Topic: LCD I2C Displaying Weird Characters. (Read 3676 times) previous topic - next topic
pasta1234
May 02, 2012, 08:32 am Last Edit: May 02, 2012, 08:56 am by pasta1234 Reason: 1
I am trying to interface my Uno R3 board to this LCD
http://media.nkcelectronics.com/datasheet/LCM1602K3-NSW-BBW.pdf
Using the Example in the Liquid Crystal I2C Library "Hello World" all i get is a bunch of meaningless characters on the screen.
I have checked that the correct pins are connected and that R2 jumper is soldered for I2C comm.
Is their something i am missing ? ? ?
#include <Wire.h>
LiquidCrystal_I2C lcd(0x19,16,2);  // set the LCD address to 0x19 for a 16 chars and 2 line display
  lcd.init();                      // initialize the lcd
  // Print a message to the LCD.
  lcd.backlight();
  lcd.print("Hello, world!");
fm
That library will not support that LCD, if you look at the datasheet it seams to have a custom driver that is not hitachi driver compliant.
Two options:
1. Write your own library to drive the LCD
2. Google one and see if someone has already writen one.
floresta
Not exactly - but the result is the same.  According to the datasheet the board uses a Sunplus SPLC780D controller which, as far as I can tell, is indeed compatible with the HD44780 instruction set.  BUT - there is also a PIC16F690 that is converting the serial input information into commands for the controller chip.  So the library will not support that LCD because that particular PIC interface is not supported by the Liquid Crystal I2C Library.
Don
fm
More than driver, I should have said interface to the LCD. Thanks for the clarification there Don.
pasta1234
What about the library listed on this page for New Haven (LCDi2cNHD) Displays, it seems they also use the PIC 16F690 Interface ?
http://arduino.cc/playground/Code/LCDi2c
Pete
floresta
That's a (very slim) possibility.  The PIC 16F690 is nothing more than a garden variety microprocessor, not unlike the ATmega328 in your Arduino.  It can be programmed to interface the LCD display with any variety of serial communication protocols.  If the commands for the New Haven serial interface happen to match match the commands for your serial interface (not likely) then the library may work.
Don
pasta1234
Considering that, what are my other options for using this LCD using the fewest possible wires ?
Pete
fm
The newhaven display - LCDi2cNHD will most likely work. Looking at the data sheet from NHD (I picked up one at random) from http://www.newhavendisplay.com/specs/NHD-0216K3Z-NSW-BBW.pdf and the one posted have a nice command set matching (including I2C address).
Even the 0xFE command, will most likely work on the NHD since it may not have been documented on their data sheet.
An easy test to do and it would be nice to know if it works.
floresta
You could try using the regular serial interface and the example Arduino code available at the NKCElectronics website.
It certainly is worth a try but be aware that at least some of the New Haven devices use a controller that is largely, but not completely, compatible with the Hitachi.
Don
pasta1234
I tried getting the  LCDi2cNHD Library to work but for some reason it wouldn't even compile, many error messages.
I ended up removing the jumper that i had soldered and implementing the screen using the Serial communication and it worked just fine.
I appreciate your help :)
Pete
