Topic: Starting my first UGV project - need some starting help (Read 26509 times) previous topic - next topic
TiboJ
It also depends on transmitter and receiver.
So it can be less then 500m with some.
cr0sh
If I use Nootropic Design Video Experimenter shield on my Arduino, will I be able to add GPS function to the Arduino?
I only suggested the Nootropic VE as what to look for; because it utilizes the TVOut library, it actually uses up a -ton- of RAM on the Arduino (and it won't work with a Mega); there are other devices out there that would probably be a better fit for your application, that would be more "standalone", in that they use their own on-board microcontroller or whatnot to work (look up "microcontroller", "video overlay", "OSD", "on-screen display", "arduino" to find other such devices).
Alternatively, use the Nootropic VE with it's own Arduino, and communicate with that Arduino via serial or SPI (at this point, you should use SPI, with the WT board as the master, and your other Arduinos as slaves with their own addresses).
Other than the memory usage, your only worry would then be what pins it needs, etc; if those interfere with anything else you plan to use and you can't use substitutes, then it probably won't work well.
TiboJ
Ok, I'll search some others and gather information.
TiboJ
#48
May 23, 2012, 08:52 pm Last Edit: May 23, 2012, 09:16 pm by TiboJ Reason: 1
I just found this:
http://shop.ciseco.co.uk/xrf-wireless-rf-radio-uart-rs232-serial-data-module-xbee-shape-arduino-pic-etc/
Seems that wifi can have excellent range! I will research this, because this will maybe be better then 2.4Ghz.
edit:
I also found the xbee module, and it can reach a range of 1500m outdoor, and uses 2.4Ghz.
Will the xbee module with 2.4Ghz have the same problems with obstacles as the 2.4Ghz transmitter has?
Or does the xbee use the special wifi technology, that eliminates the problem?
http://www.digiwireless-solutions.com/Bizit/store/product.php?id_product=186
TiboJ
I just ordered the Wild Thumper 6WD 75:1 Chassis, the WP controller and the WP high current switch.
TiboJ
I received it all and it is all nice working, expect the following:
I can control the wild thumper forward, backward, and right, but not left.
It is connected  up like here:
The code that I'm using is the standard one:
http://www.exp-tech.de/service/Sample%20Code/Wild_Thumper_Controller.zip
The transmitter is a Futaba T6EX 2.4ghz and the receiver is also from futaba and 2.4ghz.
What could be the reason that I can't let the wild thumper go to the left?
If I change the Dual Rate on the transmitter to 0%, then the wild thumper can't even turn to the right...
TiboJ
I got it working now. Now I'm trying to control the motor with the right stick, but that seems to be not working.
TiboJ
Got it also working
TiboJ
The range of my UGV is now about +1km in line of sight.
How much will the range reduce in buildings?
If no one knows, I'll test it tomorrow or next week.
TiboJ
I just tested the range of the UGV in a densely forested area, and it all did it right. The range that I just tested was about 100m.
After that, I tested the range at the other side of my house, and still everything did it good.
I'll do some larger  obstacle range tests soon, and see what the results are.
TiboJ
#55
Jun 14, 2012, 07:25 pm Last Edit: Jun 14, 2012, 08:08 pm by TiboJ Reason: 1
When I drive over the grass in my garden, and I turn left or right, then the Wild Thumper stops working;
the control over it has gone, and I need to disconnect and reconnect the battery to make it work again.
The Wild Thumper Motor Controller and my receiver doesn't go off, I just lose controls.
Is this because my 8.4V 4600mAh NiMh battery is to weak? Should a LiPo battery fix this problem?
The turning is by turning the wheels in opposite direction. So this problem only happens when I spin, but not when making a smooth turn.
And, the spinning works on flat surfaces. It only has problems on grass and other not-flat surfaces.
Can someone help me, please?
EDIT: I just saw that when the controls stop working, the battery led went off(led 5) on the WP motor controller. So it has probably something to do with the battery. I've tried about 5 different NiMh battery's, and all no luck.
cyclegadget
It could be tripping a safety because of overload then resetting to operate again, or it could be a loose connection related to the battery circuit.
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
TiboJ
Yes, at this time the controller shuts down the wild thumper if the voltage is around 6.3V.
Probably its the voltage drop of the wires and tamiya connectors that causes the controller to think the battery is at 6.3V.
I'll put some deans connectors and a lipo battery on it, instead of the tamiya connectors with a nimh battery.
DuaneB
    Another thing to look into is 'thermal shutdown', its 47 degrees in Dubai today and my ESCs are shutting down. This is a safety mechanism built into them which is designed to shut them down if the motors are stalled and too much heat builds up as a result.
In your case grass and particularly counter rotating on grass will put a lot of strain on whatever is driving the motors, if there is a thermal shutdown circuit it might be getting triggered.
Two solutions-
1) Add a fan
2) Cut your grass !
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
TiboJ
The controller has 2 fuses, but they don't burned out. I think there isn't any thermal circuit.
1) Add a fan
It already has a heatsink. And the heat is not the problem I think, because the wild thumper controller and wires aren't hot when it shuts down
2) Cut your grass !
It's already cut and very short, so that isn't the problem.
It is an all-terrain vehicle :) But probably other tires will help alot.
