Topic: Binary Clock - Help again! (Read 987 times) previous topic - next topic
danielNC
Okay, Ive been playing with the Evil Genius binary clock and I added a RTC to keep the time accurate.
Final problem is that the LED on lilypad pin 1 remains high.  It does appear to flash off with the updateDisplay routine, but essentially it is on all the time.
I can see the time on the serial monitor and also advance the time, but it always remain on with some brief flashes off during uploading or as listed above.
Des anyone see something causing this?
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
int switchPin = 11;
int hourLEDs[] = {4, 3, 2, 1}; // least significant bit first
int secondLEDs[] = {10, 9, 8, 7, 6, 5};
int minuteLEDs[] = {17, 16, 15, 14, 13, 12};
int loopLEDs[] = {4, 3, 2, 1, 17, 16, 15, 14, 13, 12, 10, 9, 8, 7, 6, 5};
  for (int i = 0; i < 4; i++)
     pinMode(hourLEDs, OUTPUT);
  for (int i = 0; i < 6; i++)
     pinMode(minuteLEDs, OUTPUT);
     pinMode(secondLEDs, OUTPUT);
   setSyncProvider(RTC.get);   // the function to get the time from the RTC
  if (digitalRead(switchPin))
    adjustTime(60-second());  // Move the clock forward to the next minute
    RTC.set(now());  // Set the RTC to the new time
    delay(100);
  else if (minute() == 0 && second() == 0)
    spin(hour());
  updateDisplay();
  delay(100);
void updateDisplay()
  //setSyncProvider(RTC.get);
  //time_t t = now();
  setOutput(hourLEDs, 4, hourFormat12());
  setOutput(minuteLEDs, 6, minute());
  setOutput(secondLEDs, 6, second());
  Serial.print(hourFormat12());
  printDigits(minute());
  printDigits(second());
  Serial.println();
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
  Serial.print('0');
  Serial.print(digits);
void setOutput(int *ledArray, int numLEDs, int value)
    for (int i = 0; i < numLEDs; i++)
     digitalWrite(ledArray, bitRead(value, i));
void spin(int count)
  for (int i = 0; i < count; i++)
      for (int j = 0; j < 16; j++)
         digitalWrite(loopLEDs[j], HIGH);
         delay(25);
         digitalWrite(loopLEDs[j], LOW);
kf2qd
Is pin 1 used for the serial port on the lilypad? might be seeing a conflict there -
Try putting your code inside a code block - the button with the "#"
danielNC
The original code used the same pins and If I run that program it seems find, just does not use the RTC.  (My original clock was running at 1/2 speed and I think the board was bad.  Bought a new one and it appears much better.  Just trying to add in the RTC to keep time accurate)
I added in the RTC and a print.serial so that I could see the time when plugged in.  Now I can't seem to be able to get pin to go low.
I'm not sure what you mean by "Try putting your code inside a code block - the button with the "#".....  New to arduino and C  :)
Thanks for looking, Dan
PaulS
Above the gray box where you type and paste code, there are a series of icons. One of them has a # sign on it. Press that BEFORE you paste code, and you will see
[code][/code]
with the cursor between the ] and the [. That is where you paste your code.
danielNC
Thanks...  Got it.
Found the problem (I think)
I turned off the serial display for "seeing" the time value.  Appears to be working inf now!   :)
cmiyc
This is what kf2qd was getting at.  You are using Pin 1 in your code, so of course it will react when Serial communication occurs.
