Topic: Rapidly spinning laser to create one-lined image (Read 3798 times) previous topic - next topic
Chagrin
The Transistor as Switch section shows setup. Also read the "Connecting a transistor from the output of an IC" for an explanation of what's going on. Heck, read the whole page and you'll be a lot smarter in the end ;)
The current drawn by a laser pointer is very low so pretty much any N-channel transistor you have will work.
cr0sh
#16
May 13, 2012, 08:10 am Last Edit: May 13, 2012, 08:12 am by cr0sh Reason: 1
Something like this?
Yes! Exactly. :)
Something you might have to play with is finding the right photo-transistor; most are at best sensitivity in the IR region (look at the datasheet), but you can get ones that are sensitive in other bandwidths.
zoomkat
I've driven a cheap laser pointer using a transistor without issue. No problem switching it at 38KHz for use with an IR receiver.
Interesting. How sensitive are the IR receivers to the visible red spectrum of the cheap laser pointers?
David82
Why do I need to use a transistor? If the end result is still the laser being rapidly cycled then what's wrong with just using one of the digi out pins?
dxw00d
Chagrin
That's a tough question to answer; given the nature of the coherent beams of lasers it should be sensitive at "any" distance. I quickly got a signal at ~12 meters distance (the longest clear span in my house) without tweaking the laser focus, frequency, or power and didn't take it any farther. My goal was only to build a laser tripwire and I wasn't attempting long distance communication.
Grumpy_Mike
David82
Read this for driving a laser:-
http://www.repairfaq.org/sam/laserdps.htm
That's too much info. Why can't I buy some cheap, green laser from eBay and rapidly turn it on/off using a digi out pin (assuming the voltage is not more than the required amount for the laser)?
winner10920
Why can't you? Lol try it or search online if someone did before, I haven't tried it(couldn't get it open)  and don't know of anyone who did
Runaway Pancake
It's not the voltage, in that case - it's the current.
Do you have a laser pointer or a similar, simple laser module (5V or 3V) at hand?
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Runaway Pancake
Getting something done with a low-power module will be a lot easier than something "high-power".
There's not a PnP, "one-size-fits-all" solution for you.
Grumpy_Mike
That makes me sad.
You can't be bothered to read this simplified web page. What ever makes you think you are going to understand what to do.
Well that page would have told you.
Hint:- it is.
David82
Hint:- it is.
If the laser wants 3v, then I just add the appropriate resistor right? Problem solved. Is there something I'm missing or is it not that simple? If I am missing something, why can't it be mentioned in one or 2 sentences? Like this, "That won't work because X, Y, Z"
zoomkat
Did you use a modular IR receiver like is used in typical home IR remote controlled electronics? If so, which particular one did you use?
Grumpy_Mike
Wrong.
This won't work because a laser presents a varying impedance to the thing driving it and so a simple resistor will not be able to give it the constant current it needs.
