Topic: Simplest AM radio receiver (Read 15614 times) previous topic - next topic
adilmalik
I'm trying to understand how am radios work. But i dont understand the most basic and fundamental parts required for reception of am radio. can some one help me out by telling me how to make the simplest AM receiver and please explain LC circuits.
Thanks!
Erni
http://en.wikipedia.org/wiki/Crystal_radio
adilmalik
i just saw the circuit shown in wiki, can i feed the audio output to a op amp instead of using crystal earphones?
RandallR
adilmalik
So basically i need an antenna, a LC circuit that resonates at the required frequency, a diode (can i use any rectifier diode?), a opamp and earphones?
Grumpy_Mike
Yes that is all you need.
If you wind the coil on a ferrite rod, you can tune the radio by sliding the rod in and out of the coil.
adilmalik
Okay, so how can i calculate the number of turns i need to wind round the core?
adilmalik
so in the lc circuit i can either keep a variable cap or a variable inductor?
Grumpy_Mike
One over two Pi root LC gives you the resonant frequency. (sing it)
The number of turns depends on a lot of things like the diameter.
If you just want to try for medium wave wind 40 turns.
Make the C about 200pF.
adilmalik
can i used a fixed 200uh inductor and just vary the cap? of does it have to be the inductor.
Thanks again
runaway_pancake
Yes!
Most car radios used to use a variable inductor, less subject to drift vs. temperature compared to a variable capacitor.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
adilmalik
Okay i think i understand now. So the resonant frequency of my LC circuit should cover the AM range?
Grumpy_Mike
This shows you step by step from just household items.
http://scitoys.com/scitoys/scitoys/radio/homemade_radio.html
You can but will be able to pick up more stations if you use a germanium diode in place of a rectifying silicon one.
Yes
adilmalik
thank you again, i finally understand this. 1 more question please, now i know that LC circuits are used during reception of Am but are they also used to transmit RF? example: if i transmit a blank carrier wave and connect it to a LC circuit?
Grumpy_Mike
They can be if they are part of the oscillator that generates the carrier.
If you have something like a crystal oscillator then you don't need them.
