Poll
Question: usb port problems
howe to solve - 0 (0%)
how it hapens - 3 (100%)
Total Voters: 3
Author Topic: avrdude: stk500_getsync(): not in sync: resp=0x30  (Read 1924 times)
Hello,
I don't is topic about egsist or not but I run with error "avrdude: stk500_getsync(): not in sync: resp=0x30". And about it can't find good info how to solve it. So I making a topic about it.
I solve this error finaly (I hope) reinstaling arduino and its driver. I using windows 7 64bits.
If some knows the better way for this error please write. Becose I believe he comes back. And changing ports not solution.
Hapen again. What i should do please help. Can't use my arduino.
I´ve gotten the same problem, i got my arduino uno, a week ago, so here my experience so far:
1)  I never got the green led to turn on when connect arduino to my macbook pro.
2) tx led nor rx led blink, when trying to upload a sketch
3) after trying to upload any sketch, i get this message: avrdude: stk500_getsync(): not in sync: resp=0x00
I dunno if im doing anything wrong, so far ive follow step by step number of posts in forums and websites, but still not working
if its not broken, dont fix it, instead open it and look how it works
Holland
Troubles are there to be solved!
is the atmega chip insert correctly? (does the mark on the chip match the mark on the DIP-packet)
is this a problem wich happens all the time or is it just randomly and works just fine..?
just asking so people have a better view on the problem..
humankind cannot obtain anything without
sacrificing something of equal value.
this happens everytime i try to upload a sketch, also tried to keep the reset button pressed before, during, after upload the sketch
well, here´s some update of the issue:
I tried to load sketches on windows XP, it didnt work...
I also tried using a different USB cable, I think the usb cables i have are working fine, so the problem must be somewhere else
the chip is correctly inserted
the problem happens everytime I connect arduino to my macbook pro, I ve been able to load a sketch properly in very few times
any help?
can´t even upload the blink sketch, really frustratting!!!!!!!!!
I managed to upload a modified blink sketch:
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
  delay(500);              // wait for a second
so the time the led is off its half of the on time (nothing impressive); the first time i did it, it worked fine, so I tried to again, but this time it didnt work and instead I got that annoying message:
"avrdude: stk500_recv(): programmer is not responding"
Is there any cause im not considering in the process?
IS this  normal in Arduino? i mean this unstability, sometimes works, some other times doesnt....
looks like the way to "solve" it is to press the reset button at the precise moment (which is frustrating task to do) in order to load a sketch....
anyone has found a different (actually working) solution?
This solution worked for my UNO on Windows 7 64-bit.
Thanks! Ill try tonight at home, and keep posted!
i tried to do something similar to this last indication, but honestly it was imposible to follow the instructions since they are meant for win7.... not mac which is my case
so again: any ideas about how to solve this in mac?
I got this message the first time I tried to use my uno it turned out that I was using the wrong com port I changed the com port and it worked. I don't know if this will work for someone else I just know that is what was wrong with mine when I got that same error message
avrdude: stk500_getsync(): not in sync: resp=0x30 I realize that this is an old post and these problems have probably been solved but this might help someone else like me who came here and there was no solution there is one now thank you Tom.
