Topic: LED won't shut off completely. (Read 3030 times) previous topic - next topic
danieljay
so i followed this LED strip tutorial: http://www.ladyada.net/products/digitalrgbledstrip/index.html
basically I've followed the circuit with the TIP 122 transistor, and I'm trying to fade between 3 led strips. they all work, except one of the strips will not completely turn off. I'm not sure if anyone has some quick suggestions/tips why this might be happening.
the code has been tested and works fine with lower voltage LED's. I've adjusted the circuit to take into an account an external power supply instead of the Arduino power due to low amperage and not enough voltage.
help?
Grumpy_Mike
We need to know what you have done. That tutorial is about an addressable LED strip. You can't dim those with PWM.
danieljay
I've been dimming them with PWM. and have tested a digital write to it. same results.
Jassper
You can dim them, simply give it a lower voltage - but that doesn't mean it is correct.
dc42
The link you posted doesn't mention a TIP122 transistor. Maybe you posted the wrong link?
danieljay
the circuit just asks for power transistors. tip122 would work just as fine. i am setting the voltage to 0, using an analog write function, i.e.
analogWrite(led, 0);
AWOL
is any of this relevant?
We haven't seen your code (hint) so we can't tell.
dc42
I still think you have linked to the wrong page, I can find no reference to power transistors on that one.
MarkT
help?
Might be leakage current in the transistor - does that strip still glow a bit if the TIP122 base is connected to ground?
