Topic: Wire library enables internal pull-ups -> bad for 3.3V I2C devices. (Read 5590 times) previous topic - next topic
nickgammon
There would be a bit of a danger if a 3.3V I2C device lets the line go high (by going high impedance) the line will only reach 3.3V if you pull-up to 3.3V and not 5V. Thus, although the Atmega running at 5V will read that as a high, it is only just (it registers high at above 2.7V) - page 412 of datasheet. You would need a reasonably powerful (ie. low) pull-up resistor to make sure it reached that level quickly enough.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
jepjep
Hello,
I am a student (but 48 yo!) just beginning to work with Arduinos. I am in this situation, too: a 5 V Arduino to connect to a 3.3 V device through I2C, so I designed a circuit with 3.3 V pull-up resistors.
The "easy" solution to disable internal pull-up, as reported, was to comment out disable Arduino internal pull-ups enable in twi_init().
What I have done is adding a new parameter in Wire.begin() wich allows enabling (default) and disabling pull-up resistors in the way that begin function is back-compatible.
I've had to modify Wire.h, Wire.cpp, utility/twi.h, utility/twi.c:
Example:
#include <Wire.h>
 // new parameter: WIRE_DISABLE_PULLUPS WIRE_ENABLE_PULLUPS
 Wire.begin(WIRE_DISABLE_PULLUPS); //start Wire with pullups disabled
 // Previous library version works as usual:
 // Wire.begin(); //start Wire with pullups enabled (default case)
 // and can be called this way, too:
 // Wire.begin(WIRE_ENABLE_PULLUPS);
// The 'begin' implementation makes Wire.begin(address) works as usual
// but it can be called too as: Wire.begin(address, WIRE_DISABLE_PULLUPS)
Attached you will find Wire library with this new specification/proposal.
Regards,
Josep
