Author Topic: Recognizing loud sounds.  (Read 898 times)
Hello everyone,
I want to build an arduino controlled machine that  recognizes if someone is shouting and react to that.
It should messure the the length of the shout.
I thought of something like this:
microphone ->preamp -> arduino
(if sound is going louder than xy start messure Time, if sound is not  louder than xy anymore stop messure Time
-> 30% of the messured Time = doing nothing
-> than trigger a Relais for 100% of the messured Time)
I hope you understand that, my english isn't that good on Sundays smiley
It seems like an easy thing to do to me, is it?!
Ah btw. i want it standalone, without a PC. Dont know if it makes any difference.
You see I am pretty new to arduino, so maybe you know some existing codes that could be used for it? Or just some general advice how to realize the interpreting of the audio in signal etc.
Best Max
Netherlands
Hi Max, welcome where are you from (I can't see in your profile)
Think you have a reasonable idea how you would do it. Have you checked the tutorial section allready, There are several samples that contain code parts that I recognize in your project.
learn how to measure time wilt millis()
Here some code to get started...
  Serial.println("Soundmeter 0.1");
  // DO MEASUREMENT
  unsigned long startTime= millis();
  while (analogRead(A0) > 300);  // 300 threshold to be tuned
  unsigned long duration = millis() - startTime;
  Serial.print("duration:\t ");
  Serial.println(duration);
  if (duration > 10000) // 10 seconds minimum value to be tuned
     // wait 30%
    // switch on Relay 100%
now it's your turn to finish it smiley-wink
Rob Tillaart
Manchester (England England)
Solder is electric glue
No.
Because a microphone gives you the whole audio waveform. It is only the size of the peaks that determin the loudness.
So you have to do one of a few things
Just filter out the peak readings.
Take an RMS value from a number of readings.
Have an envelope detector between your amplifier and the arduino's input.
No.
thanks both of you!!!
Is this working for that purpose?
http://wiring.org.co/learning/basics/microphone.html
Yes D1, R2 and C2 together form an envelope detector.
Just remembered now and thought i post my final code here:
int sensorValue;
boolean measuring = false;
boolean action = false;
unsigned long startTime;
unsigned long duration = 0;
unsigned long LEDStart;
const int threshold = 600;
  pinMode(12, OUTPUT);
  Serial.begin(9600);  // sets the serial port to 9600
  sensorValue = analogRead(0);       // read analog input pin 0
  delay(100);      // wait 100ms for next reading
  //Messung anfangen falls gerade nicht gemessen wird und die
  //Lautstaerke den Schwellwert ueberschreitet
  if(measuring == false && sensorValue >= threshold)  {
    measuring = true;
  //Messung beenden falls gemessen wurde und die Lautstaerke
  //den Schwellwert unterschreitet
  if(measuring == true && sensorValue < threshold) {
    measuring = false;
  Serial.print("sensorValue:\t ");
  Serial.println(sensorValue, DEC);
  //30% der gemessenen Zeit nichts machen
  delay(0.5*duration);
  //LED 100% der gemessenen Zeit aktivieren
  LEDStart = millis();
  while(millis() - duration < LEDStart) {
    digitalWrite(12, HIGH);
    if(!action) action = true;
  if(action) {
    digitalWrite(12, LOW);
    duration = 0;
    action = false;
    delay(10000);
sorry for german comments and maybe not the best style but i think everyone get it anyway smiley
