Loading...
Pages: [1]   Go Down
Author Topic: Atmega 328 vs 328P Problem  (Read 622 times)
Offline Offline
Jr. Member
View Profile
Does anyone know if there is some difference between the 328 and the 328p that will affect Serial.print?
I made my own Nano board and I guess I ordered 328 instead of 328P. I only found that out when bootloading with AVRISP and AVR Studio reports. I loaded the Optiboot Boot loader. It runs the Blink sketch no problem but when I add a Serial.Print command, it just prints garbage.
When I do the same with my original Nano, it prints fine.
Any help or input would be appreciated. Sorry I am a noob who may be doing something wrong.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Does your board use a resonator or crystal?
What values did you use for the fuses?
Logged
Offline Offline
Edison Member
View Profile
The 'P' is for PicoPower.
It uses less power. But Serial.print should be just the same.
Logged
Offline Offline
Jr. Member
View Profile
I used a ceramic resonator 16MHz. In the eagle files from Gravitech it says resonator. It looks identical to the one on the original board. Do you think it needs to be a crystal?
I did not change the fuse bits.
Sorry i am a hardware guy and this is a little new for me.
Logged
Offline Offline
Edison Member
View Profile
At 16MHz, I would prefer a crystal.
The fuses are different for resonators or crystals (not always).
Logged
France
Offline Offline
Sr. Member
View Profile
Could your clock frequency be off?  Make a blink sketch with a really long delay, like 20 minutes, and time it with a stopwatch as accurately as you can.  An error of <4% is usually ok, but tolerances vary.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
No.
Quote
From the factory, the processor is configured to run at 1 MHz using the internal oscillator.  If you did not change the fuses then it is still configured to run that way.
Do you have another board?  Like an Arduino Uno?  If you do, use OptiLoader to install the bootloader.  It handles all the details including correctly setting the fuses.
I agree with @tim7.  A timing test may help determine what's wrong.  (other than the 20 minutes; 15 to 30 seconds is adequate)
« Last Edit: May 04, 2012, 07:10:03 pm by Coding Badly » Logged
Offline Offline
Jr. Member
View Profile
I tried Optiloader earlier today and now again. Cannot get it to work. I cannot tell if it is programming the board or not as nothing is on the serial monitor. But when I use the programmed board and try to load a sketch, I get an Avrdude error. These problems led me to buy  the avrisp this morning and I am able to burn the bootloader with it. Do you know what the fuse bits should be set to?
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
https://github.com/arduino/Arduino/blob/master/hardware/arduino/boards.txt#L3
Logged
Offline Offline
Jr. Member
View Profile
Thank you
Those settings worked with the ATmegaBOOT_168_atmega328.hex but not with the Optiboot file.
thank you, she now speaks English.
Logged
Pages: [1]   Go Up
Print
Jump to:
