Topic: Dumping firmware/software...and/or reflashing?? (Read 45617 times) previous topic - next topic
bag06a
Does the tactile button have no function now then? Also They way u described your programming mode it sounds similar to the x7 classic. Do u have classic or phenom?
mikedehaan
I have a Phenom X7.   I decided to change the programming around a little because I don't want to have to whip out a special tool to get to programming.  I was planning on using the button for "reset to factory default" (e.g.  on startup, hold the button for 5 seconds to reset the board).
Also, just a warning, I have not tested this latest code on the actual board yet.  I hope to get to that this weekend.  I'm mostly worried about the red LED.  Everything else has already been proven.
mikedehaan
Hahaha, well...my plans were foiled.  I just tested out the new build in the full system and found that you cannot hold the trigger down and switch from the "F" position to "FA" (to turn on the board).  So I switched the programming to use the pushbutton rather than the trigger to enter programming mode.
Other than that, I made some tweaks to Auto-Response and the new build mostly works.  I say mostly because successBlink is not working for some odd reason.  I'm baffled why it is not working on the board when it does on the testbed, but I'll figure that out later.  successBlink is supposed to blink green + red three times to indicate that your changes have been saved to the EEPROM.
I'm starting a google code project with everything I do.  I expect to put documentation, pictures, videos, etc up there.
http://code.google.com/p/phenomx7-etrigger/
If you'd like to contribute to some of the documentation etc, let me know.  I think all I need is an email address of yours to set you up.
From this point forward, new code and builds will be posted there.
Cainxxx
Hello mikedehaan, any news about your firmware?
What things I need to flash my phenom with your firm?
Correct me if I'm wrong:
1) ATTINY44A-PU
http://www.ebay.com/itm/2x-8-bit-Microcontroller-ATTINY44A-PU-/221023275589?pt=LH_DefaultDomain_2&hash=item3376038a45
2) PROGRAMER
http://www.ebay.com/itm/ATtiny24A-SSU-ATtiny24-ATtiny44-ATtiny84-AVR-SOIC14-150-mil-Programming-Adapter-/261012681784?pt=LH_DefaultDomain_0&hash=item3cc5917438
3) Your HEX File
I need desolder the original chip from my board? or exist the posibility to program it directly in the board? Or is read only?
Your work is awesome!
Sorry for my very poor English... (Entiendes espaƱol?)
mikedehaan
Yes!  I post updates for the firmware at the google project wiki.  A new version was uploaded last night.  Check it out here:
http://code.google.com/p/phenomx7-etrigger/wiki/Home
1) ATTINY44A-PU
You do not need to buy a chip (unless you want to develop for the project).  The instructions on the wiki (the link above) will show you how to apply the new firmware directly to the chip inside your eGrip without desoldering.
2) PROGRAMER
This programmer looks like it will do the job, but it quite a bit more expensive than what you will need.  The programmer I used was:
http://www.amazon.com/SainSmart-Programmer-ATMEL-ATMega-ATTiny/dp/B0051SRZWC/ref=sr_1_1?ie=UTF8&qid=1338268631&sr=8-1
Though you can find cheaper (eBay).  Just make sure it support ISP, is supported by AVRDUDE, and is supported by your Operating System.  It would be nice if it supplies 5v power.
3) Your HEX File
New versions of the program are uploaded to the following link:
https://code.google.com/p/phenomx7-etrigger/downloads/list
No, you do not need to desolder the chip from the board.  You can directly program the chip on the board.  The chip is writable, but must first be erased.  There is no way to backup the existing manufacturer's program, so USE AT YOUR OWN RISK.  There is no turning back once you install this software.
Good luck, and keep asking questions if you have trouble.
Cainxxx
Thanks for all replies man!! Last question, is there a way to backup original firmware?
mikedehaan
...is there a way to backup original firmware?
Unfortunately, there is no way to backup the original firmware.
Cainxxx
To implement in the future, this are the modes of Xboard Firmware:
Programmable Rate Of Fire-
1 to 30
Programmable Burst-mode-
2 to 8
Safe Burst mode -
Pulling the trigger three times in less than one second results in an X-shot burst on the third trigger pull. Each pull of the trigger in less than one second after this, results in another X-shot burst (X= 2 to 8 ).
Safe Full-Auto mode-
Pulling the trigger three times in less than one second results in full-automatic firing. Holding the trigger down on the third pull sustains this full-auto mode.
