Topic: help me in EasyTransfer Library (Read 2803 times) previous topic - next topic
amr_hamed
Hello arduino members plz i need to control 2 servos with 2 potentiometers wireless by 2 arduino & Xbee modules , i had EasyTransfer library to make it but i faced a problem with the example code because the code designed to control 1 servo with 1 pot & i tried to modify it but in vain because i can't find any Definition of the pot in this code like : int potpin = 0 , val = analogRead(potpin) ........ so plz help - See the code
/*This is an example of the EasyTransfer Library 2way communications.
This sketch is for the Arduino with the servo attached to pin 9.
The other Arduino has a potentiometer attached to analog pin 0.
Both have a putton attached to pin 12 and output a status using the LED on pin 13.
The idea is each arduino will read the status of the button attached to it, and send it
to the other Arduino, which will toggle it's LED based on the others button. The button
should connect pin 12 to ground when pushed.
And the Arduino with the potentiometer will send it's value to the one with the servo.
The servo will move to the position based on the potentiometer.
#include <Servo.h>
#include <EasyTransfer.h>
//create two objects
EasyTransfer ETin, ETout;
//create servo
Servo myservo;
struct RECEIVE_DATA_STRUCTURE{
  //put your variable definitions here for the data you want to receive
  //THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
  int buttonstate;
  int servoval;
struct SEND_DATA_STRUCTURE{
  int buttonstate;
//give a name to the group of data
RECEIVE_DATA_STRUCTURE rxdata;
SEND_DATA_STRUCTURE txdata;
void setup(){
  //start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
  ETin.begin(details(rxdata), &Serial);
  ETout.begin(details(txdata), &Serial);
  pinMode(13, OUTPUT);
  pinMode(12, INPUT);
  //enable pull-up
  digitalWrite(12, HIGH);
  myservo.attach(9);
void loop(){
  //first, lets read our button and store it in our data structure
  if(!digitalRead(12))
    txdata.buttonstate = HIGH;
    txdata.buttonstate = LOW;
//then we will go ahead and send that data out
  ETout.sendData();
//there's a loop here so that we run the recieve function more often then the
//transmit function. This is important due to the slight differences in
//the clock speed of different Arduinos. If we didn't do this, messages
//would build up in the buffer and appear to cause a delay.
  for(int i=0; i<5; i++){
    //remember, you could use an if() here to check for new data, this time it's not needed.
    ETin.receiveData();
    //set our LED on or off based on what we received from the other Arduino
    digitalWrite(13, rxdata.buttonstate);
    //set our servo position based on what we received from the other Arduino
    //we will also map the ADC value to a servo value
    myservo.write(map(rxdata.servoval, 0, 1023, 0, 179));
    //delay
    delay(10);
  //delay for good measure
  delay(10);
cheers
PaulS
No. It is designed to send one packet containing two ints.
It does not matter what those two ints represent. They could be two potentiometer values, two sensor values, two switch states, or two random numbers.
Of course, you can change the number of ints in the structure, or add other variable types.
amr_hamed
#2
May 05, 2012, 04:21 pm Last Edit: May 05, 2012, 04:30 pm by amr_hamed Reason: 1
thanks for ur interest , see these modification & tell me if it true
#include <Servo.h>
Servo myservo ;
Servo myservo2 ;
  int servoval;
  int servoval2;
  int servoval;
  int servoval2;
void setup(){
  myservo.attach(9);
  myservo2.attach(10);
void loop(){
  txdata.servoval = analogRead(0);
  txdata.servoval2 = analogRead(1);
  ETout.sendData();
    ETin.receiveData();
    myservo2.write(map(rxdata.servoval2, 0, 1023, 0, 179));
    delay(10);
  delay(10);
cheers
PaulS
Servo myservo ;
Servo myservo2 ;
When you are counting servos, do you count "Yes, that is a servo, 2, 3..." or do you count "1, 2, 3..."?
The digitalRead() function does not return a boolean value. You should not write code whose intent is not clear. There should be no reason to think about whether HIGH or LOW is true, and the effect of negating that. Use
if(digitalRead(12) == HIGH)
and put the correct actions in the correct blocks.
What happens when you execute that code?
amr_hamed
see the code again because i have removed the button case becasue i don't need it
best - amr
PaulS
Don't do that. If you modify the code, post it again.
Answer all the questions, if you need help.
amr_hamed
sorry  :smiley-slim: this the code again , i didn't try the code yet because i didn't get the xbee modules yet but i am waiting for it , i am doing that to be ready when the modules comes
#include <Servo.h>
Servo myservo ;
Servo myservo2 ;
  int servoval;
  int servoval2;
  int servoval;
  int servoval2;
void setup(){
  myservo.attach(9);
void loop(){
  ETout.sendData();
    ETin.receiveData();
    delay(10);
  delay(10);
Cheers
amr_hamed
Arrch
hello every body i need help :)
With what? Your last post was "here is the code, but I haven't tried it yet."
If you wan't help, you're going to have to try the code first and then report back any problems you have.
amr_hamed
thanks for reply i will try it but , i need u to confirm that i will upload this code in the 2 arduinos with the 2 Xbees
sincerely
Arrch
sincerely
You have my permission to upload your code to your Arduino.
