Author Topic: Arduino Mega Replacement components  (Read 662 times)
Hi, I have two burnt-out components on my Arduino Mega. I found them on the online schematic, but I'm not sure where to look for them.
They are:
D1:
DIODE-SMB (DIODE-)
C6:
CPOL-EUSMCD (CPOL-EU)
I looked at the top of the components and they had the following labels:
D1:
GW
4007
C6:
A476D
10F60
Does anyone know where I can find replacement parts?
Boston area, metrowest
Digikey.
Search for 1N4007 in SMB package.
Search for aluminum cap in surface mount package, probably 100uF, 25V, maybe 5mm?
I think I found an appropriate capacitor:
Manufacturer:   Murata Electronics North America
Manufacturer Part Number:   ECASD91B107M012K00
Description:   CAP ALUM 100UF 12.5V 20% SMD
Lead free / RoHS Compliant
However, SMB packaged diodes for some reason aren't the same size as the one I measured on the board. It appears to match an SMA packaged diode.
I found this diode which appears to be the correct size:
Manufacturer:   Diodes Inc
Manufacturer Part Number:   S2BA-13-F
Description:   RECTIFIER GPP 100V 1.5A SMA
Lead free by exemption / RoHS Compliant
Is there anything glaring that would suggest why either of these won't work (I'm a mechanical engineer normally so I don't have a lot of electronics experience)?
If they fit on the board, they will do fine.
How did you damage the input power section?
A battery pack had the red wired as ground and black as hot, so I accidentally plugged it in backwards smiley-sad These were the only two components which had visible damage, hopefully the board will work after I replace them.
Oooh, nasty!
Hopefully the diode took the brunt of it.
SE USA
@ssh0le
SMA is smaller than SMB but it should fit on the pads enough to solder
Got the two parts on and the chip works like a charm smiley