Auto-Response mode -
The marker fires on the pull and on the release of the trigger.
Turbo-mode -
Pulling the trigger three times in less than one seconds results in full-automatic firing at rate of 15 BPS. To sustain this rate of fire the trigger must be pulled at least once a second.
Semi-Auto -
This mode is the same as selecting the F firing mode with the selector switch (one pull/release of the trigger fires one time).
Burst mode -
The marker fires an X-shot burst on each trigger pull (X= 2 to 8 ).
Full-Auto mode -
Pulling the trigger results in full-automatic firing. Holding the trigger down on the first pull sustains this full-auto mode.
X mode -
Pulling the trigger results in full-automatic firing. Holding the trigger down on the first pull sustains this full-auto mode. The Rate of fire (ROF) will gradually increase depending on how long the trigger is held (10 to 25bps).
Super Response mode - aka A.D.A.M. mode
The marker fires an X-shot burst on each trigger pull and on the release of the trigger (X= 2 to 8 ).
The follow feature is suggested by me:
Abbility to Change RATE OF FIRE (betwen 2 rates, 15 and 25 for example) directly by pressing program button
mikedehaan
#68
Jun 07, 2012, 07:38 pm Last Edit: Jun 07, 2012, 08:50 pm by mikedehaan Reason: 1
1 to 30
We currently support a rate of fire between 5 and 40 (as of version 0.3)
2 to 8
We currently support a burst between 2 and 10 (as of version 0.4)
Safe Burst mode -
If more people request "safe" firing modes I will implement them, however, this was the reason behind the whole project (to remove the "safe" feature).
Same as above.
We currently support Auto-Response (as of version 0.3)
Turbo-mode -
Similar functionality can be achieved by increasing your Rate Of Fire setting on Full Auto firing mode.  We do not require pumping the trigger to keep the gun firing.  If more people request this feature, I can implement it.
Semi-Auto -
This is the same functionality as switching the selector switch to the F firing mode and therefore has not been implemented.  If more people request this feature, I will implement it.
Burst mode -
We currently support a burst between 2 and 10 (as of version 0.4).  To configure, select three round burst firing mode and adjust the burst size between 2 and 10.
Full-Auto mode -
We currently support Full Auto (as of version 0.3).
X mode -
We do not currently support full auto ramping.  If more people request this feature I will implement it, however, I have a few design changes I would implement instead.  I did not like the YouTube demo of this feature.
We do not currently support Auto Response Burst firing mode.  My opinion on this is the trigger would start to feel heavier latency as the gun would be in the middle of firing while you either pull or release the trigger.  It is incredibly easy to fully saturate your gun's mechanical limit of rounds per second with 3 round burst alone.  However, if more people would like this feature, I will implement it.
I definitely like this idea.  I will put this on the list to implement.
Thank you for your ideas!  Keep them coming!
bag06a
The programming via the button is a great idea.
Know whats weird?? I got out my multimeter and put it on the continuity test mode and tried it on all pins (started with the pins you defined as VCC and gnd) and I didn't get any continuity? Shouldnt it be beeping???
Hopefully be getting my blank chips soon also :)
mikedehaan
If you put the negative multimeter lead on the negative battery terminal, and the positive multimeter lead on the GND pin of the chip on the board, I would think the multimeter would show continuity.
I'll try this at home tonight and let you know if it works for me.
Coding Badly
Don't do that!  It violates the electrical specifications.  While very unlikely in this case, any time the electrical specifications are violated there is a possibility of damage.
mikedehaan
Wow, good catch.  I didn't think of that.  The multimeter is probably sending some voltage through to get from point A to B that might cause damage.  What about measuring Ohm's?  Would that do the same?
bag06a
Confirmed-- Negative terminal to Pin14 worked for continuity.
Coding Badly -- TY for the warning....I certainly dont want to fry my chip :-\. How does it violate specifications? Is it possibly sending to much current and/or voltage through the chip just with the batteries in the multimeter?
Coding Badly
Absolute Maximum Ratings*
Voltage on any Pin except RESET
with respect to Ground ................................-0.5V to VCC + 0.5V
*NOTICE: Stresses beyond those listed under "Absolute Maximum Ratings" may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
VCC with respect to GND is zero.  The continuity and ohm meters very likely operate outside the -0.5 to +0.5 volt range.
