Topic: Eagle + questions on routing? (Read 6357 times) previous topic - next topic
xl97
#15
Jun 06, 2012, 06:53 am Last Edit: Jun 06, 2012, 06:55 am by xl97 Reason: 1
SMASH!..
thats what I have been looking for..
what other side effects will it have?
it just allows the names/values to be edited/altered on each part? does it do anything else to the part itself??  (layers)
also. when I am done 'sizing' the name/value of a component....and position it where I like.. it is still 'part' of the component?  if I move the component around.. will the name/value move/be associated with it?
Thanks
edit: just tried the smash command.. LOVE IT!.. it keeps/treats the names/values sorta like net names or labels..etc..
PERFECT!..
these tips are great..
thanks
Chagrin
When you're running the CAM processor and after you've loaded the job, you can tweak where names/values/etc. are printed (bottom or top). Just select the Silk Bottom or Silk Top tab and select the layers to include.
xl97
ok..
so I have generated my GERBER files.. (I hope)..
OPEN CAM panel..
loaded the iTeadStudio.cam file..  (first tab)
I did nothing else but click 'process job'..
it finished.. I look in directory I have a bunch of new GERBER files generated  ;)
** my question/concern is understanding more about the process of what needs to be sent to iTeadStudio?  (everything?)
** Do I attempt to edit the 'gerber' file in some sort of editor? (all the free viewers seem to not allow editing without expensive license)
** Or do I go into the .brd file.. and use the SMASH tool on every component.. and edit/alter the names/values to be places and sized (or removed all together).. before generating my GERBERS??
thanks
CrossRoads
SMASH before creating gerbers.
The names & values remain attached to the parts.
If you delete one by accident, or can't find where it ended up on the board, Unsmash to get it back & then Smash again.
Do not edit the gerbers.
Edit your .brd file before creating the gerbers. Can right click each name, change its properties: size, font, etc.
Send itead all but the .sch and .brd.
xl97
perfect.. thanks
thats how Ive been doing it so far....
Can I 'omit' a layer all together?
example.. I was thinking of omitting the tNames layer..so it doesnt print all the C1,.....C11 all over the place..
however.. I copied the S +/-  and P+/- 'text' to the tSilk.. (not _tSilk.. I dont even know the difference though..just wanted to copy it off of tNames layer.. so I could turn that off completely..but still have some text on top...
'or'..
do you recommend I go back and 'SMASH' everything.. delete those tNames I dont want.. (which is like 90% of them)..
thanks..
sidenote: sent ya email Crossroads.. ;)
CrossRoads
Try it both ways, only takes a few seconds to create the gerbers again.
I think you can also review the Tabs at the CAM processor and see what layers it is pulling into each gerber file.
xl97
ok..
finally back on this.. :)
generated gerbers (several times).. installed & used viewplot to check out each 'file'..
iteadStudio seems to only use these files:
.gtl
.gbl
.gts
.gbs
.gto
.gbo
.txt (drill)
but it generates a lot files.. does itead just ignore these?. I sent them along anyways in my .zip file.
so in a few more weeks I should have some PCB's made for one of my projects!  :)
thanks
CrossRoads
xl97
good!..
then I just need to 'wait'.. lol.
might as well start putting together the BOM list.. and order the stencil too!   :D
Chagrin
Wait for Itead's approval before you order the stencil. It's quite possible that they will ask you to make changes to your board.
xl97
ahh.. good call!..
it is in review 'currently' and will contact me only if there are problems.   (heres hoping!)  :) 8)
CrossRoads
The board passed iteadstudio.dru checks, it will be accepted.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
