Loading...
Pages: [1]   Go Down
Author Topic: Problem using 2 Ultrasonic sensors together  (Read 429 times)
Cardiff, Wales, UK
Offline Offline
Newbie
View Profile
Im working on a project where the user moves their hand up and down above 2 ultrasonic sensors and a line of LEDs follow your hand up and down. basically, the problem im having means that if you only use one ultrasonic sensor (and get a value back in cm), it subtracts this value from the other sensors value. e.g. you have your hand over the left sensor, but not the right one. as you increase the value of the left sensor, you decrease the value of the right one :S
I've looked at everything and have no idea why this is happening!
My code is too long to post in these forums so i've put it on pastebin: http://pastebin.com/KhDTa7rZ. I'm using an arduino mega. pins 24-53 are the leds. the left and right ultrasonic sensors are attached to 8 & 9, and 10 & 11 respectively.
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Can you see the minimal difference between this
Code:
void right14() {
  digitalWrite (R1, HIGH);
  digitalWrite (R2, HIGH);
  digitalWrite (R3, HIGH);
  digitalWrite (R4, HIGH);
  digitalWrite (R5, HIGH);
  digitalWrite (R6, HIGH);
  digitalWrite (R7, HIGH);
  digitalWrite (R8, HIGH);
  digitalWrite (R9, HIGH);
  digitalWrite (R10, HIGH);
  digitalWrite (R11, HIGH);
  digitalWrite (R12, HIGH);
  digitalWrite (R13, HIGH);
  digitalWrite (R14, HIGH);
  digitalWrite (R15, LOW);
and this
Code:
void right15() {
  digitalWrite (R15, HIGH);}
If you spent a little time refactoring your code, it might make spotting your problem a lot easier.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
The snippet that AWOL posted just screams for arrays. Perhaps, then, your code wouldn't be so long that it couldn't be posted.
If you strip away all the stuff NOT involved with reading the ultrasonic sensors, what do your serial print statements tell you is happening?
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
I just took another look - the code is around 600 (+/- 100) lines too long.
Remember, computers, even teeny-weeny ones like Arduinos, are really good at repetition.
But yes, the serial prints will tell all.
My guess is that the second sensor is picking up a return from the first.
A good long delay of, say 50 ms, between the two will tell you.
« Last Edit: May 14, 2012, 06:56:38 am by AWOL » Logged
Offline Offline
Sr. Member
View Profile
I did not look at your code but the first think I thought of was you may have been trying to read both sensor at the same time or close enough together at the signals were interfering.
Just a thought.
Logged
Cardiff, Wales, UK
Offline Offline
Newbie
View Profile
I've just stuck a delay in and it has solved the problem perfectly! smiley its so obvious i'm kicking myself! smiley-razz cheers guys! smiley
so...umm..how do I make this smaller?
Code:
void right14() {
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Stick all the pin numbers (and ranges) into an array, and use a for loop (or two).
I think you'll be able to get your entire sketch under 100 lines.
Quote
Don't be hard on yourself - it isn't all that obvious - we expect the results returned by a sensor to relate to only that sensor, but sound travels a long way, very slowly.
« Last Edit: May 14, 2012, 08:38:02 am by AWOL » Logged
California
Offline Offline
Edison Member
View Profile
Quote
Code:
void right14() {
  for (short i=R1; i<R15; i++)
    digitalWrite (i, HIGH);
Works fine as long as the RXX are sequential.
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
...which is why arrays are such a good idea.
"right14" and all its siblings shouldn't be there anyway.
Logged
Offline Offline
Sr. Member
View Profile
I'm just glad to see that I am not the only one that makes these sorts of simple mistake.  We can sometimes get "tunnel vision" and focus our attention in the wrong places.  I sometimes help to have a second pair of eyes on the problem.  Especially a pair that does know know enough to have preconceptions.
As soon as read the title, I wondered it they were being used "together" and getting interference.
Logged
Pages: [1]   Go Up
Print
Jump to:
