Hi all before that i am using ADXL345 eval board. Because of the communication problem between the eval board and arduino. I give up on the eval board and change to breakoutboard ADXL335. The before posting is:
http://arduino.cc/forum/index.php/topic,95980.0.htmlNow i can get the reading directly from adxl335 and process it at arduino. Now my project is related on the hand movement control servo motor. I am referring to
http://bildr.org/2011/04/sensing-orientation-with-the-adxl335-arduino/ so that i can figure out what algorithm can be used to act like the movement of the wrist.
Objective:
1. the sensor is placed on wrist. The movement of the wrist is transfer to the Arduino Uno board and process and then send the output to servo motor.
2. 3 servo motors are used to control each axis. (x,y,z)
Here is what i had in my code:
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
Servo myservo1;
Servo myservo2;
const int xPin = 0;
const int yPin = 1;
const int zPin = 2;
//The minimum and maximum values that came from
//the accelerometer while standing still
//You very well may need to change these
int minVal = 262;
int maxVal = 402;
//to hold the caculated values
int x = 0;
int y = 0;
int z = 0;
void setup(){
myservo.attach(9);
myservo1.attach(10);
myservo2.attach(11);
void loop(){
//read the analog values from the accelerometer
int xRead = analogRead(xPin);
int yRead = analogRead(yPin);
int zRead = analogRead(zPin);
//convert read values to degrees -90 to 90 - Needed for atan2
int xAng = map(xRead, minVal, maxVal, -90, 90);
int yAng = map(yRead, minVal, maxVal, -90, 90);
int zAng = map(zRead, minVal, maxVal, -90, 90);
//Caculate 360deg values like so: atan2(-yAng, -zAng)
//atan2 outputs the value of -π to π (radians)
//We are then converting the radians to degrees
x = RAD_TO_DEG * (atan2(-yAng, -zAng) + PI);
y = RAD_TO_DEG * (atan2(-xAng, -zAng) + PI);
z = RAD_TO_DEG * (atan2(-yAng, -xAng) + PI);
//Output the caculations
Serial.print("x: ");
Serial.print(x);
myservo.write(x);
delay(15);
Serial.print(" | y: ");
Serial.print(y);
myservo1.write(y);
delay(15);
Serial.print(" | z: ");
Serial.println(z);
myservo2.write(z);
delay(15);
delay(100);//just here to slow down the serial output - Easier to read
Question:
1. according to the code, converting method to degree can be modified or not?
2. After tested the code with servo motor, the servo motor will move randomly (seem like messy output but it gives no problem in serial monitor)
3. Any1 can advised me how to works on this moving algorithm? many thanks for those who replied. Many thaks
