Topic: Xbee to Xbee - communication failure (Read 1 time) previous topic - next topic
tyraki
May 09, 2012, 09:33 am Last Edit: May 10, 2012, 09:07 am by tyraki Reason: 1
Hi , this is my last school year and i'm working with arduino and xbee for my project. ive got 2 arduino uno's and 2 xbee schields .
i'm making a boat , so i have a boat with 2 motors in it , and a remote control . each has 1 uno and 1 xbee.
i'll made 2 programs 1 program that reads 2 potentiometers , and calculates the speed.. this works pretty good , when i open serial monitor and i move one of the potentiometers its sends serial information : (L249R249)
L & R are the left and right motor , so this is what i wanted .
 //Declaratie
 int analogPin1 = 4;
 int analogPin2 = 5;
 int dL = 0;
 int dR = 0;
 int linksemotor = 0;
 int rechtsemotor= 0;
 int analogL = 5;
 int analogR = 6;
 int snelheidBegin = 0;
 int richtingBegin = 0;
void setup()                          // toekennen functie van de I/O
 pinMode(analogPin1, INPUT);
 pinMode(analogPin2, INPUT);
 pinMode(analogL,OUTPUT);
 pinMode(analogR,OUTPUT);
 Serial.begin(9600);                 // initializeer de seriele communicatie
 }                                   // einde van void setup
   int snelheid = map(analogRead(analogPin1), 0, 1023, 0, 499);
   int richting = analogRead(analogPin2);
   if (abs(snelheidBegin - snelheid)> 2 || abs(richtingBegin - richting)>2)
   snelheidBegin = snelheid;
   richtingBegin = richting;
   if ((richting > 499) && (richting < 524)) {
   dL = 0;
   dR = 0;
   else if (richting < 500)  {
   dL = 499 - richting;
   else {
   dR = richting - 524;
   if (dL > snelheid){
   dL = snelheid;
   if (dR > snelheid){
   dR = snelheid;
   linksemotor = snelheid - dL;
   rechtsemotor = snelheid - dR;
   Serial.print("(");
   Serial.print("L");
   Serial.print(linksemotor/2);
   Serial.print("R");
   Serial.print(rechtsemotor/2);
   Serial.print(")");
   delay (50);
   }                                 // einde van   if(snelheidBegin != snelheid || richtingBegin != richting)
 }                                   // einde van voidloop
in mij other arduino i have another program that must recieve this information and use it with PWM to control the motors of the boat
when i open serial monitor , and i type : (L0R249)
the left motor stand still , and the right motor is rotate at his max speed , i can type every singal , it works fine.
 //Declaratie
#include <math.h>
int PWMout1 = 5;
int PWMout2 = 6;
String inputString = "";         //
String strL = "";                //
String strR = "";
int charCount = 0;               //
unsigned long valL = 0;          //
unsigned long valR = 0;
int L = 0;                       //
int R = 0;                       //
int E = 0;
boolean stringComplete = false;  //
char STX = '(';
char ETX = ')';
 pinMode(PWMout1, OUTPUT);
 pinMode(PWMout2, OUTPUT);
 // reserveer 200 bytes voor de inkomende string
 inputString.reserve(200);
 if (stringComplete)
   Serial.println(inputString);
   Serial.println(charCount);
   L = inputString.indexOf("L");
   R = inputString.indexOf("R");
   E = inputString.indexOf(")");
   Serial.print("posities LR: l");
   Serial.print(L);
   Serial.print("r");
   Serial.print(R);
   strL = inputString.substring(L+1,R);
   strR = inputString.substring(R+1,E);
   valL = convertString2int(strL);
   valR = convertString2int(strR);
   Serial.println(strL);
   Serial.println(strR);
   Serial.println(valL);
   Serial.println(valR);
   Serial.println("the end");
   analogWrite(PWMout1,valL);
   analogWrite(PWMout2,valR);
   inputString = "";
   strL = "";
   strR = "";
   charCount = 0;
   valL = 0;
   valR = 0;
}                                    // einde van void loop
void serialEvent ()
 while (Serial.available())
   // read the new byte
   char inChar = (char)Serial.read();
   // add the byte to inputString
   inputString += inChar;
   // increment charCount with 1
   charCount = charCount+1;
   // if the incoming character is a ')', set a flag
   // so the main "loop" can start parsing inputString.
   if (inChar == ETX)
   {stringComplete = true;}
}                                 // einde van void serialEvent
unsigned long convertString2int(String x)
 Serial.println();
 Serial.print ("start converting ");
 Serial.print (x);
 Serial.print (" to int - length =");
 unsigned long addVal=0;
 unsigned long sum=0;
 unsigned long result=0;
 unsigned long digit = 0;
 unsigned long length = x.length();
 unsigned long tenPow =1;
 Serial.println (length);
for (unsigned long i=0; i<length ; i++)
  Serial.print ("tenPow = ");
  Serial.println (tenPow);
  Serial.print ("loop: ");
  Serial.print(i);
  Serial.print (" - digitStr: ");
  String digitStr = x.substring(length-(i+1),(length+1)-(i+1));
  Serial.print(digitStr);
  if(digitStr == "0")digit=0;
  if(digitStr == "1")digit=1;
  if(digitStr == "2")digit=2;
  if(digitStr == "3")digit=3;
  if(digitStr == "4")digit=4;
  if(digitStr == "5")digit=5;
  if(digitStr == "6")digit=6;
  if(digitStr == "7")digit=7;
  if(digitStr == "8")digit=8;
  if(digitStr == "9")digit=9;
  Serial.print (" - digit: ");
  Serial.print (digit);
  addVal = round (round (tenPow)*round(digit));
  Serial.print (" - addVal: ");
  Serial.print (addVal);
  Serial.print (" - former result ");
  Serial.print (sum);
  sum = round (addVal + round(sum));       //
  Serial.print (" - new result ");
  Serial.println (sum);
  tenPow = round(tenPow * 10);             //
     result = sum;
 return result;
but when i put the jumpers on xbee , and try the programs , nothing moves , the recieve LED  on the arduino with motors isn't on or blinking ...
i already configurated the xbee's with ctu and i tested with this program and its worked : http://arduino.cc/it/Guide/ArduinoXbeeShield
so i dont get it .. i got the right information to send , my recieve program works perfect , my xbee's are configurated perfect , the test program works but al together it dont ..
i hope someone knows why ..
already thanks & grtz from belgium !
PaulS
Don't you use capital letters to start sentences in Belgium? Or, is your shift key broken?
I'm going to do my Karmac the Magnificent impression, and say it's line 78 that needs to be changed.
If, rather than guesses, you want some real help, then posting your code might be a good idea.
tyraki
I added the code , excuse me :)
PaulS
On the sender, you use Serial.print() to send to the receiver and the Serial Monitor.
On the receiver, you use Serial.print() to send to the sender and the Serial Monitor.
What you see on the Serial Monitor(s)?
