Topic: LCD Bitmap - Updated v1.6 (Read 13046 times) previous topic - next topic
teckel
May 02, 2012, 12:41 am Last Edit: Sep 16, 2015, 08:37 pm by teckel
Arduino library that allows you to create a tiny 20x16 pixel bitmap (raster) display on a normally character-only LCD display. Typical drawing functions like line, rectangle, invert, etc. Control right down to the pixel level. Works with both the standard LiquidCrystal library as well as Francisco's New LiquidCrystal library.
Example sketchs are available on the project website and as part of the library download.  Try it out and let me know what you think.  I plan on adding additional features in the near-term.
LCDBitmap Library for Arduino
Here's a sample of it in action:
New in v1.6
BITMAP_RANGE_CHK bug fix.
New in v1.5
4bit method now works without the New LiquidCrystal library (was always supposed to work this way, oversight on my part). Update switch now optional on all functions, defaults to NO_UPDATE.
New in v1.4
Fixed a few problems with the barGraph function. Further optimization with the range checking. Compatible with Arduino 0023.
LCDBitmap Library v1.6 Download
Tim Eckel
My hardware: Arduino, Teensy 2.0, Teensy 3.2 & custom ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My Projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
fm
I need to check this out!
Cheers
teckel
And thanks for the New LiquidCrystal library.  Love it, and a shift register daughterboard for my LCD was my first Arduino hardware project.  The New LiquidCrystal library makes it a piece of cake.
Tim
fm
#3
May 02, 2012, 09:13 am Last Edit: May 02, 2012, 07:51 pm by fm Reason: 1
Glad you liked the library. I need to check out the one you've posted, I liked the video you've posted. I have a project that will surely make good use of it!
Thanks for sharing.
robtillaart
wel done!!
does it also work on a 4x20 display?
just waiting until someone makes (sort of) tetris with this ... (vertical way)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
fm
#5
May 02, 2012, 09:07 pm Last Edit: May 02, 2012, 11:09 pm by fm Reason: 1
Hi, just wanted to make a few comments on the library and the way you use the LCD library.
I've seen that you have multiple constructors for the various LCD, however, if you change:
Code: [Select]
#ifdef _LIQUIDCRYSTAL_SR3W_H_
LCDBitmap(LiquidCrystal_SR3W& lcd, byte bitmap_x, byte bitmap_y);
#else
#ifdef _LIQUIDCRYSTAL_SR2W_
LCDBitmap(LiquidCrystal_SR2W& lcd, byte bitmap_x, byte bitmap_y);
#else
#ifdef _LIQUIDCRYSTAL_SR_
LCDBitmap(LiquidCrystal_SR& lcd, byte bitmap_x, byte bitmap_y);
#else
#ifdef LiquidCrystal_I2C_h
LCDBitmap(LiquidCrystal_I2C& lcd, byte bitmap_x, byte bitmap_y);
#else
LCDBitmap(LiquidCrystal& lcd, byte bitmap_x, byte bitmap_y);
#endif
#endif
#endif
#endif
and use:
Code: [Select]
LCDBitmap ( LCD *lcd, byte bitmap_x, byte bitmap_y);
and in the private section of the class definition you declare:
Code: [Select]
#include "LCD.h"
LCD *_lcd;
Modify the constructor with this:
Code: [Select]
LCDBitmap::LCDBitmap(LCD *lcd, byte x, byte y)
  bitmap_x = x;
  bitmap_y = y;
  _lcd = lcd;
as opposed to use each individual supported library. Your entire code could use the abstract class all the time and would be completely independent of the driver. Additionally you would have to change in your code the "lcd." for the pointer to "_lcd->" but a simple find and replace will do the trick nicely.
This is the nice thing about this library, if you use the LCD abstract class, you don't need to change the code at all to support any of its drivers, just the LCD object creation in your main program.
You would have to use some conditional compilation flags to determine if you are using the stock LiquidCrystal library or the LCD library though.
Your main program and examples would look as follows to support the I2C variant:
Code: [Select]
LiquidCrystal_I2C lcd(0x38);
LCDBitmap bitmap(&lcd, 12, 0);
To support the SR3W variant.
Code: [Select]
LiquidCrystal_SR3W lcd(2, 3, 4);
bperrybap
Tim,
I really like the library but could you check the code into the project repository so
it can be properly tracked and viewed using the SCM tools?
One thing that probably should be high on the list of future improvements
is to use a bit array or maybe even a bitmap buffer vs an array of booleans which take up a byte each.
As is, the library uses up 320 bytes of RAM for the bitmap[][] array
which when combined with the 64 bytes for chr[][] ends up being a large
percentage of the overall RAM on some AVRs.
--- bill
teckel
wel done!!
