Pages: [1]   Go Down
Author Topic: Weird characters when parsing incoming SMS SM5100B-D  (Read 978 times)
Offline Offline
Newbie
View Profile
Hi guys,
Recently got myself a Uno and a SM5100B-D GSM which i've got successfully calling and hanging up. Done the same with SMS but now i'm wanting to read incoming messages.
I've found a few bits and pieces around and came across this:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1294527225
Code:
/* Cellular shield code, by Phil Gordon http://mrphilipgordon.com
 This code assumes a pull down pushbutton switch attached to pin 9.
 Code expects text in the format x,number1,number2 with number1 being either 1 or 2.
 It will store number2 in a variable depending on number 1.
 Values of variables will be printed on press of pushbutton attached to pin 9
#include <NewSoftSerial.h>         //Include the NewSoftSerial library to send serial commands to the cellular module.
NewSoftSerial cell(2,3);           //Create a 'fake' serial port. Pin 2 is the Rx pin, pin 3 is the Tx pin.
char c = 0;                        //Will hold the incoming character from the Serial Port.
int ATReady = 0;                   //Cellular shield ready
char module1[128];                 //Value for module1
char module2[128];                 //Vue value for module2
int index;                         //Array index
long lastPress = 0;                //For debounce pushbutton
long debounceDelay = 500;          //Delay between represses
  Serial.begin(9600);              //Initialize serial ports for communication.
  cell.begin(9600);
  Serial.println("Starting SM5100B Communication...");
  if(cell.available() >0)           //If a character comes in from the cellular module...
    c=cell.read();                  //Get the character from the cellular serial port.
    Serial.print(c);                //Print that character to serial monitor
    if(c == '+')
      c=cell.read();
      Serial.print(c);
      switch(c)
      case 'S':
        c=cell.read();
        Serial.print(c);
        delay(10);
        c=cell.read();
        Serial.print(c);
        delay(10);
        c=cell.read();
        Serial.print(c);
        delay(10);
        c=cell.read();
        Serial.print(c);
        delay(10);
        c=cell.read();
        Serial.print(c);
        delay(10);
        c=cell.read();
        Serial.print(c);
        switch(c)
        case '3':                                  //Check for initiallisation statud, waiting for command
          Serial.print("\n \rAlmost there...");    //  +SIND: 4
        case '4':
          Serial.print("\n \rNetwork established");
          ATReady=1;
          cell.println("AT+CMGF=1");               //Set message mode to text
          cell.println("AT+CNMI=3,3,0,0");         //Display messages when received
        case '7':
          Serial.print("\n \rSomething b0rked");
          ATReady=0;
      case 'C':
        c=cell.read();
        Serial.print(c);
        delay(10);
        if(c == 'M')
          c=cell.read();
          Serial.print(c);
          delay(10);
          if(c == 'T')
            while(c != 'x')            //Wait untill the character 'x' is displayed
              c=cell.read();
              Serial.print(c);
            c=cell.read();
            Serial.print(c);
            delay(10);
            c=cell.read();
            Serial.print(c);
            switch(c)
            case '1':                  //Run this code if number1 is a 1
              index=0;                 //Reset array index
              c=cell.read();
              Serial.print(c);
              delay(10);
              c=cell.read();
              Serial.print(c);
              while(c != '\r')         //Run loop till end of the line
                module1[index] = c;    //Add character to the array
                c=cell.read();
                Serial.print(c);
                index++;               //Advance array
              module1[index]='\0';     //Terminate array
            case '2':
              index=0;
              c=cell.read();
              Serial.print(c);
              delay(10);
              c=cell.read();
              Serial.print(c);
              while(c != '\r')
                module2[index] = c;
                c=cell.read();
                Serial.print(c);
                index++;
              module2[index]='\0';
  if(Serial.available() >0)              //If a character is coming from the terminal to the Arduino...
    c=Serial.read();                     //Get the character coming from the terminal
    cell.print(c);                       //Send the character to the cellular module.
  if (digitalRead(9) == HIGH && (millis() - lastPress) > debounceDelay)   //stop button repeatedly sending commands.
    lastPress = millis();
    Serial.print("Module1: ");
    Serial.println(module1);
    Serial.print("Module2: ");
    Serial.println(module2);
It works fine, until a message comes in and in the serial window i see
Code:
+CMT: "+642********","+642********","12/05/01,21:00:56+00",4
Test
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Then the ÿ characters keep spamming and eventually freezes up.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
    if(c == '+')
      c=cell.read();
      Serial.print(c);
      switch(c)
      case 'S':
        c=cell.read();
        Serial.print(c);
        delay(10);
        c=cell.read();
        Serial.print(c);
        delay(10);
        c=cell.read();
        Serial.print(c);
        delay(10);
        c=cell.read();
So, if there is at least one character to read, read the first one. If, by chance, it is a '+', read the next one that hasn't arrived yet.
How is that working for you? Never mind, I already know.
Quote
Well, duh. You are reading and printing data that has not arrived yet.
Logged
Offline Offline
Newbie
View Profile
Is there a better way i can handle an incoming message then?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Of course, there is. Figure out what constitutes the start of a packet (most likely the +). Figure out what constitutes the end of a packet (most likely a carriage return or line feed ; possibly two CRs in a row or CR,LF,CR,LF).
Discard data that arrives before the start of packet marker. Store all data that arrives after the start marker, until the end marker arrives. When the end marker arrives, then parse the stored data.
Code:
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   Serial.begin(57600);
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Logged
Global Moderator
Offline Offline
Brattain Member
Lua rocks!
View Profile
WWW
For example: http://www.gammon.com.au/serial
Logged
Offline Offline
Newbie
View Profile
Thanks - I'm new to the Arduino scene so a bit in the deeper end but i have a good knowledge of programming so its more the actual interfacing and how its all handled.
Logged
Pages: [1]   Go Up
Jump to:
