Topic: Help how using Arduino interface (Read 743 times) previous topic - next topic
stiv
Hello to all, I'm new in this forum and I'm a student of Civil Engineering, I'm writing my last elaborate, the graduation thesis.
Sorry for my easy questions but I'm a beginner.
I have to build a IMU platform integrated with a GPS sensor, and a barometer + sensor of temperature for the positioning in-door, for example in galleries and undergrowth.
I have seen a integrate platform with many sensors but I want to assemble many sensors that I choose, linking these to Arduino.
So my question is: does Arduino supports many sensors? Is Arduino input ports serial ports or I2C protocol? So can I link all sensors to Arduino input and then I query these one at a time with the their ID?
An example of sensors that I want to link is this:
Tri-Axis Gyro Breakout - L3G4200D
or this:
9 Degrees of Freedom - Razor IMU
Thanks to any answer.
stiv
Grumpy_Mike
Quote
Well not exactly support but it can be connected to many sensors in many ways.
Perhaps the easiest way to expand the arduino from the basic number of I/Os (input / outputs) is to use the I2C bus. This can support up to 127 devices that could be sensors, or could be port expanders, that is give you more I/Os.
The 1 wire bus is useful for long runs, that is sensors a long way from the arduino. These are mainly temperature sensors.
For high speed connections use the SPI bus.
brunialti
#2
May 09, 2012, 06:58 pm Last Edit: May 09, 2012, 10:39 pm by brunialti Reason: 1
I2C is slower than SPI (10Mbit/s vs 400Kb). but it has the plus of addressing each sensor. Personally I would suggest to use I2C  when you have multiple sensors and small amount of data for each request/poll. SPI is much better for "massive" data transfer as imnage, audio or other data streams. If you use SPI to poll multiple devices you have to handle a minimum protocol to reach any single device.
