Topic: advice needed for arduino as diesel injection brain... (Read 21149 times) previous topic - next topic
japie
@cyclegadget
Thanks for pin4, didn't see that. (but they where fictional)
@wildbill
I know it is not threaded and that is why I am concerned.
Main issue is that I want a calculated injection moment, the only stable factor is the end of the injection in degrees. (so in time dependable on rpm)
To make live easier when mounting/adjusting I like the distributor to give a pulse at TBP since that is the only position of my engine I can monitor. (with head in place)
So with cylinder 1 at TDP I have a starting point for injecting cylinder 3 (order 1342)
I have a time interval in us between 2 interrupts so I can calculate delays but main thing is that the interrupt triggers actions with delays where the end of that cycle can be after the next interrupt is triggered. (due to revving up)
I don't see a software solution, only thing I can do is mounting the distributor to the throttle cable and let  the interrupt trigger injection without delay.
cyclegadget
I wrote some code just to give you a place to start. It is not working code but, I think I wrote enough to give you an idea how to remove your delays.
Code: [Select]
// Variables will change:
int InjectorState1 = LOW;  // the state of the injector1
unsigned long previousMicros = 0;
  unsigned long currentmicros = micros();
int inject1()
  //////////////////////////////////////////////////I don't know what you are doing here
  // find out how many uS 90 degrees camshaft is
  TimeFrame = (micros() - TimeOld);
  TimeOld = TimeFrame;
  Delay = InjectionDelay - ThrottleDuration;
  ////////////////////////////////////////////////this below can work without delay
   static int done = 0;  // this variable will show when the inject1() function is complete. 0 = not complete, 1 = complete
  // open injector, hold it and close
     if (InjectorState1 == LOW)
      digitalWrite(inj1,HIGH);   //open the injector
      previousmicros = currentmicros;  // save the time the injector was opened
      InjectorState1 = HIGH;   // set the injectorState to HIGH
     // If the injector is open and it is time to close the injector do so.
     if(currentmicros - previousmicros > Delay && InjectorState1 == HIGH)
      digitalWrite(inj1, LOW);  // close the injector
      InjectorState1 = LOW;    // reset the injectorState to LOW
      done = 1; // injection cycle is complete
     return done;  // return 0 or 1 to show if function has both opened and closed injector.
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
japie
#32
Jan 28, 2013, 07:23 am Last Edit: Jan 28, 2013, 07:31 am by japie Reason: 1
Thanks, I understand this way of handling.
Instead of putting waits in the interrupt you used a compare to see if it is time to close, but does this change behavior when 2 interrupts overlap each other?
I attached an image to explain the situation:
Each injection has 3 values: delay_from_tdp, injection_duration and remaining_time_to_next_tdp
When rpm is steady the green time is free time for the uC but when revving up it can happen that the next interrupt trigger is before that free time so it is triggered when the previous interrupt function is still running.
That don't have to be a problem since during injection there is no action, only a wait time so the start of the next cycle/interrupt can only add a couple of cpu cycles to the injection time.
Main thing I am afraid of is that if an interrupt function is not yet finished the next won't start or the first is not closed due to the overlap, that is why I was asking about the bash & solution. (free the interrupt while the injection cycle remains running)
cyclegadget
I haven't had much practice using interrupts() so my sketch may have issues. In this sketch, the interrupt sets a flag to true. The function then runs only if the flag is set. The interrupt is done the moment the flag is set. The inject function resets the flag from "true" to "false" so that it can be set again on the next interrupt.
Each injector has it's own flag and will have it's own function.
The code is mostly written for the cylinder1. You will need to review it and see if it can be used for the rest of the cylinders.
Code: [Select]
// setup pin for throttle potentiometer:
int ThrottlePin = A0;
unsigned long ThrottleValue = 0;
unsigned long ThrottleDuration = 0;
// base idle injectiontime is 100uS
unsigned long IdleDuration = 100;
// define throttle calibration values:
// we like to inject from -45 to -10 TDP making 35 degree injection duration max.
