Topic: Where are the files hex saved after Verify (Read 966 times) previous topic - next topic
okap
Hi Everyone,
I am new in the Arduino world, but I already love it :)
I have installed the software Arduino 1.0-rc2 on Mac OSX 10.6.6 (10.6.8 )
In the instructions that I am following (AVRdude) I need the "Sample_Program" on hex format ( .h or .hex) which should find up upon "Verify" in folder "/tmp" ... unfortunately, I cannot find any file with the name "Sample_Program" etc. I have only "Sample_Program.ino" under folder sketch (sketchbook).
My question is, where does Arduino 1.0-rc2 save it's temporary files, e.i. compiled files (Sample_Program.h, Sample_Program.c, etc) ?
Thank you very much for your help
okap
#2
May 02, 2012, 12:22 am Last Edit: May 02, 2012, 01:10 am by okap Reason: 1
Re: Coding Badly
I dont understand what you mean ...  on OSX ??? ... %TEMP% ... Can you be more specific please, thank you
johnwasser
In Arduino Preferences set "Show verbose output during : [X] compilation [ ] upload"
Then when you verify you will get the verbose output that will tell you where the compile was done.  It will be in the second-to-last line:
Quote
/var/folders/cs/p6yz0z1m8xj9lf0059b_lzw00000gn/T/build8229176203510383123.tmp/Blink.cpp.hex
Binary sketch size: 1026 bytes (of a 32256 byte maximum)
Of course it will be different for each build.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
okap
Thank you very much John, this is exactly what I needed ... THANKS !!!
