Loading...
Pages: [1]   Go Down
Author Topic: Error with VB2010  (Read 574 times)
Offline Offline
Newbie
View Profile
Hello,
I have the Arduino send values back to VB2010 and depending on the value, it will be displayed in a different label.
Below is my VB code:
Code:
    Sub EventHandler(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles SerialPort1.DataReceived
        Dim datareceived As Boolean = False
        Dim recStr As String = ""
        While Not datareceived
            Dim recVal As Integer
            recVal = SerialPort1.ReadByte()
            If recVal = 10 Or recVal = 13 Then
                datareceived = True
            Else
                recStr = recStr + Chr(recVal)
            End If
        End While
        If recStr <> "" Then
            If recStr > 1000 Then
                recStr = recStr - 1000
                Label10.Text = recStr
            End If
            If recStr > 100 And recStr < 1000 Then
                Label4.Text = recStr
            End If
            If recStr < 0 Then
                recStr = recStr * (-1)
                Label8.Text = recStr
            End If
            If recStr > 0 And recStr < 10 Then
                recStr = recStr
                Label6.Text = recStr
            End If
            If recStr > 10 And recStr < 100 Then
            End If
        End If
    End Sub
If I use a message box then the variable is displayed correctly. but when I try to display the variable on a label I get an error.
Anybody knows why??
Thanks for your help.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
And that error is?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
But, recStr is a String. What does a String greater than 1000 mean?
I think you need to convert the String to a number, if possible, and compare and manipulate that number.
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
I thought VB (particularly in later versions) let you do things like that.
Logged
Belgium
Offline Offline
Full Member
View Profile
WWW
yes it does, but you have to insert an error check, otherwise the program will error if you type anything that is not a number...
i tried it with a button instead of datareceived and it all worked fine, so i don't see why it shouldn't work with datareceived
It changes the labeltext as you want, and does not throw any error
« Last Edit: May 02, 2012, 03:37:41 pm by Steen » Logged
Offline Offline
Newbie
View Profile
Here is the error that I get: "Cross-thread operation not valid: Control 'Label4' accessed from a thread other than the thread it was created on."
With a button it works fine!
but the way I want to use, it does not work at all!
Any ideas??
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Any ideas??
Sure. The error message is telling you EXACTLY what is wrong.
Quote
The thread that does the serial reading has to Invoke() the thread that manages the GUI. Hit the help pages for how to do this in VB. I could tell you for C#, but that wouldn't help you.
Logged
Belgium
Offline Offline
Full Member
View Profile
WWW
did you manage to solve this problem already?
Logged
Copenhagen / Denmark
Offline Offline
Edison Member
Do it !
View Profile
WWW
You need to check up on using delegates because the code that handles the serial comm. is running in another thread than he code updating the UI.
This might point you in the right direction:
mikmo.dk/misc/vbarduino.zip
Not the most elegant code, but it works.
Logged
Pages: [1]   Go Up
Print
Jump to:
