Loading...
Pages: [1]   Go Down
Author Topic: Float I2c  (Read 986 times)
WV
Offline Offline
Full Member
Arduino, Helps With the ADD
View Profile
Is there a nice simple way to Pass Float Value over I2C -to a second arduino-  (example 3.12 for Volts). All ive seen is elaborate unions and pointers ,, Seems WAY over complexe so i skipped reading further. Any thoughts/ideas /Examples/referances smiley ?
Logged
WV
Offline Offline
Full Member
View Profile
Wow thers a first, never had one with out some kind of responce smiley
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You need a union. You said you don't want to use one. Not much left to say. They are not particularly elaborate BTW.
Logged
WV
Offline Offline
Full Member
View Profile
Nick Gammon , you sem to the goto for I2C ,, have your had the chance to run "unions" before ?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
OK, here's how to do it. Based on the EEPROM_Anything idea I did this ...
I2C_Anything.h
Make a new tab in the IDE called "I2C_Anything.h". Put this in it:
Code:
// Written by Nick Gammon
// May 2012
#include <Arduino.h>
#include <Wire.h>
template <typename T> int I2C_writeAnything (const T& value)
    const byte * p = (const byte*) &value;
    unsigned int i;
    for (i = 0; i < sizeof value; i++)
          Wire.write(*p++);
    return i;
  }  // end of I2C_writeAnything
template <typename T> int I2C_readAnything(T& value)
    byte * p = (byte*) &value;
    unsigned int i;
          *p++ = Wire.read();
    return i;
  }  // end of I2C_readAnything
Now here is an example of sending a float and a long to a slave:
Master
Code:
// May 2012
#include <Wire.h>
#include "I2C_Anything.h"
const byte SLAVE_ADDRESS = 42;
  Wire.begin ();
}  // end of setup
 long foo = 42;
 for (float fnum = 1; fnum <= 10; fnum += 0.015)
    Wire.beginTransmission (SLAVE_ADDRESS);
    I2C_writeAnything (fnum);
    I2C_writeAnything (foo++);
    Wire.endTransmission ();
    delay (200);
    }  // end of for
}  // end of loop
And here is the slave:
Slave
Code:
// May 2012
#include <Wire.h>
const byte MY_ADDRESS = 42;
  Wire.begin (MY_ADDRESS);
  Serial.begin (115200);
  Wire.onReceive (receiveEvent);
}  // end of setup
volatile boolean haveData = false;
volatile float fnum;
volatile long foo;
  if (haveData)
    Serial.print ("Received fnum = ");
    Serial.println (fnum);
    Serial.print ("Received foo = ");
    Serial.println (foo);
    haveData = false;
    }  // end if haveData
}  // end of loop
// called by interrupt service routine when incoming data arrives
void receiveEvent (int howMany)
 if (howMany >= (sizeof fnum) + (sizeof foo))
   I2C_readAnything (fnum);
   I2C_readAnything (foo);
   haveData = true;
   }  // end if have enough data
 }  // end of receiveEvent
The template in the .h file will convert any data type (eg. float, int, long) into a pointer to a series of bytes and send (or receive) those one at a time via I2C.
Example output:
Code:
Received fnum = 6.52
Received foo = 410
Received fnum = 6.53
Received foo = 411
Received fnum = 6.55
Received foo = 412
Received fnum = 6.56
Received foo = 413
Received fnum = 6.58
Received foo = 414
Received fnum = 6.59
Received foo = 415
Received fnum = 6.61
Received foo = 416
Received fnum = 6.62
Received foo = 417
Received fnum = 6.64
Received foo = 418
Received fnum = 6.65
Received foo = 419
Received fnum = 6.67
Received foo = 420
« Last Edit: May 07, 2012, 07:01:32 pm by Nick Gammon » Logged
WV
Offline Offline
Full Member
View Profile
Holy Crap, Ty for the info -I would have never expected a complete sketch  tyvm smiley . Now i have to break it down to get the idea of how its works, then to incorporate into my increasingly growing sketch. thank you again smiley
« Last Edit: May 07, 2012, 07:25:34 pm by woody_unreal » Logged
Offline Offline
Newbie
View Profile
I'm having trouble using I2C_Anything with Wire.requestFrom, and any help would be greatly appreciated.
I'd like the master to request data from the slave, but all my floats arrive as nan .  I've tried sending individual bytes and it works.  I'm confident in my wiring because I can get I2C_Anything to work as written in this post.  There's something about how I'm using requestFrom which is breaking something!
