Loading...
Pages: 1 [2]   Go Down
Author Topic: auto reset during the loop()  (Read 826 times)
Offline Offline
Newbie
View Profile
I am giving the code because there are errors:
Code:
int rechercheUtilisateur(char numUtilisateur[TAILLE_NUM_UTI]){
    int i, ligne = 1;
    //declaration des tableaux locaux
    char numString[TAILLE_NUM_UTI];
    //place le pointeur au debut du fichier
    myFile.seek(0);
    //recupére le numéro d'identifiant de la ligne
    for(i=0; i<TAILLE_NUM_UTI-1; i++) numString[i]=myFile.read();
    numString[i]='\0';
    while(strcmp(numUtilisateur, numString)){
        if(!sautDeLigne()){
          myFile.seek(0);
          return 0;
        ligne++;
        //met dans 'numString' le numéro d'identifiant de la ligne
        for(i=0; i<TAILLE_NUM_UTI-1; i++){
        numString[i]='\0';
    //place le pointeur au debut de la ligne
    myFile.seek(myFile.position()-TAILLE_NUM_UTI);
    return ligne;
TAILLE_NUM_UTI is defined in the beginning of the code:
Code:
#define TAILLE_NUM_UTI 8+1
Do you want the entire program?
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Yes, please give us the whole program and also tell us what's in the file you're reading in.
Logged
Germany
Offline Offline
Edison Member
View Profile
BTW:
Code:
is dangererous:
int x = TAILLE_NUM*4; // x = 12 !!!
better say
#define TAILLE_NUM_UTI (8+1)
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
strcmp() returns 0 if the strings match, or -1 or +1 if they don't match, depending on whether string 1 comes before or after string 2. It does NOT return a boolean, so this code should not be written as though it does. Explicitly state what you are expecting.
Code:
Suppose you read past the end of the file. Then what happens?
Some Serial.print()s in this code will tell you where you are going wrong. Why are there none?
Logged
Offline Offline
Newbie
View Profile
I've watched with Serial.println () but that the reset occurs at different times if I change the code.
Code:
I normally can not to be at the end of the file, I read the first 8 characters of a great line.
Logged
Canada
Offline Offline
Full Member
Code Monkey
View Profile
WWW
Quote
Code:
What if your file contains less than 8 bytes?
You really ought to be checking for unexpected results from read().
« Last Edit: May 14, 2012, 11:55:41 am by The Clever Monkey » Logged
I yield() for co-routines.
Pages: 1 [2]   Go Up
Print
Jump to:
