Topic: Float I2c (Read 13801 times) previous topic - next topic
Steveiboy
Thanks chuck that should get me going, I will try it in the week
Once again for your support
Steveiboy
#16
Jun 15, 2015, 10:24 pm Last Edit: Jun 15, 2015, 10:25 pm by Steveiboy
I think I need to read up more, I've tried to add a second slave but it receives nothing from both salves
So I went back to basic with one salve
If I use this Wire.begin (SLAVE_ADDRESS_1); only with one slave it works
but if I just use this Wire.begin (); then nothing happens
tried to add this but same nothing comes through
Wire.begin (SLAVE_ADDRESS_2);
This is what I've tried
Code: [Select]
  uint8_t datalen = (sizeof foo) + (sizeof fnum); // get info from the First Slave
  Wire.requestFrom (SLAVE_ADDRESS_1, datalen, true);
  if (Wire.available() == datalen) { // got correct size of packet
    I2C_readAnything (fnum);
    I2C_readAnything (foo);
  Wire.requestFrom (SLAVE_ADDRESS_2, datalen, true);
  if (haveData)
    Serial.print ("Received 0x58 = ");
    Serial.println (fnum);
    Serial.println (foo);
   Serial.print ("Received 0x59 = ");
  haveData = false;
  }  // end if haveData
}  // end of loop
The other thing I'm struggling to understand is how to display the 4 floats are  displayed via the serial terminal as there are only one fnum and foo to send.
chucktodd
#17
Jun 16, 2015, 01:27 am Last Edit: Jun 16, 2015, 01:53 am by chucktodd Reason: forgot to attach I2C anything lib
Steveiboy,
  The Wire library has a problem.  When the onRequestevent() is triggered (inside ISR), the code only transmits the last Wire.write() data.  if your onRequestEvent() is like this:
Code: [Select]
void onRequestEvent(){
   Wire.write(1);
   Wire.write(2);
   Wire.write(3);
   Wire.write(4);
   Wire.write(5);
   Wire.write(6);
   Wire.write(7);
and the Master's code was
Code: [Select]
Wire.requestFrom(slave,7);
  while(Wire.available()){
     Serial.print(Wire.read(),HEX);
     Serial.print(' ');
the Monitor would print:
7 FF FF FF FF FF FF
Not what you expected right?
I changed the code in my library to fix this and another Issue.
C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\utility\twi.c
Code: [Select]
 * Function twi_transmit
 * Desc     fills slave tx buffer with data
 *          must be called in slave tx event callback
 * Input    data: pointer to byte array
 *          length: number of bytes in array
 * Output   1 length too long for buffer
 *          2 not slave transmitter
 *          0 ok
uint8_t twi_transmit(const uint8_t* data, uint8_t length)
  uint8_t i;
  // ensure data will fit into buffer
  //if(TWI_BUFFER_LENGTH < length){ // original
  if(TWI_BUFFER_LENGTH < (length+twi_txBufferLength)){ //chuck 15JUN2015
    return 1;
  // ensure we are currently a slave transmitter
  if(TWI_STX != twi_state){
    return 2;
  // set length and copy data into tx buffer
  //twi_txBufferLength = length; original
  for(i = 0; i < length; ++i){
  //  twi_txBuffer[i] = data[i]; original
    twi_txBuffer[twi_txBufferLength++] = data[i]; //chuck 15Jun2015
   return 0;
Appended are my update twi.c and two test Sketches that work.
Chuck.
Check out my Kickstarter Project Memory Panes an expansion RAM Shield for Mega2560's.  It adds 1MB of RAM for those projects where 8KB is not enough.
Currently built mega http server, Now converting it to ESP32.
Steveiboy
Wow, Thanks chuck this is a massive help, I've compiled and upload I now can send and receive data from both slaves, I will also learn loads more by reading through your code and playing with it.
I shall now study and play around with the code.
Hopefully I can get it working. I see when I ground A0 it just receives  data from slave one only I will try and get it to read both slaves and display both slaves with different values.
many thanks for your time and help
Steve
chucktodd
#19
Jun 16, 2015, 08:51 pm Last Edit: Jun 16, 2015, 08:52 pm by chucktodd
Steve
Now for one more complication.  You do realize that an arduino can be both a Master and a Slave at the same time?
just add the onRequest, onReceive events to the Master Sketch, change the Wire.begin() in the Master to Wire.begin(thirdslaveaddress);add the Wire.onReceive(),onRequest(). One more thing, put the volatile prefix on fnum, and foo.  They will now be access in a ISR.
Now one proviso, The master CANNOT talk to itself  successfully.  if you put this new sketch into multiple Arduino's you could have them access each other.
If you added this complexity you would need to start monitoring the results from endTransmission(), requestFrom().  your transfers might get aborted if the transaction looses arbitration.  you could no longer assume the master will always suceed.
multiple Master can be on the bus at the same time.  Two masters can talk to the same slave at the same time.  The master that wins is the one that transfers a byte with a low bit first.
Here is a good reference on the I2C buss  Philips Electronics I2C Specs
Chuck.
Steveiboy
I'm making progress but the foo value is not increasing as I though it would here is the codes, might be a bit messy and a better way of doing it but it's working(I will tidy up code in a bit) I'm doing it as building blocks as I want to measure a voltage from 4 locations and send it to one unit but first thought make sure it send float values, My ADC code works so I think it's just the case of adding it bit by bit
Master
Code: [Select]
#include <Wire.h>
#include <I2C_anyThing.h> // Template from Nick Gammon
long fnum;   // volatile Not Need because variable will be Not be accessed during an interrupt ISR
float foo;   //  same thing.
long fnum1;
long foo1;
#define DATALEN (sizeof fnum) + (sizeof foo)
#define SLAVE_ADDRESS_1 0x58   // slave 1change this for each slave
#define SLAVE_ADDRESS_2 0x59   // slave 2
  Wire.begin();  // not a slave
  Serial.begin(9600); // if USB is connected to this slave and Serial monitor is on
  //we will send debug messages.
void debug_out( char msg[]) {
  Serial.println(msg);
  Serial.print("foo=");
  Serial.println(foo);
  Serial.print("fnum=");
  Serial.println(fnum);
  Serial.println("**************");
  slave_one();
  slave_two();
float slave_one() {
  Wire.requestFrom(SLAVE_ADDRESS_1, DATALEN);
  if (Wire.available() == DATALEN) {
    I2C_readAnything(fnum);
    I2C_readAnything(foo);
    debug_out("SLAVE ONE");
  else debug_out("Tried to Read from Slave 1, Failed.");
float slave_two() {
  Wire.requestFrom(SLAVE_ADDRESS_2, DATALEN);
    debug_out("SLAVE TWO");
Slave_one (two is the same apart from address and values)
Code: [Select]
#include <Wire.h>
volatile long fnum; // volatile because variable will be accessed during an interrupt ISR
volatile float foo;  //  same thing.
volatile uint8_t newData; // flag to detect I2C activity
#define SLAVE_ADDRESS 0x58   // change this for each slave
void onRequestEvent(void) {
  /* Wire.write(1);
   Wire.write(2);
   Wire.write(3);
   Wire.write(4);
   Wire.write(5);
   Wire.write(6);
   Wire.write(7);
   Wire.write(8);
  I2C_writeAnything(fnum);
  I2C_writeAnything(foo);
  // newData = newData | 1; // set bit 0 to mark I2C Sent data
void onReceiveEvent(int numbytes) {
  if (numbytes == DATALEN) { // Masters beginTransmission(SLAVE_ADDRESS);Write();endTransmission();
    // sent the correct number of bytes
    // newData = newData | 2; // set bit 1 to mark I2C Received Data.
  //newData = 0;
  Wire.begin(SLAVE_ADDRESS);
  Wire.onReceive(onReceiveEvent);
  Wire.onRequest(onRequestEvent);
  foo = 12.36 + 0.01;
  fnum = 24;
Why  is not the foo value increasing ?
Steveiboy
#21
Jun 16, 2015, 09:05 pm Last Edit: Jun 16, 2015, 09:32 pm by Steveiboy
Chuck.
I did think about that but not was 100% sure about it, Now you got me worried and think may have bit of more than I can chew but the main ting is I'm having fun it seems to be working ok here a sample of the data coming in
Code: [Select]
SLAVE ONE
foo=12.37
fnum=24
SLAVE TWO
foo=12.36
fnum=50
SLAVE ONE
foo=12.37
fnum=24
SLAVE TWO
foo=12.36
fnum=50
SLAVE ONE
foo=12.37
fnum=24
SLAVE TWO
foo=12.36
fnum=50
SLAVE ONE
foo=12.37
fnum=24
SLAVE TWO
foo=12.36
fnum=50
Thanks for the link it will be interesting bedtime reading :-)
EDIT... I got it counting set foo to read 12.36 then in the loop I added foo = foo + 0.01;
chucktodd
Feels good when you figure it out :smiley-mr-green:
Enjoy!
 Chuck.
ha2709
Steveiboy,
Code: [Select]
   Wire.write(1);
   Wire.write(2);
   Wire.write(3);
   Wire.write(4);
   Wire.write(5);
   Wire.write(6);
   Wire.write(7);
Code: [Select]
     Serial.print(' ');
7 FF FF FF FF FF FF
Code: [Select]
 *          0 ok
  uint8_t i;
    return 1;
    return 2;
   return 0;
Chuck.
i'm the new, how to do with your library and the twi file. Thanks
Steveiboy
I've started to play around again with this again, Not sure what's happened as the last time it was working but now I just get it displaying -1 and nan on the LCD and serial port, I've done nothing to the code since it was working last time other than reloaded it into the board's. I'm only using one slave at the moment and highlighted out slave two if/when I get it working I will see about adding 3 other slaves.
I'm using version 1.67 and replaced the twi.c file as I did the last time to get it working when I add the same issue with the previous version of the IDE
Master code
Code: [Select]
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
float fnum;   // volatile Not Need because variable will be Not be accessed during an interrupt ISR
long foo;   //  same thing.
float fnum1;
float foo1;
  lcd.begin (20,4); // for 16 x 2 LCD module
  lcd.setBacklightPin(3, POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.clear();
lcd.setCursor(0, 0);
lcd.print(foo);
  lcd.print("  ");
  lcd.setCursor(0, 1);
  lcd.print(fnum);
  lcd.print("  ");
void debug_out1( char msg1[]) {
  Serial.println(msg1);
  Serial.println(foo1);
  Serial.println(fnum1);
lcd.setCursor(0, 2);
lcd.print(foo1);
  lcd.print("  ");
  lcd.setCursor(0, 3);
  lcd.print(fnum1);
  lcd.print("  ");
  slave_one();
 // slave_two();
 delay(200);
float slave_one() {
float slave_two() {
    I2C_readAnything(fnum1);
    I2C_readAnything(foo1);
    debug_out1("SLAVE TWO");
  else debug_out1("Tried to Read from Slave 2, Failed.");
Slave code
Code: [Select]
#include <Wire.h>
const int numReadings = 10;
int readings[numReadings];      // the readings from the analog input
int readIndex = 0;              // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
float vout = 0.0;
int inputPin = A0;
volatile float fnum; // volatile because variable will be accessed during an interrupt ISR
volatile long foo;  //  same thing.
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
  /* Wire.write(1);
  Wire.write(2);
  Wire.write(3);
  Wire.write(4);
  Wire.write(5);
  Wire.write(6);
  Wire.write(7);
  Wire.write(8);
  newData = 0;
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
  // subtract the last reading:
  total = total - readings[readIndex];
  // read from the sensor:
  readings[readIndex] = analogRead(inputPin);
  // add the reading to the total:
  total = total + readings[readIndex];
  // advance to the next position in the array:
  readIndex = readIndex + 1;
  // if we're at the end of the array...
  if (readIndex >= numReadings)
    // ...wrap around to the beginning:
    readIndex = 0;
  // calculate the average:
  vout = total / numReadings;
  foo = (vout * 5.0) / 1024.0; // see text
  fnum = 12;
  delay(200);
chucktodd
Master code
Code: [Select]
#include <Wire.h>
float fnum1;
float foo1;
  lcd.clear();
lcd.print(foo);
  lcd.print("  ");
  lcd.print(fnum);
  lcd.print("  ");
lcd.print(foo1);
  lcd.print("  ");
  lcd.print(fnum1);
  lcd.print("  ");
  slave_one();
 // slave_two();
 delay(200);
float slave_one() {
float slave_two() {
Slave code
Code: [Select]
#include <Wire.h>
float vout = 0.0;
int inputPin = A0;
  /* Wire.write(1);
   Wire.write(2);
   Wire.write(3);
   Wire.write(4);
   Wire.write(5);
   Wire.write(6);
   Wire.write(7);
   Wire.write(8);
  newData = 0;
    readIndex = 0;
  fnum = 12;
  delay(200);
Steveiboy,
 I haven't looked at any of the newer Arduino's past 1.65,  you should install the newest version and compare my version of twi.c with the 'new' library, all of my edits are commented, you should be able to see the differences.
Also,I changed Wire.h, Wire.cpp, and twi.c.  if you just updated twi.c I can see where this problem would rear it's head.  In the Wire.write() is were the buffer count is overwritten if the write() is during a onRequest() event.
Instead of overwriting twi.c inside of the Arduino environment, just use the Arduino Environment to install whole modified Wire library.
Sketch\include Library\add .Zip Library...
That way, you can easily remove it by just deleting the whole subdirectory.
The Arduino environment will create a directory {sketchesFolder}\libraries\Wire
My {sketchesFolder} happens to be "C:\Users\User\Documents\Arduino".
When you have My wire library install, any sketch that uses Wire will display this warning when it is compiled:
Code: [Select]
Multiple libraries were found for "Wire.h"
 Used: C:\Users\user\Documents\Arduino\libraries\Wire
 Not used: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
Your locations may be different, mine are under 32bit Win7.
Chuck.
Steveiboy
Something has changed from version 1.60 to 1.67,1.69,
Chuck I've tried what you said with 1.67 and 1.69 installed your files but both programs will not complie I get errors, I deleted the library and they complie. I uninstalled 1.69 and re-installed 1.60 copied only the twi file over and everything is working like it was before. Strange, I will re-install 1.69 tomorrow and copy the errors as I could not understand the errors. I think it's something  to do with the I2Canything library
As its late here I will continue tomorrow
Thanks for your help
Steve
chucktodd
Steve
Steve,
  Look in my Wire.h,  I included Nick Gannons I2C_anything. You probably don't need to re include his templates.
Chuck.
Steveiboy
Steve,
Chuck.
Hi Chuck
Sorry for the delay and late reply, I had some time and got back onto this project and I've managed to get it working the way you said, The new errors where caused by including the I2C_writeanything still been there I removed this and it now compiles and is working I will add the 3 other salves later and see how it goes
thanks for your help
