb and arduino.
Arduino program will send "a" character and arduino will give me the sensor value...if "b" character send to arduino and arduino will give me second sensor value.
Rx = "a"
Tx =  (sensor 1 value)
Rx = "b"
Tx = (sensor 2 value)
This is may code vb2010 :
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick  // timer 1
        Try
            SerialPort1.Write("a") // vb 2010 will send a character to arduino
            System.Threading.Thread.Sleep(250)
            Dim i As Integer = SerialPort1.ReadExisting() //vb 2010 read value from sensor1
            Chart1.Series("Series1").Points.AddY(i)
            Label1.Text = "" + i.ToString()
            Me.Refresh()
        Catch ex As Exception
        End Try
Private Sub Timer2_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer2.Tick // timer 2
     Try
            SerialPort1.Write("b") // vb 2010 send b character to arduino
            Dim i2 As Integer = SerialPort1.ReadExisting() // read value from arduino
            Chart1.Series("Series2").Points.AddY(i2)
            Label1.Text = "" + i2.ToString()
        End Try
Arduino code :
int temp_value;
int rainana_value;
#define SERIESRESISTOR 1000
#define tempsensor 0
#define raingauge 1
    char on_sensor =  'n';
  if(Serial.available()>0)
    on_sensor = Serial.read();
  if (on_sensor=='a')
  temp_value = analogRead(tempsensor);
  temp_value = (5* temp_value * 100)/1024;
Serial.println (temp_value);
else if (on_sensor=='b')
  rainana_value = analogRead(raingauge);
  Serial.println (rainana_value);
Thank you all
PaulS
How come the timer1 tick function includes a Refresh, while the timer2 tick function does not?
Why is the labels showing the number of characters read, instead of something useful, like the characters read? Why are there not two labels?
What are the timer intervals? Try making timer1's interval a lot longer than timer2's interval.
ram1301
Reply :
Timer setting :
Try
            SerialPort1.Open()
            Timer1.Interval = 1000
            Timer1.Enabled = True
            Timer2.Interval = 5000
            Timer2.Enabled = False
        End Try
i put timer setting in connect button. if i press connect button system will connect to com port according to the com setting and start timer 1 and timer 2. actually still trying with timer 2 so still not include Refresh at timer 2. what did you mean labels showing number of characters read...?
can you give some example, tutorial or book using two timers in vb 2010...
thank you for fast reply... :)
PaulS
Without the refresh, how do you know whether the Timer2_Tick function got called, or not?
ram1301
I already add Me.Refresh() at timer 2 and nothing show at label3. By the way label3 use for show second sensor. In my gui label1 show sensor 1 value and label3 show sensor 2 value.
venenoso
Hello,
I am trying to do the same , and using your example/problem I think get something , please give it a try and let me know:
arduino code:
int temp_value;
int wind_value;
#define tempsensor 0  // DEFINE PIN ENTRADA DATO
#define windsensor 1  // DEFINE PIN ENTRADA DATO
  if (on_sensor=='a')
  //temp_value = (5* temp_value * 100)/1024;
  wind_value = analogRead(windsensor);
  Serial.println (wind_value);
I use 2 label , one for temp and second for wind , no buttons , and only one timer set to 1000 milisecons
Visual Basic 2010 code:
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
    Dim i
    Dim i2
    Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
        SerialPort1.Close()
        SerialPort1.PortName = "com3" 'change com port to match your Arduino port
        SerialPort1.BaudRate = 9600
        SerialPort1.DataBits = 8
        SerialPort1.Parity = Parity.None
        SerialPort1.StopBits = StopBits.One
        SerialPort1.Handshake = Handshake.None
        SerialPort1.Encoding = System.Text.Encoding.Default
        Timer1.Start()
    End Sub
    Private Sub Timer1_Tick(sender As System.Object, e As System.EventArgs) Handles Timer1.Tick
        SerialPort1.Open()
        SerialPort1.Write("a") ' vb 2010 will send a character to arduino
        Dim i As Integer = SerialPort1.ReadExisting() 'vb 2010 read value from sensor1
        Label1.Text = i
        SerialPort1.Close()
        SerialPort1.Open()
        SerialPort1.Write("b") ' vb 2010 will send a character to arduino
        Dim i2 As Integer = SerialPort1.ReadExisting() 'vb 2010 read value from sensor1
        Label2.Text = i2
        SerialPort1.Close()
    End Sub
End Class
, please let me know if it works for you or if you found other solution.
Regards