You tell me ;-)  Seriously, I only have a 2x16 display, so I can only say with authority that it works with 2x16.  With that said, it's not hard-coded to work on a particular display size and should work on all sizes as long as they use the Hitachi HD44780 and each character is 5x8 pixels.  Is that all of them?  I would seriously be surprised if it didn't work on every display with a HD44780 controller.
Tim Eckel
teckel
Thanks fm!  I wasn't aware of using the LCD abstract class which made the code a mess (but functional).  I believe I've implimented your changes and will test them tonight to make sure I got everything correct.  I figured there was a cleaner way of doing it, but lacked the experience to even begin to figure it out.
Thanks again!
fm
You are very welcome, that is one of the nice things about OO programing, not too common around here though. You are doing a very nice job with the library. Very cool.
teckel
Maybe a little outside my experience level.  I believe I have everything turned on in Google Project Hosting.  I'm a software developer, but have never used an online code repository, or even C for at least 25 years.  So, if you'd like me to do something specific, I may need a little hand-holding because this is all new to me.
I just got an Arduino a week or so ago with the purpose of getting my 16 year old son interested in something other than video games (his birthday is today actually).
For sure, that is high on my list.  I actually started the library that way, but figured I'd go the easy route to test the concept first.  Optimization of memory and speed have not been considered at all at this point.  I wanted to get it out there to see if anyone else was interested in something like this first.  If so, then I'd deal with those issues.  I haven't completed the functions either.  Missing are circle, oval, floodfill, etc.
Tim
fm
Quote
Shouldn't he be playing with the board instead of you? ;)
Let me know if it works, my kids seam to have the same video game habit.
teckel
#12
May 03, 2012, 05:41 am Last Edit: May 03, 2012, 05:46 am by teckel Reason: 1
Version 1.1 released
With the help of Francisco Malpartida, the library was cleaned up and now more easily supports either the standard LiquidCrystal library or the New LiquidCrystal library.
The only change to sketches would be to change one line, from:
Code: [Select]
LCDBitmap bitmap(lcd, 12, 0);
to this:
Code: [Select]
Basically, just add "&" to the front of the lcd class.  Let me know if there's any problem, suggestions, etc.
LCDBitmap Library v1.1
Tim
fm
Just downloaded the library and it looks great. Nice job there and thanks for the comments. I have taken it for a spin on my shift register backpack and it is very speedy.
I would do a little bit of range checking to avoid divisions by zero (in the line method) and modify the magic numbers that you have about the code by defines, #define BITMAP_X_SZ  20. Some may have to go into the header file others can remain private in the .cpp.
Being picky and to make the library available to the public, it would be good to comment the code a bit. It would also help people that wish to increase the functionality or improve it.
The last comment is similar to that from bill, but I guess that is already on your radar right now.
It would be good not only to publish the released versions in a zip file in google code but also the code its self. The option you have chosen to manage the source code in the repo is mercurial. If you are interested in seeing what it does and how to work with it, go to this online tutorial http://mercurial.selenic.com/wiki/UnderstandingMercurial, http://mercurial.selenic.com/wiki/Tutorial and if you want to dig in a bit further: http://hgbook.red-bean.com/read/. All of them are very easy to read.
With this, you will be able to synchronize your local repository with that in google code. You will have a repo version on your local machine and another one on google code. If you want me to give you a hand on setting it up, send me an email.
For UI if you are on Windows I recommend tortoisehg, if you are on a Mac: MacHg (very easy to use and intuitive) or SourceTree (ditto). If you are from the old school, you can always use the command line interface.
In a nutshell, I like it very much an excellent compliment for the LCD.
teckel
Range checking was not done to make it faster and smaller.  What I figured is with only 20x16 pixels, it should be kind of hard to get too crazy anyway.  But, if range checking doesn't add much to the code, it would be a simple process to add.
Quote from: fm
I don't exactly follow what you mean by this.  Do you mean don't use 20, 16 and 8, etc. as they repeat in many places but instead use a define instead?  I assume the reason is for memory or speed for micro controllers?  I've spent almost 100% of my programming life on fast servers and mainframes with plenty of memory, so saving a byte or cycle here or there was never a concern.  But, it's obviously very different on this platform.  Tips on saving memory and processing cycles is welcomely received.
Years of being the only programmer on projects had resulted in poor comment skills.  I typically don't add comments unless it's for me to remember how I did something.  It's hard for me to even read code with comments in it.  I typically remove comments from other people's code so I can see what is going on.  With that said, yes, I probably need some comments here and there.
I downloaded and installed tortoisehg last night but haven't had a chance yet to look at it.  I sure hope it doesn't update the code on the site till I tell it to because I'm one to change source 500 times a day, delete entire pieces of code, rewrite it a different way, then erase everything and go back the way it was.
