Offline
Newbie
« on: May 02, 2012, 09:51:00 pm » |
I was wondering how and where would I put the code for PING))) in the code below and how would I wire this to a L298N H-Bridge? int PWM1 = 6; // PWM Pin Motor 1 int PoM1 = 7; // Polarity Pin Motor 1 int PWM2 = 5; // PWm Pin Motor 2 int PoM2 = 4; // Polarity Pin Motor 2
int ValM1 = 0; // Initial Value for PWM Motor 1 int ValM2 = 0; // Initial Value for PWM Motor 2
int i = 25; // increment boolean goUp = true; // Used to detect acceleration or deceleration
void setup() { pinMode(PWM1, OUTPUT); pinMode(PoM1, OUTPUT); pinMode(PWM2, OUTPUT); pinMode(PoM2, OUTPUT); digitalWrite(PoM1, LOW); // Both motors with the sam polarity digitalWrite(PoM2, LOW); analogWrite(PWM1, ValM1); // Stops both motors => ValMx = 0 analogWrite(PWM2, ValM2); Serial.begin(9600); // Used to check value }
// Main program
void loop() { delay (500); // Give time to theh motor to adapt to new value if ((ValM1 < 250) && goUp) // First phase of acceleration { ValM1 = ValM1 + i; // Increase PWM value => Acceleration ValM1 = ValM1 + i; } else { goUp = false; // Accerleration completed ValM1 = ValM1 - i; // Decrease PWM => deceleration ValM2 = ValM2 - i; if (ValM1 < 75) { ValM1 = 0; ValM2 = 0; goUp = true; } } if ((ValM1 > 75) && ((ValM1 < 255))) { analogWrite(PWM1, ValM1); analogWrite(PWM2, ValM2); } Serial.print(ValM1); Serial.print("\t"); Serial.print(ValM2); }
Logged
Global Moderator
UK
Online
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #1 on: May 03, 2012, 03:09:24 am » |
Why do you want to wire a Ping to an H-bridge?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #2 on: May 03, 2012, 03:41:33 am » |
Logged
Offline
Newbie
« Reply #3 on: May 03, 2012, 10:27:55 am » |
@AWOL
I want to attach the Ping))) and L289N to an Arduino board to control two motors.
Logged
Global Moderator
UK
Online
Brattain Member
« Reply #4 on: May 03, 2012, 12:20:37 pm » |
Have you had a look at the Playground?
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #5 on: May 03, 2012, 01:48:50 pm » |
Here's the basic code to use the PING))) The tone is to hook up to a piezo speaker, and it changes pitch based off the distance. I'm not entirely sure what you want to do with it, but if you needed the code, here you go. int tone_freq=0; long duration, inches; pinMode(3, OUTPUT); digitalWrite(3, LOW); delayMicroseconds(2); digitalWrite(3, HIGH); delayMicroseconds(5); digitalWrite(3, LOW); pinMode(3, INPUT); duration = pulseIn(3, HIGH); Serial.print(148, BYTE); Serial.print(duration); inches = (duration/2)/74; Serial.print(137, BYTE); Serial.print(inches); delay(100); tone_freq= inches*100; tone(2,tone_freq);
Logged
SF Bay area
Offline
Full Member
« Reply #6 on: May 03, 2012, 03:25:26 pm » |
I think he meant this http://arduino.cc/en/Tutorial/PingPing != Ping)))
Logged
Offline
Newbie
« Reply #7 on: May 03, 2012, 03:29:50 pm » |
I have searched the internet for about four hours trying to find a good example on how to wire and Arduino Mega, L289N Motor Control, and a Parallax Ping))) all together? I was tired of searching the internet and didn't look on the forum. If you know how or know of a good/great example that shows how and with some code, could you point me in that direction?
Thank you.
P.S. I did wire every but I didn't power it up since I am afraid that I would fry my Mega and I have already did that once.
Logged
Global Moderator
UK
Online
Brattain Member
« Reply #8 on: May 03, 2012, 03:48:02 pm » |
If I have to merge another of your duplicate posts, I'm going to start deleting them.
Logged
Offline
Newbie
« Reply #9 on: May 03, 2012, 03:53:43 pm » |
I was wondering why are you merging them? My first question was about coding and the second question was about wire them altogether.
Logged
Global Moderator
UK
Online
Brattain Member
« Reply #10 on: May 03, 2012, 03:57:31 pm » |
Or, in the first case, both
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #11 on: May 03, 2012, 04:54:03 pm » |
How about a link to the datasheet for this Ping thing?
Logged