Here are the files:
Master, an Uno which uses Wire.requestFrom to ask for the data
Code:
// Eric Rombokas
// Jan 3 2013
// Arduino is i2c master, arduIMU is i2c slave .  arduino dumps requested i2c data to serial
// Using gammon I2C_readAnything.h for translating I2C bytes to other data types
#include <math.h>
#include <Wire.h>
#include "I2C_writeAnything.h"
const int SLAVE_ADDRESS = 10;
volatile float volatileYaw;
  Wire.begin(); // begin with no address specified joins the bus as a master
  if (Wire.requestFrom(SLAVE_ADDRESS, 4, true) == 4) {
    I2C_readAnything(volatileYaw);
    Serial.println(volatileYaw);
And slave, which uses I2C_writeAnything in its requestEvent()
Code:
// Eric Rombokas
// Jan 3 2013
// ArduIMU runs as an i2c slave, querying freeIMU for yaw, pitch, roll when asked to by the i2c master
// Adapted from Fabio Varesano's FreeIMU_Yaw_pitch_roll RIP
// i2c float/byte stuff adapted from "WanaGo" on arduino forum
#include <ADXL345.h>
#include <bma180.h>
#include <HMC58X3.h>
#include <ITG3200.h>
#include <MS561101BA.h>
#include <I2Cdev.h>
#include <MPU60X0.h>
#include <EEPROM.h>
//#define DEBUG
#include "DebugUtils.h"
#include "CommunicationUtils.h"
#include "FreeIMU.h"
#include <Wire.h>
#include <SPI.h>
#include <math.h>
volatile float volatileYaw = 42.42;
const int I2CSlaveAddress = 10;
  Wire.begin(I2CSlaveAddress);
  Wire.onRequest( requestEvent ) ; // declare function handle to be called when i2c master requests
// called by onRequest interrupt
void requestEvent() {
  I2C_writeAnything(volatileYaw);
Any ideas?
Thanks,
Eric R
(edited to remove superfluous stuff)
« Last Edit: January 03, 2013, 06:51:34 pm by rombokas » Logged
Offline Offline
Newbie
View Profile
An update.  Sending multiple bytes at all during a requestEvent results in error.
I'm running on two Uno R3 arduinos.
Master uses requestFrom to ask for bytes.  If I ask for one, it works, but if I ever ask for more than 1, they come back corrupted.
Master code:
Code:
#include <Wire.h>
int numReceived = 0;
Wire.begin();        // join i2c bus (address optional for master)
  numReceived = 0;
  Wire.requestFrom(2, 2);
  while(Wire.available())
  byte c = Wire.read();
  Serial.print("Received: ");
  Serial.print(c);
  Serial.println(" . ");
  numReceived++;
  Serial.print(" Received ");
  Serial.print(numReceived);
  Serial.println(" bytes.  ");
Slave code:
Code:
#include <Wire.h>
byte val1 = 0;
byte val2 = 1;
Wire.begin(2);                // join i2c bus with address #2
Wire.onRequest(requestEvent); // register event
delay(100);
void requestEvent()
  Wire.write(val1);
  Wire.write(val2);
Output is :
Received: 1 .
Received: 255 .
 Received 2 bytes.
What is happening here?
-Eric
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Try this:
Code:
byte vals[2];
void requestEvent()
  vals[0] = 14;
  vals[1] = 172;
  Wire.write(vals, 2);
Logged
Offline Offline
Newbie
View Profile
Thanks for the reply!
It works correctly using the single call to Wire.write().  If I split it into two calls it fails:
eg
Code:
Wire.write(vals[0]);
Wire.write(vals[1]);
Produces
 Received 2 bytes.
Received: 172 .
Received: 255 .
Is there something about the Wire library that means only a single write() should be used in an interrupt?  I2C_writeAnything() uses multiple Wire.write() calls in a for-loop, so that would mean it can't be used in an onRequest handler.
Perhaps I could modify it to fill a byte array, then send using a single write() call, like this:
Code:
float someFloat = 1.2;
byte vals[4];
byte * p = (const byte*) someFloat;
unsigned int i;
for (i = 0; i < sizeof someFloat; i++)
  vals[i] = *p++;
Wire.write(vals, 4);
Or something like that?
-Eric
Logged
Offline Offline
Newbie
View Profile
That worked.
I added the following function to I2C_Anything.h
Code:
template <typename T> int I2C_singleWriteAnything (const T& value) {
  int size = sizeof value;
  byte vals[size];
  const byte* p = (const byte*) &value;
  unsigned int i;
  for (i = 0; i < sizeof value; i++) {
    vals[i] = *p++;
  Wire.write(vals, size);
  return i;
And it works perfectly, even in the onRequest handler.
Thanks 4.2 zillions!
Eric Rombokas
Logged
Pages: [1]   Go Up
Print
Jump to:
