Topic: Arduino Rover Rocket Launcher (Read 5591 times) previous topic - next topic
PaulS
Quote
Let me know what you think of this...
Sniff. Sniff. Sniff. Hmmm, smells a bit like spam.
minds-i
Hey PaulS,
Nope not spam, just sharing my awesome project check out the code: http://www.mymindsi.com/code
click "launch control box" or "missile truck".
dxw00d
You might want to use the Exhibitions/Gallery forum - http://arduino.cc/forum/index.php/board,29.0.html
cyberteque
That looks great!
Are you using the same kind of digital wireless security camera I am?
http://www.youtube.com/watch?v=43zqBtQyBF0
What kind of control link?
I'm using 2.4Ghz for my video link and 2.4Ghz XBee's, but I'm going to switch over to a 900Mhz XBee link.
I'm finding the video link is "swamping" the XBee at distance.
michael96_27
Good Day minds-i!
Is it okay if you will give me some info or tutorial on how you make your ignition system for your rover?
thanks,
michael
minds-i
Thanks for you recommendation, I'm new to Arduino and this forum. I'll have to post some more cool stuff there!
minds-i
That looks great!
Hey CyberTeque,
Awesome project! I actually only used two Arduino Uno's I didn't need the full capabilities of the Mega. Not for the rocket launcher project anyways...
The camera I used was different than yours. I wouldn't recommend the camera I used it wasn't very good and it didn't have very good range (only a couple hundred feet). The 2.4Ghz xBee's also didn't have that long range either. The camera was 2.4 Ghz.
I used two different controls, we used a standard 2.4 Ghz RC remote to control the chassis and we had a separate launch controller that used a 2.4Ghz xbee, and armed and fired the rockets as well as controlled the pan and tilt.
thanks, let me know if you have any other questions.
Tim
minds-i
Good Day minds-i!
thanks,
michael
Hi Michael,
ummm I might do a tutorial. How about an overview of every that is included in the ignition system?
cyberteque
I'm using 60mW XBee Pro modules, I've gotten nearly 1km!!
For most of the videos I've shot I can't see the rover or I'm inside watching on a 37" TV.
michael96_27
Quote
what do you mean?
cyberteque
not much needed to firing a rocket, if you already launch and fly, just add a transistor and a relay on a digital pin.
I would suggest you NOT switch the igniter directly with a transistor though, you can loose a bit of skin if the rocket exhaust shoots across your fingers as you attach your alligator clips.
and yes, that was from personal experience!
and it did hurt...
AWOL
Quote
How does that happen, when the battery is disconnected?
Smoothing caps discharging?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
cyberteque
lol!
Umm, no, I think it was base leakage maybe?
I didn't have an arming switch...
I still cringe when I think about what my hand looked like!
You don't learn unless it hurts!
And boy did it hurt!
minds-i
and it did hurt...
Actually that did happen to us the other day, we had fired off a couple of rockets using the control box, but the switch was left on so when the when Mike went to attach the alligator clip, the rocket fired! Luckly no on was hurt or burned. Just the shock of the rocket being fired.
Yep w'ere just using a relay to fire each rocket. We use  a digital pin to send a signal to the relay and fire the rocket it pretty safe unless you leave the control box on, armed and ready to fire...
