Topic: Moving a servo between 2 points (Read 3732 times) previous topic - next topic
EnigmaCypher7
I am using an Adafruit motor shield to control a small robotics platform, the code for the motors works perfectly but the code for the servo will not stop moving after it reaches the end of its cycle. More specifically, the servo stays on, hums loudly because it is trying to overdrive its inner workings in either direction depending on which way you are trying to drive it.
I need 2 things to happen, the servo to move all the way to 0 and all the way to 180. (standard servo, not continuous)
and
Every time I power on this project the servo feels the need to move back to position 0. Can this be eliminated so that the servo just stays wherever it was last? If not not as big a deal as the previous problem.
Code: [Select]
#include <AFMotor.h>  //Add support for Motorshield Motor Library
#include <Servo.h> //Add support for Motorshield Servo Library
Servo myservo;  // create servo object to control servo (Pin10)
AF_DCMotor motor1(1, MOTOR12_64KHZ); // create motor #1, 64KHz pwm  - Right Track
AF_DCMotor motor2(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm  - Left Track
AF_DCMotor motor3(3, MOTOR12_1KHZ);  // create motor #3, 1KHz pwm  - Tilt Camera Mount
AF_DCMotor motor4(4, MOTOR12_1KHZ);  // create motor #4, 1KHz pwm  - Lights / Buzzer (Depending on Polarity)
myservo.attach(10); // Attaches servo1 on pin 10 to the servo object
Serial.begin(9600);           // Setup Serial library at 9600 bps
  // read the IO:
  if (Serial.available() > 0) {
    int inByte = Serial.read();
    int speed; // Local variable
//Motor 1 - LOW Speed - LEFT Track
      switch (inByte) {
    case 'Q':
      motor1.setSpeed(175);
      motor1.run(FORWARD);     // Motor Runs Forward
    case 'W':
      motor1.run(RELEASE);     // Motor Stops
    case 'E':
      motor1.run(BACKWARD);    // Motor Runs Backwards
//Motor 1 - HIGH Speed - LEFT Track
    case 'q':
      motor1.setSpeed(225);
    case 'w':
    case 'e':
//Motor 2 - LOW Speed - RIGHT Track
    case 'A':
      motor2.setSpeed(175);
      motor2.run(FORWARD);     // Motor Runs Forward
    case 'S':
      motor2.run(RELEASE);     // Motor Stops
    case 'D':
      motor2.run(BACKWARD);    // Motor Runs Backwards
//Motor 2 - HIGH Speed - RIGHT Track
    case 'a':
      motor2.setSpeed(225);
    case 's':
    case 'd':
//Motor 3 - Custom Speed - PT Cam
    case 'z':
      motor3.setSpeed(125);
      motor3.run(FORWARD);     // Motor Runs Forward
    case 'x':
      motor3.run(RELEASE);     // Motor Stops
    case 'c':
      motor3.run(BACKWARD);    // Motor Runs Backwards
//Servo1 - Open and Close Claws
    case '1':
      myservo.write(0);     // Closed
    case '2':
      myservo.write(180);    // Open
    default:
      // turn all the connections off:
      for (int thisPin = 2; thisPin < 7; thisPin++) {
        digitalWrite(thisPin, LOW);
Press keyboard key 1 for 0 degrees on servo.
Press keyboard key 2 for 180 degrees on servo.
I have tried changing the degree numbers and that didn't help, is there a line of code that perhaps is supposed to be added to stop the servo ?
Thanks,
Ec7
He who dares, Wins.
Grumpy_Mike
Quote
Is your servo capable of such movement? It sounds like you are hitting the physical end stops.
EnigmaCypher7
#2
May 04, 2012, 02:36 am Last Edit: May 04, 2012, 03:00 am by EnigmaCypher7 Reason: 1
It is supposed to be able to do only 180 degrees, I have tried changing the numbers to a smaller number than 180. For instance if you change 180 to 90, it will move and hit the stops anyways.
Update:
Okay still playing with it, if I change one of the numbers to 50, it will not hit the stop and the Servo cuts off like it is supposed to. But if I hit the key to make it go back to 0 degrees, it moves back but will vibrate and still hits the stop.
He who dares, Wins.
EnigmaCypher7
Okay, I can get the servo to stop vibrating if I change the 0 to larger number, 20 for an example. If I change the 180 to 60 this works as well.
Unfortunately when the shield first starts up the position still seems to move to 0 ish and the servo vibrates.
I added
Code: [Select]
int pos = 20;
Hoping the servo would start at 20, in range enough to stop vibrating, but it still seems to go to 0ish and isn't vibrating but isn't 20 either.
This is where I put this line:
int pos = 20;    // variable to store the servo position
He who dares, Wins.
EnigmaCypher7
As far as the project goes, problem solved it was the servo,
When this new servo is first fired up (Board is powered on) it goes to 90 degrees, I then changed to the following code:
Code: [Select]
case '1':
      myservo.write(120);
    case '2':
      myservo.write(55);
This moves as much as I need it to. The 90 Degrees is close enough to half way for this to work. I know I could always turn the mounting wheel thing so that 90 degrees was closed or open and readjust the numbers in the code.
Yay! =D
Thanks for the help Mike.
Sill a bit curious about:
Code: [Select]
He who dares, Wins.
Grumpy_Mike
All that does is to declaire a variable you have to use it in setup to send the servo to that position, then put in a bit of a delay so it gets there, befor loop tells it to go some place else.
DaveO
Just a novice question : but wouldn't the servo, on receiving power, need to travel to the zero point ( it's limit ) in one direction or another, so that it has a reference position to work from ?
If so, then how would you prevent this movement ? Even setting the servo position ( eg myservo.write(20) ) would make it ( when powered up ) travel to zero so that it then knows where the 20 point is.
Grumpy_Mike
Quote
No, it is not a stepping motor, the position pot inside a servo gives an absoloute position, so there is no need to find a referance point.
AWOL
Strangely, you can do a "Servo.write" before you do a "Servo.attach" to set the start "angle".
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
EnigmaCypher7
I am thinking the pot inside the first servo I used was misaligned, telling the servo shaft to go past the stop to reach the desired degrees. The servo was absolutely defective, it was doing stupid stuff with another code that I know works.
Awol;
Quote
I will play with this idea when I get home, could be really useful for future projects.
Grumpy_Mike;
Quote
Yeah, that's what I thought it was supposed to do, but it didn't seem to be working, was the way I inserted it in my code wrong?
Thanks again for both of your help,
I will play with these some more then start learning about and playing with my new XBees, don't worry, not related to my other Theoretical question post =P
http://arduino.cc/forum/index.php/topic,103923.0.html
He who dares, Wins.
Grumpy_Mike
Quote
Probably, but as you didn't post that bit I can't tell. The bit you posted had no movement in the setup.
