Pages: [1] 2   Go Down
Author Topic: 2 dimensional array of chars.  (Read 696 times)
UK
If I have a 1 dimensional array of chars
char command[20];
Which contains a set of chars which are zero terminated.
So
command[0]="H"
command[1]="E"
command[2]="L"
command[3]="L"
command[4]="O"
command[5]=(char)0
I can refer to that as command so Serial.println(command); works and prints HELLO
Now the problem:
If I have a 2 dimensional array of chars
char commands[20][5];
So
commands[0][0]="H"
commands[1][0]="E"
commands[2][0]="L"
commands[3][0]="L"
commands[4][0]="O"
commands[5][0]=(char)0
commands[0][1]="W"
commands[1][1]="O"
commands[2][1]="R"
commands[3][1]="L"
commands[4][1]="D"
commands[5][1]=(char)0
How can I refer to a group in that
Serial.println(commands[][0]);  obviously can't work
and Serial.println(commands[0]);  obviously can't work because it wouldn't know which element it was talking about......
Is there a way ????
UK
Online Online
Unless you've got very peculiar requirements, I'd say you've got your array indices the wrong way round.
commands[0][0]="H"
commands[0][1]="E"
commands[0][2]="L"
commands[0][3]="L"
commands[0][4]="O"
UK
If it makes it easier then I could swap them but they are basically just chars in a grid....
Netherlands
should be
char commands[20][6];
to have place for the '\0'  Needed if you want to use println()
and single quotes!!!
commands[0][0]='H'
commands[0][1]='E'
commands[0][2]='L'
commands[0][3]='L'
commands[0][4]='O'
commands[0][5]=0
Rob Tillaart
UK
Online Online
Sorry - Rob is correct - I missed the double quotes.
UK
Thanks, I just wrote the above using copy and paste in order to populate the array.  The array is populated ok at the moment so
if I have the array as per your spec (which just means swapping the indices round) how do I actually print HELLO?
Thanks for taking the time.
Miramar Beach, Florida
You can use them that way, but you need to use them like you entered them.
for(int x=0; x<20;x++)
   if(commands[x][0] == 0) break;
   Serial.print(commands[x][0]);
Now, when you look at the alternative, doesn't AWOL's plan sound better?
UK
Sorry if there was any confusion here....
I will swap the indices round happily and the array does have the correct values in it...
the following code shows me that:
 Serial.println("\n>>>>>");
  for (i = 0; i < numcommands+1; i++) {
    Serial.print(i);
    Serial.print(" = '");
    for (int k = 0; k < 20; k++) {
      Serial.print(commands[k][i]);
    Serial.println("'");
  Serial.println(">>>>>\n\n");
So with the indices swapped around which I will happily do....
can I refer to one string in the same way that I would if it were 1 dimensional
commands[0]='H'
commands[1]='E'
commands[2]='L'
commands[3]='L'
commands[4]='O'
commands[5]=0
Serial.println(commands)
Thanks
« Last Edit: May 04, 2012, 07:56:47 am by cowasaki » Logged
UK
Online Online
If you put proper code tags around that, it'll remove the italics, and start to make sense.
If you switch the array dimensions around (and use the code tags) as AWOL suggests, then you can use these:
Serial.println(commands[1]);
UK
Serial.println(commands[1];
Thanks,  I will swap the indices around and check....
UK
Thanks everyone for your help it is appreciated.
I was writing a parsing function which handles double quotes too.  It now works smiley
I'm new to C++ normally programming in assembler or Pascal (delphi)
char commands[5][20];
byte getwords(char s[30]){
  byte i=0;
  byte pos=0;
  byte numcommands=0;
  boolean inquotes=false;
  for (i = 0; i < 6; i++) {
    for (pos = 0; pos < 20; pos++) {
      commands[i][pos]=(char)0;
  pos=0;
  for (i = 0; i < 30; i++) {
    if (s[i]==NULL){break;}
    if (s[i]==(char)34){
      inquotes=!inquotes;
      if ((s[i]==(char)32) && !inquotes){
        pos=0;
        numcommands++;
        commands[numcommands][pos++]=s[i];
  return numcommands+1;
I am trying to get my head round C++, is this written in the best way?  Can anyone see anything that is best done another way?
Thanks for looking.
« Last Edit: May 04, 2012, 10:16:14 am by cowasaki » Logged
BTW, there is a quick way to initialize that array.
char commands[2][16] = {
   "Hello ",
   "world!"
   Serial.print(commands[0]);
UK
Thanks,  I actually know that but I was trying to make sure it was very obvious what I was doing.
just looking for quick and/or smaller ways of doing stuff.
  for (int i = 0; i < 6; i++) {
      commands[i][k]=(char)0;
As an example:      To empty the array, is there an easier/smaller way of doing this?
UK
Online Online
You could use memset, but if all you're using is string functions (strcmp, strcat, strlen etc) then all you need to do is set the first element of each string to null '\0'.
Pages: [1] 2   Go Up
