Author Topic: Ardiuno UNO, a4983 driver and stepper motor  (Read 1087 times)
Hi
My Motor doesn't move, i think its a problem with the code
// Stepper
    #include <Stepper.h>
    // steps value is 360 / degree angle of motor
    #define STEPS 200
    // create a object on pins 6 and 7
    Stepper stepper(STEPS, 6,7);
    ///// Turn the stepper 200 steps with a 1 sec delay between steps at 60rpm
    /// then reverse the direction and do 50 steps at 20rpm with a 1sec delay between steps
    stepper.setSpeed(1);
    stepper.step(200);
    //delay(1000);
    //stepper.setSpeed(20);
    //stepper.step(-50);
    //delay(1000);
i am using 12V battery, this motor:
http://www.sparkfun.com/datasheets/Robotics/SM-42BYG011-25.pdf
i am attaching a pic of the Arduino for you to look at.
hope somebody cold help me here...
Itamar
Gosport, UK
I can't see anything connected to the ground (GND) pins.
the GND is connected to  22/j (green wire)
Gosport, UK
There is nothing connected to the Arduino's ground pins.
sorry for the ignorant but i am not sure what do you mean..
i change the code a little bit and now theirs a movement of millimeter (left & right)
Gosport, UK
Whatever the board on the breadboard is, should have it's ground (or GND) connected to the Arduino's ground (GND - just below the 5v pin).
OK. isnt it the same as the GND above the 13 pin?
anyway i am getting the same result from the motor...
Gosport, UK
Sorry, you're right. The text was hidden by the wire.
Gosport, UK
What is the board on the breadboard?
are you talking about the "a4983 driver"?
Canada
Sometimes teaching, always learning,
1 sec delay between steps at 60 RPM doesn't make sense. If you have a 200 step motor and 60 RPM, it will need 200 steps per second, not 1. Likewise, 1 second between steps is about 60/200 RPM, or 0.3RPM.
stepper.setSpeed(1) sets your speed to 1 RPM, not 60. Try setting the value to 100 or so and see if it is actually working.
