I made this program that reads the button responses and sends them to the pc as a usb keyboard. it runs the way you did, and it runs perfectly fine... the code may not be the most clean one, but it does its job
#include "UsbKeyboard.h"
double cnt = 0;
int btnPin = 0;
double pauseCnt = 0;
boolean printCode = true;
int ledPin = 13;
int recPin = 1;
int psLengthPin = 6;
int psLengthPot = A0;
int dashLengthPot = A1;
double spd = 1;
double dashLength = 1;
boolean setSpd = true;
int buzzPin = 3;
int recCode[6] = {0,0,0,0,0,0};
int recPlace = 0;
int morseLts[246] = {/*A*/1,2,0,0,0,0 , /*B*/2,1,1,1,0,0 , /*C*/2,1,2,1,0,0 , /*D*/2,1,1,0,0,0 , /*E*/1,0,0,0,0,0 , /*F*/1,1,2,1,0,0 , /*G*/2,2,1,0,0,0 , /*H*/1,1,1,1,0,0 , /*I*/1,1,0,0,0,0 , /*J*/1,2,2,2,0,0 , /*K*/2,1,2,0,0,0 , /*L*/1,2,1,1,0,0 , /*M*/2,2,0,0,0,0 , /*N*/2,1,0,0,0,0 , /*O*/2,2,2,0,0,0 , /*P*/1,2,2,1,0,0 , /*Q*/2,2,1,2,0,0 , /*R*/1,2,1,0,0,0 , /*S*/1,1,1,0,0,0 , /*T*/2,0,0,0,0,0 , /*U*/1,1,2,0,0,0 , /*V*/1,1,1,2,0,0 , /*W*/1,2,2,0,0,0 , /*X*/2,1,1,2,0,0 , /*Y*/2,1,2,2,0,0 , /*Z*/2,2,1,1,0,0 , /*1*/1,2,2,2,2,0 , /*2*/1,1,2,2,2,0 , /*3*/1,1,1,2,2,0 , /*4*/1,1,1,1,2,0 , /*5*/1,1,1,1,1,0 , /*6*/2,1,1,1,1,0 , /*7*/2,2,1,1,1,0 , /*8*/2,2,2,1,1,0 , /*9*/2,2,2,2,1,0 , /*0*/2,2,2,2,2,0 , /*enter*/ 2,1,1,1,2,1, /*esc*/ 2,1,2,2,1,1, /*bcksp*/ 1,2,2,1,1,2 , /*tab*/ 1,1,2,2,0,0 , /*space*/1,2,1,2,0,0};
pinMode(btnPin, INPUT);
digitalWrite(btnPin, HIGH);
pinMode(ledPin, OUTPUT);
digitalWrite (ledPin, HIGH);
pinMode(recPin, OUTPUT);
digitalWrite(recPin, LOW);
pinMode(psLengthPin, INPUT);
digitalWrite(psLengthPin, HIGH);
pinMode(buzzPin, OUTPUT);
digitalWrite(buzzPin, LOW);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
digitalWrite(8, HIGH);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
TIMSK0&=!(1<<TOIE0);
cli();
usbDeviceDisconnect();
delayMs(250);
usbDeviceConnect();
sei();
UsbKeyboard.update();
if(digitalRead(psLengthPin) == LOW) {
spd = map(analogRead(psLengthPot), 0, 1024, 500, 10000);
dashLength = map(analogRead(dashLengthPot), 0, 1024, 1000, 40000);
//getSpd(spd);
else if(digitalRead(btnPin) == LOW) {
setSpd = true;
cnt++;
pauseCnt = 0;
printCode = true;
digitalWrite(buzzPin, HIGH);
else {
pauseCnt++;
if(cnt>(100)) {
if(cnt<(dashLength/3)) {
//Serial.print(cnt);
//Serial.println("\tDot");
if(recPlace<6) {
recCode[recPlace] = 1;
recPlace++;
else if(cnt<dashLength) {
//Serial.println("\tDash");
if(recPlace<6) {
recCode[recPlace] = 2;
recPlace++;
if(pauseCnt>=spd && printCode) {
printCode = false;
int checkVal = 0;
int placeBuff = 0;
boolean maySpace = true;
for(int i=0; i<=240; i+=6) {
checkVal = 0;
for(int j=0; j<=5; j++) {
if(recCode[j]==morseLts[i+j]) {
checkVal++;
else {
checkVal = 0;
if(checkVal == 6) {
digitalWrite(recPin, HIGH);
//Serial.print((char)(97 + (i/4)));
UsbKeyboard.sendKeyStroke(4+(i/6));
digitalWrite(ledPin, !digitalRead(ledPin)); // Toggle status LED
checkVal = 0;
//maySpace = false;
if(maySpace) {
for(int i=0; i<=5; i++) {
if(recCode[i] == morseLts[154+i]) {
//Serial.print(" ");
checkVal++;
if(checkVal == 6) {
UsbKeyboard.sendKeyStroke(44);
recCode[i] = 0;
recPlace = 0;
cnt = 0;
void delayMs(unsigned int ms)
for (int i = 0; i < ms; i++) {
delayMicroseconds(1000);
int getSpd(int nr) {
digitalWrite(8, LOW);
if(nr>=0 && nr<1) {
} else if(nr>=1 && nr<2) {
digitalWrite(9, HIGH);
} else if(nr>=2 && nr<=3) {
digitalWrite(10, HIGH);
it reads the values from 2 potmeters as length from dash/dot and length of the pause between two letters. this way you can set it up completely the way you want, at every speed you want. There is this led that flashes when the char is recognized, and the buzzer buzzes as long as you press the button
