Topic: How do i use the Sparkfun Touch Shield to control pin 6 on the Arduino? (Read 1 time) previous topic - next topic
CDCosma
Hi, I have been trying to use Sparkfun's Touch Shield: http://http://www.sparkfun.com/products/10774 to control pin 6 on the Arduino. I want every time I press the 1 button to make pin 6 go low, and every time I press the 2 button to make pin 6 go high. I have tried the most simple approach by adding digitalWrite(6, HIGH); to the else if that runs when button 2 is pressed but it doesn't work. How do I solve this problem?
johnwasser
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
johnwasser
Try this simplified example:
Code: [Select]
// include the atmel I2C libs
#include "mpr121.h"
#include "i2c.h"
// Match key inputs with electrode numbers
#define ONE 8
#define TWO 5
#define THREE 2
#define FOUR 7
#define FIVE 4
#define SIX 1
#define SEVEN 6
#define EIGHT 3
#define NINE 0
//extras (not used)
#define ELE9 9
#define ELE10 10
#define ELE11 11
//interupt pin
int irqpin = 2;  // D2
  //make sure the interrupt pin is an input and pulled high
  pinMode(irqpin, INPUT);
  digitalWrite(irqpin, HIGH);
  //configure serial out
  //output on ADC4 (PC4, SDA)
  DDRC |= 0b00010011;
  // Pull-ups on I2C Bus
  PORTC = 0b00110000;
  // initalize I2C bus. Wiring lib not used.
  i2cInit();
  delay(100);
  // initialize mpr121
  mpr121QuickConfig();
  // prints 'Ready...' when you can start hitting numbers
  Serial.println("Ready...");
  uint16_t touchstatus;
  touchstatus = mpr121Read(0x01) << 8;
  touchstatus |= mpr121Read(0x00);
  if (touchstatus & (1<<ONE))
      digitalWrite(6, LOW);
  if (touchstatus & (1<<TWO))
PaulS
Quote
t's not working.
Yes, it is. It just isn't doing what you want.
You need to tell us what it does, and what you want it to do, and how those two differ.
johnwasser
It's not working.
Oops...  I forgot to put pinMode(6, OUTPUT) in setup().  Does it 'work' if you add that?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