// crank duration in uS: (1000000/(rpm/60))/360*35
// at 10K rpm that is 583uS since the throttle has 1023 steps 1023/583=1.75
float ThrottleCalib = 1.75;
// define injection delay
unsigned long InjectionDelay = 0;
// define microsecond timeframe between 2 injects = duration 90 degree camshaft/ 180 degree crankshaft
unsigned long TimeFrame = 0;
unsigned long TimeOld = 0;
unsigned long Delay = 0;
unsigned long currentmicros = 0;
int cyl1 = 1;
int cyl2 = 2;
int cyl3 = 3;
int cyl4 = 4;
// setup pins for injector drivers:
int inj1 = 4;
int inj2 = 5;
int inj3 = 6;
int inj4 = 7;
volatile int state1 = LOW; ///////////////////Flags to determine if injection functions should run
volatile int state2 = LOW;
volatile int state3 = LOW;
volatile int state4 = LOW;
volatile int Fuel1  = false;
volatile int Fuel2  = false;
volatile int Fuel3  = false;
volatile int Fuel4  = false;
  // initialize the digital injector pins as an output:
  pinMode(inj1, OUTPUT);
  pinMode(inj2, OUTPUT);
  pinMode(inj3, OUTPUT);
  pinMode(inj4, OUTPUT);
  // attach action when interrupt gets actived:
  pinMode(cyl1, INPUT);
  attachInterrupt(1, Fire1, RISING);
  pinMode(cyl2, INPUT);
  attachInterrupt(2, Fire2, RISING);
  pinMode(cyl3, INPUT);
  attachInterrupt(3, Fire3, RISING);
  pinMode(cyl4, INPUT);
  attachInterrupt(4, Fire4, RISING);
  /////////////////////////////check interupts////////////
  digitalWrite(cyl1, state1); // runs function called Fire1
  digitalWrite(cyl2, state2);  // runs function called Fire2
  digitalWrite(cyl3, state3);  // runs function called Fire3
  digitalWrite(cyl4, state4);  // runs function called Fire4
  /////////////////////////if the flag is true start the inject function/////////////
  if (Fuel1 == true)       // START THE FUNCTION IF FLAG IS SET
    inject1();
////////////////////////////Flag setting functions///////////////
void Fire1()
  Fuel1 = true;
void Fire2()
  Fuel2 = true;
void Fire3()
  Fuel3 = true;
void Fire4()
  Fuel4 = true;
//////////////////////////////////////injection function for cyl one
int inject1()
  Fuel1 = false; //reset the flag that was caused by the interrupt
    previousMicros = currentmicros;  // save the time the injector was opened
    done = 0;                // injection cycle is NOT complete
  if(currentmicros - previousMicros > Delay && InjectorState1 == HIGH)
japie
OK cyclegadget, that is clear:
The interrupt sets a flag, inside a loop the flag is detected and an injection subroutine for that flag is called.
One advantage of that approach is that I have to concentrate to make the loop as fast as possible since reading ADC and doing calculations in that loop could disturb injection start. (so it is more clear how many cpu cycles things use)
It does however raise another question (which also exist with any other approach), when the inject1 routine is called from within the loop what happens with the loop itself?
If if(currentmicros - previousMicros > Delay && InjectorState1 == HIGH) is running will the loop be stalled until Delay matches the micros calculation or will it keep running during every free cpu cycle?
cyclegadget
Quote
It would have been better if the variable called "Delay" would be the words "on-time-needed" .  Basically, it is like you look at your wrist watch noting the time as you turn the injector turn on, next you walk off to do other things and when the time has elapsed, you stop long enough to turn the injector off then, you go back to doing other things.
japie
Clear!
Before writing final code I will add timings to every part of my main loop to see how much time is consumed on every part, based on that information I will create something final.
Thanks for your help, I will post again if I have something working and on every step I take for the record. (calibrating injectors and timings)
cyclegadget
  I think you are on the right track and your project is very doable. I can wait to see your progress. I will help as much as I can.
japie
#38
Feb 15, 2013, 08:02 pm Last Edit: Feb 15, 2013, 08:05 pm by japie Reason: 1
Hello cyclegadget,
The parts for the injector and pump driver print are ordered so next week I can start with building the hardware.
