Pages: 1 [2]   Go Down
Author Topic: Rc Receiver to a variable  (Read 639 times)
UK
No, simply pass the output of pulse in into map.
Seattle, WA USA
Seattle, WA USA
The stream between Tx and Rx is PPM, but once the stream is past the demultiplexer and on its way to the servo or ESC, it's PWM.
Get over it.
I did.
Then, how is it that servos can be connected to other than PWM pins, and still operate. The Servo library is not doing soft-PWM, is it?
UK
Just because the Servo library doesn't do 490Hz 0-100% PWM doesn't make it any less PWM.
The position of the servo or speed of the ESC (which may itself output a different frequency and duty cycle PWM) is proportional to the width of the pulse, hence Pulse Width Modulation.
Would you mind giving some example code?
UK
int servoAngle = map ( pulseIn (rxPin, HIGH), 540, 2400, 0, 180);
Of course, you may have to play with the constants.
Even do some preprocessing, but, as I said, that's the gist.
Pages: 1 [2]   Go Up
