Topic: More than two PWM output in Arduino Pro mini ? (Read 9431 times) previous topic - next topic
mr_genius
Hi everyone
I am using 4 servo motors for my project and using an arduino pro mini. I am using Pin 9 and 10 for PWM function, and I need to connect other two motors to be able to use the PWM library function to write to the Servos. Is there any simple way to do thi s? How many different ways could I make my other two servo motors run. Arduino Pro mini have only 2 pins that uses pwm library. So how can i overcome this problem ?  I want to connect and use other two motors to be able to use pwm function, where should i connect it ?
DuaneB
Can't you just use the servo library, see here-
http://rcarduino.blogspot.com/2012/01/can-i-control-more-than-x-servos-with.html
Also checkout the two links in my signature regarding powering your servos
Duane B
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
mr_genius
You can Run the Servos but you cannot write it. According to Servo library in arduino main page it says - The Servo library supports up to 12 motors on most Arduino boards and 48 on the Arduino Mega. On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins.
And I need to use that functionality of writing on to two other motors as well. I have heard of using a motor controller, but i dont know which one to use
DuaneB
I don't think you are right. If I understand you want to run two normal motors and several servos. The Arduino has six pins which support analogWrite, the servo library effects two of these so you still have four analogWrite pins left for motors - they are the ones with the wggley lines next to the pin numbers printed on your board, check out pins 6,5 and 3.
You will most likley want a motor driver ic of some sort, this will allow you to supply the motors with their own power and also gives forwards and reverse control, look up l293 it's what many of the motor shields use.
Duane B
Read this
then watch this
mr_genius
Thanks, that helped me a bit. But I don't get this. Why does this link says pwm functionality is disabled on pins 9 and 10 if we use library :s  . What does it mean ? And i connected it on pin 6 and servo motors moves but very strangely.
http://arduino.cc/it/Reference/Servo
MarkT
It means PWM is disabled on pin 9 and 10 if you use that library.  It can't be stated any simpler.
On standard (not Mega) Arduinos:
timer0 does PWM for pins 5 and 6, and also does the timing for millis(), micros(), delay() etc
timer1 does PWM for pins 9 and 10
timer2 does PWM for pins 11 and 3
The Servo library takes over timer1 completely, no more PWM on pins 9 and 10.  Simple.
DuaneB
If your servos are moving strangely,nits your code or your power. Check the links in my signature for info and examples about servo power with Arduino.
Duane B
Read this
then watch this
mr_genius
Okay, so how can I have two more pins that function similar to pin 9 and 10 ? I want Servo library to take over for example timer 2.
MarkT
The Servo library needs a 16 bit timer IIRC, and only timer1 is 16 bit, the others are 8 bit.  The Servo library can drive any pin for Servo style PWM, but the built-in PWM is then limited to pins 3,5,6,11 - that's what the hardware gives you.  Arduino Mega has many more timers, and most are 16 bit, note.
mr_genius
16 bit PWM outputs on Timer1 which support fast PWM mode versus only one 8 bit PWM on Timer2
So I guess I have no way to have 16 bit PWM on other pins for other servo motors but to use 8 bit PWM which is provided by Timer 2 or timer 0 and is not good option.