Did some coding last week based on your idea, do have a question about it:
In the injection function you use done=0; and done=1; and at the end return done; why is that, for usage in messages when serial prints are added?
I did change things a bit, I moved time reading stuff directly into the interrupt function to make it more accurate.
Also I changed the way U used time based checks for start and stop injecting to add a "delay" before start injecting and to make it a bit more clear on when things are happening.
Code: [Select]
 Cuprum-2.0 simplified 1-3-4-2 cylinder common rail injection system for Arduino Mega.
 Using interrupts for timing injections cycle, a timing disc (alternator) is mounted to camshaft.
 Throttle position is read from potentiometer.
 Pump pressure is bound to throttle position.
 Base rule for the system is that we want all fuel injected at 10 crank degree before TDP:
 - cylinder 2 gives pulse for cylinder 1
 - wait (180 degree at current rpm) - injection time (max 35 degree) - injection advance (10 degree at current rpm)
 - inject
 Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground, output will be 0-1023
 Attach timing signals to external interrupts: cyl1 pin 3, cyl2 pin 21, cyl3 pin 20 and cyl4 pin 19
 Attach injector drivers: cyl1 pin 2, cyl2 pin 4, cyl3 pin 6 and cyl4 pin 8
 Attach pump pressure to PWM pin 13
// base idle injectiontime is 50uS
unsigned long IdleDuration = 50;
// define microsecond timeframe between 2 injects = duration 180 degree crankshaft
// define injection cycle times
unsigned long InjectionAdvance = 0;
unsigned long InjectionDuration = 0;
// state of injectors
int InjectorState2 = LOW;
int InjectorState3 = LOW;
int InjectorState4 = LOW;
// injection start times
unsigned long start1micros = 0;
unsigned long start2micros = 0;
unsigned long start3micros = 0;
unsigned long start4micros = 0;
// setup timer pins for interrupts:
int cyl1 = 1;
int cyl2 = 2;
int cyl3 = 3;
int cyl4 = 4;
volatile int state = LOW;
int inj1 = 2;
int inj2 = 4;
int inj3 = 6;
int inj4 = 8;
// injection functions flags
 // check interupts
 // read throttle position
 throttle();
 // if the flag is true start the inject function
 if (Fuel1 == true)
   inject1();
 if (Fuel2 == true)
   inject2();
 if (Fuel3 == true)
   inject3();
 if (Fuel4 == true)
   inject4();
// set flags
void Fire1()
 // set flag
 Fuel1 = true;
 // set start time
 start1micros = micros();
 // calculate how many uS 180 degrees last
void Fire2()
 // set flag
 Fuel2 = true;
 // set start time
 start2micros = micros();
void Fire3()
 // set flag
 Fuel3 = true;
 // set start time
 start3micros = micros();
void Fire4()
 // set flag
 Fuel4 = true;
 // set start time
 start4micros = micros();
// throttle reading
int throttle()
 // read the throttle input on analog pin 0:
 ThrottleValue = analogRead(ThrottlePin);
 // see if we are trying to have fun :-)
 if (ThrottleValue > 5)
   // injection ends uS/360*350 to make sure all juice is injected 10 degree before TDP.
   InjectionAdvance = TimeFrame/360*10;
   // recalculate throttle value to wanted microseconds:
   InjectionDuration = ThrottleValue/ThrottleCalib;
 // it seems we are idling :-(
   // make sure all juice is injected at TDP.
    // if we are running 900rpm (33333uS) we reduce injection time
   if (TimeFrame > 33333)
     // reduce injection time
     IdleDuration=IdleDuration-5;
     InjectionDuration = IdleDuration;
   // if we are running 800rpm (37500uS) we inject a bit longer
   else if (TimeFrame < 37500)
     // expand injection time
     IdleDuration=IdleDuration+5;
int inject1()
 // read time
 // reset the flag that was caused by the interrupt
 Fuel1 = false;
 // this variable will show when the inject() function is complete. 0 = not complete, 1 = complete
 // if the injector is closed see if it is time to open
 if(currentmicros - start1micros > (TimeFrame - (InjectionAdvance + InjectionDuration)) && InjectorState1 == LOW)
   done = 0;
 if(currentmicros - start1micros > (TimeFrame - InjectionAdvance) && InjectorState1 == HIGH)
   done = 1;
 return done;
int inject2()
int inject3()
int inject4()
cyclegadget
Returns are the method to transfer variables from functions to the rest of the loop. It is easier for me to write a sketch to show how a return works so, hopefully you will see it in this sketch. Watch the led13 and use the serial monitor.
Code: [Select]
const int ledPin =  13;      // the number of the LED pin
int done = 0;
long previousMillis = 0;        // will store last time LED was updated
long interval = 1200;           // interval at which to blink (milliseconds)
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  if(currentMillis - previousMillis > interval)
    // save the last time you blinked the LED
    whatdonedoes();
    Serial.print("done = ");
    Serial.println(done);
    digitalWrite(ledPin, done);
////////////////////////////////function with a return called done//////////
int whatdonedoes()
  // if the LED is off turn it on and vice-versa:
  if (done == 1)
    done = 0;
    done = 1;
  return done;
cyclegadget
  I think your sketch has a few problems. I need to think it over how to solve them. I recommend starting your sketch as basic as possible. Use 1 button for 1 interupt, use the led13 to simulate an injector, set the time of injection for 1 to 3 seconds range, lastly you can use 1 pot for a throttle simulator. Get the led working as expected then add more leds for injectors.
The larger the code is, the harder it is to work out problems.
cyclegadget
In this part of your sketch,  (start1micros, TimeFrame, and TimeOld all equal the same micros. You can write a sketch that prints the values and you will see that.
Code: [Select]
void Fire1()
  // set flag
  Fuel1 = true;
  // set start time
cyclegadget
This function needs some time spent on it. The if(currentmicros.......... statements need checked. Using a piece of paper, put numbers in for the variables and ask yourself if the (if) function will result in true or false. Check both if statements using the same values then, values that represent a change in time.
Code: [Select]
int inject1()
  // read time
    Fuel1 = false;
I made some changes in the code. I made it more simple with just one injector in the loop and functions. It is still not correct and may not compile maybe it will help. I getting tired so, I need to stop where I am at.
Code: [Select]
int cyl1 = 1;
int cyl2 = 2;
int cyl3 = 3;
int cyl4 = 4;
int inj1 = 2;
int inj2 = 4;
int inj3 = 6;
int inj4 = 8;
  // check interupts
  throttle();
  if (Fuel1 == true)
    inject1();
/////////////////////////////////////////////////////functions below////////////
// set flags
void Fire1()
  // set flag
  Fuel1 = true;
  // set start time
int inject1()
  // read time
    Fuel1 = false;
// throttle reading
int throttle()
japie
Hello cyclegadget, don't make it to late... ;-)
I understand the done thing, but when going for a first dry run I will add serial prints with micros at every step and dump them into a file so I can review afterwards to see how much time is spent on every step. (suppose reading/calculating throttle takes to long I can try to strip that down)
And yes I will go for one cylinder at first step.
Code: [Select]
void Fire1()
  // set flag
  Fuel1 = true;
  // set start time
  TimeFrame = (start1micros - TimeOld);
The TimeFrame and TimeOld are common values shared between all 4 interrupts since TimeFrame is the time in uS for 180 degree crank. (did clean it up in above, no need for double  read micros(); )
So those may look equal but when looking at more then 1 interrupt/cylinder they are not. (I think ;)
Code: [Select]
currentmicros minus start1micros gives me elapsed time since the interrupt.
TimeFrame (180) minus (InjectionDuration (35) plus InjectionAdvance (10)) gives me the "wait time" from interrupt to start_injecting.
Code: [Select]
if(currentmicros - start1micros > (TimeFrame (180) - InjectionAdvance (10)) && InjectorState1 == HIGH)
TimeFrame minus InjectionAdvance gives the wait_time for stop_injecting.
I really appreciate your help, I am not a coder, give me a piece of aluminum and a lathe and I can make art but besides some bash scripting I am not that good...
Thank you for helping me out!
PeterH
Given that the sketch was written to demonstrate the use of return, it's ironic that your sketch ignores the return value.
