Author Topic: Always been a 328p guy, now what about the 2560?  (Read 470 times)
Wisconsin
I LOVE THIS STUFF!!!!
Hello,
So I've always worked with the ATmega328p and I have put it on a breadboard and uploaded sketches and such that way.
I want to know if the ATmega2560 is generally the same deal?  Obviously it doesn't come in a DIP package, but how would I upload sketches to it if I were solder the 2560 onto a breakout or a circuit board?  Is it the same with the TX and RX?
BONUS: I need help setting up a usb or serial connection or w/e, so if anybody has any resources on adding that ability to upload sketches from the usb to the microcontroller, that would be great!
Accelerate to 88 miles per hour.
Melbourne, Australia
Shannon Member
Lua rocks!
If it had a bootloader you could use Tx and Rx along with an FTDI cable. Or you could wire up the ISCP interface to the SPI pins. Or both, in case you needed to use ICSP to put the bootloader there in the first place.
Wisconsin
Okay I think I get what you are saying.
Lemme put it this way, say its set up like this
http://arduino.cc/en/uploads/Tutorial/ArduinoUSBSerial.png
Only the thing on the breadboard is the mega2560.  Could I do the same dealio?
Shannon Member
Lua rocks!
Yes I presume (apart from the difficulty of doing that with the SMD chip). But it would need the bootloader on the chip. A "raw" chip might not come with it.
Wisconsin
Can't I just do the same process on getting the ATmega2560 bootloader on there as I would an ATmega328P, other than selecting the proper bootloader?
Shannon Member
Lua rocks!
What process would that be? When you select "burn bootloader" it needs an external programmer.
The bootloader uses data from the serial ports (Tx, Rx) to modify the sketch in flash memory. It can't replace itself.
And even if it could, on a raw chip from the manufacturer the bootloader is not there anyway.
On the diagram you linked to are only connections to the serial ports. Burning a bootloader requires either a high-voltage programmer like the AVR Dragon, or a programmer that connects to the SPI pins: MOSI/MISO/SCK and RESET. The methods for burning a bootloader are built into the chip, but they have to be done using SPI or high-voltage programming.
It's no big deal, you may as well add the pins needed for that, you would need them anyway to run any sort of SPI device.
SE USA
@ssh0le
you can use a pre existing 168/328 setup as a SPI programmer, its 4 wires (not counting +5 and ground) and not rocket science, hell its an example in the IDE since post .18
your biggest issue is soldering down that high pitch, high pin count part and coming up with a board for it
for the price and effort you might as well just get a mega, here is a cheap one
http://arduino.cc/forum/index.php/topic,102760.0.html
I got one, its slow boating its way from china, but cr0sh likes it
Wisconsin
Well I would need a development board although I really want to use the 2560 elsewhere, using the arduino bootloader.
South England
http://jkdevices.com/arduino-megamini
Sounds like you need something like this!
Wisconsin
ehhh, looks great although I think i'll just get the mega clone.
I can solder those pitches fine its just developing it.
I think i'd rather pay for the entire development board for $32.99 rather than the breakout for $45+
As Nick pointed out..
this:
is not the diagram for flashing the bootloader..
that is for using your Arduino as a passive/pass-through FTDI type device to get/upload your sketches 'through' the Arduino to the target chip/circuit on the breadboard.
For bootloading you use
RESET
D10
D11
D12
D13
(SPI bus)
and you leave your Atmega328 chip in the Arduino (where as you take it out for pass-through sketch uploading)
Wisconsin
Yes, I've done that before.
I may have mistyped but I was wondering if that was the set up for uploading sketches.
