Topic: Passing 2D array into a function, pointers? (Read 4319 times) previous topic - next topic
TopDog101
I am trying to control an RGB strip, and to create some of the effects would like to store the brightness of each RGB leds information in a 2D matrix; 3 rows for colour and 160 (NUM of leds) for the columns. I have tried to write functions to handle shifting and displaying the information in the 2D array, but it seems I need to use pointers (maybe?) which I am not familiar with. So I have a few questions:
-Is an array the best way to handle this sort of information? (I think that it is only using 3*160 = 480 bytes of the 1024 on the ATmega168)
-Can I replace a whole column of an array at a time e.g. Array[][0] = Array[][1]? (as aposed to modifying each element in a column)
-How can I get pointers to work/fix the error message(s)?
Here is the compile error:
shift_Update_etc.cpp: In function 'void loop()':
shift_Update_etc:65: error: invalid conversion from 'void*' to 'byte**'
shift_Update_etc:65: error: initializing argument 1 of 'void Update(byte**, int)'
shift_Update_etc:65: error: label 'ColourArray' used but not defined
Code: [Select]
#include <FastSPI_LED.h>
//SCK = pin 13. SD = pin 11. Pins 10 and 12 are not used.
#define NUM_LEDS 160
struct CRGB { unsigned char b; unsigned char g; unsigned char r; };
struct CRGB *leds;
#define PIN 4
//---Functions---
//Shift every element in the array by 1 to either the left or the right
void ArrayShift(byte** ColourArray, int N_LEDS, char Direction){
  if(Direction == 'R'){
    for(int i = N_LEDS - 1; i >= 0; i--){
      for(int j =0 ; j < 3; j++){
        ColourArray[j][i] = ColourArray[j][i-1];
     else{
      for(int i = 0; i < N_LEDS - 1; i++){
        for(int j = 0; j < 3; j++){
//Updates the RGB strip with new information
void Update(byte** ColourArray, int N_LEDS){
  memset(leds, 0, NUM_LEDS * 3);
  for(int i = 0; i < N_LEDS; i++){
    leds[i].r = ColourArray[0][i];
    leds[i].g = ColourArray[1][i];
    leds[i].b = ColourArray[2][i];
  delay(1); //Min time needed to write data to strip
  FastSPI_LED.show();
//---End functions---
  FastSPI_LED.setLeds(NUM_LEDS);
  FastSPI_LED.setChipset(CFastSPI_LED::SPI_WS2801);
  FastSPI_LED.setPin(PIN);
  FastSPI_LED.setDataRate(2); // data rate 2 is good (default is 1)
  FastSPI_LED.init();
  FastSPI_LED.start();
  leds = (struct CRGB*)FastSPI_LED.getRGBData();
  FastSPI_LED.show();
  byte ColourArray[3][NUM_LEDS]; //Setup the array
  for ( int i = 0; i<NUM_LEDS; i++){
    for(int j = 0; j<3; j++){
      ColourArray[j][i] = 255;
  Update(&&ColourArray, NUM_LEDS);
pYro_65
#1
May 06, 2012, 12:30 pm Last Edit: May 06, 2012, 12:34 pm by pYro_65 Reason: 1
change &&ColourArray
to ColourArray
an array name without indexing is its pointer i.e 'byte**' ( arrays are pointers in disguise )
this wont work until
is declared in a scope loop() can see
it is currently only in scope during setup(), also if you make it global you will need to change the parameter names in the functions that use 'ColourArray' as a name
Forum Mod anyone?
https://arduino.land/Moduino/
TopDog101
If I declare 'byte ColourArray[3][NUM_LEDS]' outside both the setup() and loop() calls I get a new error (This is with the change to ColourArray):
shift_Update_etc:66: error: cannot convert 'byte (*)[160]' to 'byte**' for argument '1' to 'void Update(byte**, int)'
I also changed the paramter names:
Code: [Select]
void Update(byte** CArray, int N_LEDS){
    leds[i].r = CArray[0][i];
    leds[i].g = CArray[1][i];
    leds[i].b = CArray[2][i];
  FastSPI_LED.show();
PaulS
Quote
There is a real big clue there as to how you need to change the function declaration.
Code: [Select]
void Update(byte* CArray[160], int N_LEDS)
{ // Down here where it belongs!
pYro_65
You can cast the variable to the pointer type.
Code: [Select]
Update( ( byte** ) ColourArray, NUM_LEDS );
or use an array in the parameter list
Code: [Select]
void Update(byte CArray[][NUM_LEDS], int N_LEDS){
 FastSPI_LED.show();
Forum Mod anyone?
TopDog101
I managed to get the code to compile using the code pYro_65 provided:
I did try the other suggestions, but got new error messages that I wasn't able to clearly decipher.
I will test test it out soon, but thanks for the help in the meantime.
TopDog101
OK. It works! I did have to use a 328 board though, the 168 stopped uploading halfway through (even if I decreased the NUM_LEDS to 1, so that the array would decrease in size) Is this a memory problem? The 168 will still take my old programs without the functions and array.
Here is the error that occurs midway through an upload to the 168 board:
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_cmd(): protocol error
