Topic: Unity Gain Amplifier / Voltage Follower - Selecting resistor (Read 6810 times) previous topic - next topic
tocpcs
I want to put together a voltage follower, as in the circuit diagram here;
http://www.jaycar.com.au/products_uploaded/ZL3072.pdf
- Figure 1 - Unity Gain Amplifier
Note that there is a capacitor and resistor on the output - if I want no gain (just the exact voltage on Vin (voltage follower), what resistor size do I need?
I can't see it - how do you size the resistor and capacitor in the voltage follower circuit?
runaway_pancake
The unity gain config has no resistors, it's a X1 as you see it.
The network on the output there isn't for gain.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
tocpcs
So, from figure one and the many examples on Google..
Supply to Opamp - 5V from Power Supply.
Ground common to device being monitored.
Monitored Input to Non-inverting + of OpAmp
Input of Non-inverting - of Opamp tied to Output.
Output has no capacitor or resistor as in Figure 1 - it just goes straight to Analog In of arduino?
Sounds too simple?
MarkT
That figure is showing the testing network they used to get the figures in the table.  The R and C are dummy loads for the opamp during testing, just ignore them.
But you're right about it sounding too simple, these opamps won't work from a 5V supply.  They are characterised for +/- 15V (which means the datasheet is very coy about saying much about their performance at lower voltages).  One graph suggests they might just work at +/-5V supply, but they are certainly not rail-to-rail and won't work from a single +5V supply.
tocpcs
So I need another component then ?
I want to have the 'no current load' on the circuit being monitored - and ideally want to do it from the same supply as the circuit being monitored (which should be 5V).
Any suggestions on an Op-Amp capable of producing that from +5 only!?
The plan is as "CrossRoads" previously posted here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1293425807/21#21
Finally making some ground on this - but yeh, he said single power supply there ( comprehension fail!).
tocpcs
Another thought is some sort of voltmeter circuit - I need it to be high impedance though - just like a multimeter - so it doesn't interfere with the readings.
The voltmeter would need a 0-5V scale (since the most the sensor can go is 5V and gnd when short cct.
I don't really want to bring a negative supply into the equation, so I think I need a rail-to-rail opamp one that can go right close to ground (the measurements we are interested in will be in the range of 0.7 ? to around 3V when cold. I was reading that Op Amps don't typically output that close (though rail-to rail does?)
And I need it to do that with 5V input and single supply (5V and GND).
TLV2231 ? Bad choice?
runaway_pancake
LM358 and LM324 are inexpensive and commonly available "single-supply" op-amps, and they're good with inputs down to Ground.  Their outputs cannot go > Vcc - 1.5V, but that wouldn't be a concern if powered from/by tapping arduino +V_in.  They have wide supply ranges.
tocpcs
Ahh,  VCC(5V) - 1.5V = 3.5V (so I can read from 0 to 3.5V)..
I thought of LM358 (due to how common it is), but can't find in the datasheet where it is high impedance (i.e. like the JFET input in the TL072).
I need the high impedance so that we don't take current from the circuit being monitored.
tocpcs
LM358 might work, but I think rail-to-rail would be better (Gnd to 5V on input = Gnd to 5V on output).
That 3.5 - 5V would equal just below 21 deg in temperature - don't want to lose that much of the range.
tocpcs
Oh I see - Most of the Op Amps can only produce up to (VCC - 1.5V).
To get the full 5V - I need a supply of 6.5+ Vcc.
What are the downsides of using a DC-DC to get 6.5 from 5Vdc ?
5Vdc from the existing controller (mains powered), to the arduino 5Vdc, and then take from the 5Vdc to a DC-DC converter to get 7V with minimal power (OpAmp = low power).
dc42
#10
May 05, 2012, 03:13 pm Last Edit: May 05, 2012, 03:16 pm by dc42 Reason: 1
The ADC in the Arduino has a typical input resistance of 100Mohms, and a sample capacitor of around 6.5pF. So it disturbs the circuit being measured very little. Unless the input voltage is changing rapidly and you want to follow those changes, you may not need an amplifier at all.
If you want an inexpensive rail-to-rail op-amp in a non-smd package, here is a suggestion: http://uk.rs-online.com/web/p/op-amp/0403165/.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
tocpcs
Heh, I was thinking of that - the multimeter doesn't affect it - I can go to the analog pin of the MCU being monitored, and the - (gnd) of the sensor, and get a reading - it doesn't appear to drop it at all.
It appears the temperature sensor on the circuit being monitored has a diode on the grnd (looks like a shottky so I think -- lightning protection?)
And the positive is a 10k resistor.
Is the analog inputs really in the megaohms of resistance though?
How can I make my connection high impedance ? Does putting a 1Mohm resistor at the connecting point accomplish this (i.e. stops it drawing current?)
If I connect, I'll be loading down the temperature circuit (if it's wrong and the impedance isn't greater in the duino), I think that'll just cause it to think the sensor is 'hotter' than it is, until the current draw stops (as current increases, voltage decreases, so the temperature reading to the controller would be 'hotter').
MarkT
Originally all opamps were designed to operate on +/-15V or +/-12V - this was universally accepted as a given.
Only more recently have people realised that this is inconvenient since the majority of electronics is digital and 5V was a more convenient supply.   Original PCs had a +12V and -12V for several reasons (disk drive motors, serial comms and op-amp/analog interfaces).  But now the emphasis is entirely on personal electronic devices where there is no need for such supplies, so a whole raft of low-voltage opamp designs appeared.
Most opamps that can run at 5V don't perform their best at that low a voltage, note, particularly frequency response is compromised.  Most rail-to-rail opamps can't actually drive more than a few microamps right to the rail too, so in general you expect even a rail-to-rail opamp to only handle signals from 1.0--4.0V or 0.5--4.5V (on the output side that is).  The input behaviour at at least one rail is usually fine (many opamp inputs can handle -0.3V or so on the inputs for instance owing to PNP or JFET input stages.
runaway_pancake
For the purpose of this discussion impedance means the same thing as resistance.
What's needed is a comparatively low impedance connection to the analog in, that way practically all of the voltage is across the high impedance.
If you have a 1000? resistor in series with a 100M? resistor, practically all of the applied voltage is where?  It is across the 100M?, 1000? : 100M?.
You missed the part where I said to run the op-amp from "Vin", but you can't do that if you're stuck on running from 5V.
tocpcs
I caught that - VIN will be empty - the plan is to not use the voltage regulator and bring in +5 from the already regulated +5 at the other controller - (saves getting an additional supply and then wasted energy from that).
I *was* going to go and chuck a 9V supply in, but if I'm not going to have an issue wiring the input to the arduino (i.e. I don't want the arduino loading down the sensor), then I won't worry about the Op-Amp.
The entire point of the op-amp is so I don't load it down - if the analog inputs are indeed 100Mohm then I would hope that's fine? The sensor reading won't get loaded down, it'll be accurate and I'll get on with reading the voltage...
