Loading...
Pages: [1]   Go Down
Author Topic: thermistor values  (Read 383 times)
Offline Offline
Newbie
View Profile
assuming I do something like this:
http://www.ladyada.net/learn/sensors/thermistor.htm
correctly building me a thermometer like thingy...
if I graph the response to temperature will I get a linear response, exponent, log? non-linear??
(I would rather know, but will probably double check when I build it)
thaanks smiley
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
As that link lead to a 404 not found page, I don't know.
Anyhow, look for the datasheet for whatever device you are using, and it should tell you what shape response curve the device returns.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
missing l  at end of the link
http://www.ladyada.net/learn/sensors/thermistor.html
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Netherlands
Offline Offline
Tesla Member
View Profile
google thermistor graph => resulted in many graphs including this one.
http://www.digitaldandt.org/db/index.php/datasheet/show/42
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
sorry about the link.  good catch..
it looks like a log curve, however that thermistor only goes up to 100 or so, and approaches a zero resistance when it does.
analog pins give it a value between 0 and 1023 right?
is it likely to be log or linear...  up to 400C (673K) or so for one thermometer, and then up to 1400C (1473K) or so for another thermometer...?
can we assume that it will be a log line irrelevant of the temperature limits?
Logged
Offline Offline
Newbie
View Profile
ha.  woops.  serious examination later - not looking for a thermistor, looking to understand how to use a thermocouple with an arduino.
just one end in analog and one in ground will return a 0,
one end in analog and one in 5v will return a 1023.
but a thermcouple is meant to generate its own teeny voltage.  how might I read that into an arduino?
Logged
Offline Offline
Newbie
View Profile
never mind.  arduino cant do it alone...
http://www.ladyada.net/learn/sensors/thermocouple.html
seems to have helped me.
need a max#### of sorts.  will look into it.
Logged
Atlanta, USA
Offline Offline
Jr. Member
AKA: Ray Burne
View Profile
Remember that a voltage divider is the cheap way to approach the problem.  You would get far superior results using a constant current source for the thermistor.
Additionally, you may find these links of interest:
http://www.phanderson.com/arduino/ntc_therm.html
http://www.phanderson.com/picaxe/lin_thermistor.html
- Ray
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
[optimization]
nice link - bookmarked.
for efficiency reasons I would change this line
TKelvin = 1.0 / (A_const + B_const * x + C_const * square(x) + D_const * cube(x));
to
TKelvin = 1.0 / (A_const + ( (D_const * x + C_const) * x + B_const) * x );
- it removes the need for square() and cube() => removes 3 FPO's  ==> win a few micros() per call smiley-wink
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
