Topic: help on dual dc supply (Read 2978 times) previous topic - next topic
winner10920
I just got some things im not sure about, sorry I don't have any pictures/shematics, my phone can't upload
So I want to build a decent +/-12v supply
I've got two 120vac to 12vac 5amp transformers which I plan on using instead of one center tapped one, will this work the same? I don't remember off hand if they had dots on them but I would have the dot side of one connecte to the non dot side of the other, and that would be the ground reference right? Can I connect this to actual ground?
I've had a hard time finding a good shematic for rectifying the +/-, one I saw had one full bridge rectifier another had two but it seemed sketchy
what's the difference and is one better/possible than the other ?
any links to a good design would be great
johnwasser
Yes, two 12V transformers can be wired to act as a center-tapped 24V transformer.
Full-wave rectifiers will produce lower ripple than half-wave rectifiers.
You'll need +12V and -12V regulators (if you want regulated voltage) and filter capacitors.
winner10920
But all I need is one full wave rectifier right? I got these nice ics that I forget the name of, basically lm317's but rated for 5amps, which I imagine will be my max output anyway
I just gotta get a negative regulator I guess
johnwasser
One full-wave rectifier per power supply so you need two.
MarkT
Usually you'd use a bridge-rectifier, with + and - outputs going to your two smoothing capacitors.  Transformer centre-tap is 0V.
winner10920
Yeah that's the confusing part, I've seen shematic for with one and with two, any reason to use two not one?
MarkT
For centre-tapped circuits one bridge rectifier = two full-wave rectifiers = four diodes = sufficient.
winner10920
Now if I were to use two positive regulators would I need to change my setup? I got my two tranformers, one full bridge and like +/- 15v unloaded, almost exactly 12.1v +/- with a load, but I need it to be 12v all the time : /
MarkT
Yes, you'd need those two separate transformer windings and 2 bridge rectifiers and connect the output +ve side of one regulator to ground on the other...  Considerably less satisfactory arrangement than one regulator of each polarity.
If you are saying the output _without a regulator_ is dropping to 12.1V under load, then you haven't enough voltage to support 12V regulators (typically they need 1.5 to 2V of "headroom".   It might be that your smoothing capacitors are too small, it might be the transformer windings are too low a voltage or it might be the transformers need a higher power (VA) rating.
winner10920
I measured that before. I had the the bridge actually I forgot to mention, unfortunetly they are 12v transformers from highhats actually and are meant to supply 12vac up to 5 amps
now that I think about it I guess I can't get 12v, gonna definetly have to get adjustable regulators and put it to like 10v
But then again maybe after the caps itll handle it since that 12v ac is almost 16vdc, and that's under load, ill get probably 18/19 volts not loaded
and just a related question to the regulators, is it better to have big caps before or after the regulator?
Grumpy_Mike
Both are good but the biggest caps go before the regulator.
winner10920
Ok, I had some bigger caps and smaller ones, I put the big ones on already and I didn't do the regulator yet so that works out,
winner10920
About the mains ground and my "ground", is it safe to connect these two? In the future I wanna put my supply in some sort of housing and am gonna ground it from the mains if I can
I looked at my supply with my oscope and I get a sine wave unless I attack the probe ground to my ground so I guess obviously its safe since I believe the probe ground is the mains ground as well?
elandd2011
this is a good solution
Grumpy_Mike
Personally I would not do this because it restricts how you can use your power supply. Leaving the output floating allows you to do things like use it as a negitave supply.
I do not think it is any safer.
