Topic: Capacitive Sensor with conductive ink or Tin Foil — Slow readings (Read 943 times) previous topic - next topic
faeve
HI there,
I am building a capacitive sensor using conductive Ink and I am also trying to see what happens when I use tin foil.
At now I am using the CapSense Library http://www.arduino.cc/playground/Main/CapSense and their sketch.
I am using to wires one from pin 2 (the sensor) and one from pin 4 with a 10M resistor in between.
The reading in the serial monitor is sooooo slow and I can't seem to be able to do something about it.
Does anyone have a suggestion?
Many thanks in advance for your help?
Best
PIA
Hi friends. Haveing the same problem with the capsense lib - very slow readings.
Don't think it's a problem with the capteur or the resistance.
Looking for help.
best wishes
faeve
Hi there,
I have managed to make it work in the end by using at least 4-5 resistors of 10Mohm each.
Let me know if this makes any difference to your project
Best
dkl65
If you use a high value resistor, the response time will be slower. Try different resistor values, and post your code and circuit.
Visit http://www.glenof.webs.com/!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
