Topic: Serial.write(ptr,len) ->increment ptr while applying a function (Read 1 time) previous topic - next topic
diesel
Hello,
I was wondering if it is possible to apply a function to a char as it is being written with Serial.write. Something as follows:
char buffer[20]={2,3,4,5,6,7,8,9.....};
char ptr = &buffer[0];
char len = 20;
char * updatevalue(*char ptr){
uint8_t c = *ptr*2;
return &c;
Serial.write(updatevalue(ptr++),len);
Not sure if this is possible, can anybody help out?
Thanks,
-diesel
Nick Gammon
Not like that. You are returning a pointer to a local variable.
This is incredibly convoluted. What about a "for" loop that just steps through the array?
If you weren't submitting an entry in the "obsfuscated C competition" I would mark you down heavily for that code. It's almost incomprehensible. No offence. :)
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
PaulS
Code: [Select]
uint8_t c = *ptr*2;
return &c;
Did you bother even trying to compile this?
Nick Gammon
Let me try ...
Code: [Select]
char buffer[20]={2,3,4,5,6,7,8,9};
Gives:
Code: [Select]
sketch_may03e:1: error: invalid conversion from 'char*' to 'char'
More info:
robtillaart
do you want to apply the function to the first element only or to all the elements?
your code returns the address of the local var c on the stack as the start of the array. That is a recipe for disaster
this is a refactored version that only changes the first char of the array. (stayed as close to your code as possible)
Code: [Select]
char* ptr = &buffer[0];     //  Patched here
char len = 20;
uint8_t c = *ptr*2;
return ptr;   // and here
all elements
Code: [Select]
for (int i=0; i<len; i++)
  char c = buffer[i] * 2;  // keep original content intact? otherwise use buffer[i] *= 2;  Serial.write(buffer[i];
  Serial.write(c);
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
michael_x
After you've been bashed so hard:
Your original question "increment ptr while applying a function"
--> that's possible of course:
Code: [Select]
int get2Value(char* p) { return ( (*p) << 1) ; }
char* ptr = buffer;
char len = 10;
  while (len-- != 0 )
     Serial.print(get2Value(ptr++)); Serial.print(' ');  // prints "4 6 8 10 12 14 16 18 0 0 "
This sample does not change the buffer content, but it increments ptr after it has been used to call a function.
Hope you get the other hints, too ;)
diesel
Well, the reason I brought it up is because I have seen some code where people create a class that inherits from print.h, they create their own function for write to execute a function on the chars. I thought this might be a way to get around that.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
