Pages: [1]   Go Down
Author Topic: SOLAR ENERGY  (Read 1062 times)
Offline Offline
Full Member
View Profile
Hi all
I hope I post to the relevant forum .
I want to use ARDUINO in the SOLAR ENERGY field .
My question is : What is the general direction of using ARDUINO or other micros
 in the SOLAR ENERGY field ?
Thanks
Elico
Moderator edit: excessive white-space removed
« Last Edit: April 24, 2012, 01:04:42 pm by Coding Badly » Logged
Global Moderator
Netherlands
Offline Offline
Shannon Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
use it with care as higher voltages can damage your arduino.
2) an arduino is not made for outside use unless in an appropiate casing.
What do you want to do?
- monitor energy
- rotate solarcells to optimize output
- control a car wiper to keep the solar cell clean?
PLease tell us more about the goal of your project.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Offline Offline
Edison Member
View Profile
Ummm... What do you want to do????
You could certainly build a solar enegry system, complete with a battery charger and a DC-to-AC converter, and even with automatic switching between solar & the power-company. and, that could be done without a microcontroller...
If you wanted to make a sun-tracking mirror, that would be a good Arduino project because you need something to "make decisions"...  Do I need to move?  What direction should I move?  How much should I move?  Have I moved far enough? Have I moved too far?
When I think about what makes compters (and microcontrollers, etc.) and programming useful, I think of the following things:
1. Doing things over-and-over in a loop.   For example, making the same calculation in hundreds or thousands of cells in a spreadsheet.
2. Making calculations.
3. Making "logical" decisions.  If the sun is out, and it's the weekend, turn-on the solar swimming pool heater.   If it's the weekend, and the sun is behind a cloud, turn-on the gas pool heater.  (But, one simple decision like that could be done without a "brain chip", although knowing what time it is and what day it is can be somewhat complicated, and it's easy for a computer.)
4. Storing data.
« Last Edit: April 24, 2012, 02:27:36 pm by DVDdoug » Logged
Offline Offline
Full Member
View Profile
Thanks
Elico
Logged
Offline Offline
Jr. Member
View Profile
I did a project that:
1-Make a calculation of total power of 4 x 180 watt cell then is exported to a excel
2-swicht the cell form all in parallel to 2 in series in parallel with 2 in series when the sun is not enough
for increment the output power
Logged
Offline Offline
Newbie
View Profile
I would use Arduino in solar energy field:
1) to manage charging process of batteries
2) to track the Sun
3) to monitor and gather data
4) communicate with PC (upload data)
Logged
Offline Offline
Full Member
View Profile
Thanks to all
Elico
Logged
Global Moderator
Netherlands
Offline Offline
Shannon Member
View Profile
So what will be your project?
Logged
Rob Tillaart
Pages: [1]   Go Up
Jump to:
