Pages: [1] 2   Go Down
Author Topic: Pinout of 328 chip  (Read 859 times)
uk
hi
im learning to lay out a pcb and want to put the atmega328 chip into it, i really just want to be double sure on the pin out of the chip, as ive got it layed out on my board
pin8 +5
pin 9 crystal + cap
pin 10 crystal +cap
pin 20 +5
pin 22 Gnd
pin 21 is this pin i wasnt too sure about is it +5?, i see from some guides connect +5 to it - AREF, what does this pin do?
ok i see its the analog ref pin for max input range 5v.
thank you
« Last Edit: May 01, 2012, 11:10:27 am by jonisonvespa » Logged
Did you make a schematic? If you upload it, it will be a lot easier for us to see if it's okay.
Nope, that pinout is definitely wrong, pin 8 is GND, pin 7 is +5V
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
I always make sure I've had a look at the datasheet before I commit anything to a PC board.
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Or use the Sparkfun library if using Eagle?
Belgium
When I use a bare ATmega328 on a breadboard I use this drawing to see the pins:
http://www.hobbytronics.co.uk/arduino-atmega328-pinout
Very handy because it has the Atmel and Arduino pin numbers on it.
Boston area, metrowest
Or copy an arduino schematic as a starting point, delete the parts you don't need.
http://arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf
uk
thanks very much for the help
Melbourne, Australia
Shannon Member
Lua rocks!
Or this:
That has the pins, the minimal configuration, and the Arduino pin numbers in brackets.
alabama
I really like Adafruit's stickers for breadboarded 328s, http://www.adafruit.com/products/554
When I am working on a prototyping board I will cut one in half lengthwise and reverse the sides to mirror the pins and stick them  on the bottom of the board.
Saves reversing everything in my head.
TomJ
Einstein once said you don't really understand anything until you can explain it to your Grandmother
I think a few corrections are needed:
CTS on the FTDI connector needs to be grounded as well for the FTDI breakout board/cable.
(CP2102 modules don't need the CTS pin.)
Pin6 is DTR.
What's the 10K on the Tx line? That will kill any transmit drive capability.
n0m1 design
I've posted my eagle library here, which has a physical layout corresponding to the chip.
It might be useful: http://n0m1.com/2012/04/30/how-to-bread-board-arduino/
Shannon Member
Lua rocks!
Pin6 is DTR.
I don't know how those ideas got into my head, but I found this once:
http://www.sparkfun.com/datasheets/DevTools/FTDI%20Cable%205V.pdf
That has pin 6 labelled as RTS.
Why would it do that?  Its to protect the pins and allow Arduino pin 0 to be used as an output.
uk
here is my chip layed out whith what i think should be there could someone please verify it please.
thanks
« Last Edit: May 02, 2012, 09:31:32 am by jonisonvespa » Logged
Pages: [1] 2   Go Up
